Forum Topic - devnp-e1000 driver with typed_mem on i.MX8 platform (SDP 7.1.0):
I am trying to load the e1000 driver on an i.MX8QN MEK board (using the latest official BSP on SDP 7.1.0) but the driver
 load fails with the following error in the system log:
Jan 01 03:13:16.684         io_pkt_v6_hc.385071..1                 slog      0  translate 0x970caf000, len 1000
Jan 01 03:13:16.684         io_pkt_v6_hc.385071..1                 slog      0  Unable to obtain buffer translation
information, The Address Space Is Invalid/Could Not Be Translated [(PCI_ERR_ASPACE_INVALID)]
I am using the driver typed_mem option and the io-pkt-v6-hc pkt-typed_mem option, as shown in the driver use description
, for example:
# io-pkt-v6-hc -i3 -de1000 typed_mem="/memory/below4G/ram/sysram/" -ptcpip pkt_typed_mem="/memory/below4G/ram/sysram/",
prefix=/sock3
# SOCK=/sock3 ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 33136
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
I have also tried the following typed memory strings:
below4G
/memory/below4G
/memory/below4G/ram
All give the same error.
How can I load this driver on an AARCH64 i.MX8 platform?
Post Deleted
Post Deleted
Post Deleted
Re: devnp-e1000 driver with typed_mem on i.MX8 platform (SDP 7.1.0)
I can't access that either.
Would it be possible to send me details of the code change? I have e1000 source code (from SDP 7.0.3) so perhaps I can
apply the change myself.
Ah sorry, thought you were internal. You will need to contact your QNX support person and quote issue JI:2876490
