05/19/2008 12:14 PM
post8242
In qnx6.3.2, i tried to use qnet with another qnx6.2.1:
$mount -T io-net /lib/dll/npm-qnet-compat.so
But has the following err:
mount: Can't mount / (type io-net)
mount: Possible reason: Resource temporarily unavailable.
I tried to slay io-net and then tried again, but still failed. Look forward to ur solutions. thank u
RE: Unable to mount io-net
05/19/2008 1:35 PM
post8243
Are you only running one version of qnet? You can't run both qnet-compat
and qnet-l4-lite at the same time. If you are, only running one version of
qnet, what's the output from
pidin -pio-net mem
Robert.
Sent: Monday, May 19, 2008 12:15 PM
To: drivers-networking
Subject: Unable to mount io-net
Networking Drivers
http://community.qnx.com/sf/go/post8242
Re: RE: Unable to mount io-net
05/20/2008 8:33 AM
post8252
> pidin -pio-net mem
> Robert.
> From: Eric Dong [mailto:eric.dongxx@gmail.com]
> Networking Drivers
You are right. Under mem column, there was a "npm-qnet.so", which should be a sign that the elder version of qnet is
running.
But how can i stop using it? i tried "slay io-net", but no effects. thank u.
RE: RE: Unable to mount io-net
05/20/2008 10:51 AM
post8270
Hi Eric:
If you slay io-net and then do a pidin, is io-net no longer running?
Perhaps the best thing to do is to provide the following information
pidin -p io-net mem
slay io-net
pidin -p io-net mem
/sbin/io-net
pidin -pio-net mem
Robert.
Sent: Tuesday, May 20, 2008 8:33 AM
Subject: Re: RE: Unable to mount io-net
of
> pidin -pio-net mem
> Robert.
forward
> Networking Drivers
a sign that the elder version of qnet is running.
u.
Networking Drivers
http://community.qnx.com/sf/go/post8252
05/20/2008 10:57 AM
post8271
Sometimes io-net will get wedged (usually
due to a malfunctioning driver) and slay
will not terminate it. In this situation
you can either:
# kill -9 <pid>
Or
# slay -s SIGKILL io-net
aboyd
Sent: Tuesday, May 20, 2008 10:51 AM
Subject: RE: RE: Unable to mount io-net
Hi Eric:
pidin -p io-net mem
slay io-net
pidin -p io-net mem
/sbin/io-net
pidin -pio-net mem
Robert.
of
> pidin -pio-net mem
> Robert.
forward
> Networking Drivers
u.
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post8270
Re: RE: RE: Unable to mount io-net
05/21/2008 1:38 AM
post8291
Thanks very much.
Now i really slayed io-net, since the output of "pidin -pio-net mem" had nothing (no elder version of qnet is running).
Then i tried to mount qnet-compat, still the same error. What r the possible reasons??
RE: RE: RE: Unable to mount io-net
05/21/2008 9:51 AM
post8305
Hm. Sometimes the command line arrangement
of mount can be a little user-unfriendly :-(
After making sure that there are really no
other io-net instances running, have you
simply tried:
# io-net -d i82544 -p qnet-compat
aboyd
Sent: Wednesday, May 21, 2008 1:38 AM
Subject: Re: RE: RE: Unable to mount io-net
Thanks very much.
nothing (no elder version of qnet is running). Then i tried to mount
Networking Drivers
http://community.qnx.com/sf/go/post8291
05/21/2008 10:06 AM
post8307
Hi Eric:
What happens if you try
io-net -p/lib/dll/npm-qnet-compat.so
Can you also post the output from sloginfo and pidin so that we can see what
else is running?
Robert.
Thanks very much.
Networking Drivers
Re: RE: RE: RE: Unable to mount io-net
05/22/2008 5:10 AM
post8362
Thanks.
Output of pidin:
pid tid name prio STATE Blocked
1 1 procnto 0f READY
1 2 procnto 10r RECEIVE 1
1 3 procnto 10r RUNNING
1 4 procnto 10r RECEIVE 1
1 5 procnto 10r RECEIVE 1
1 6 procnto 10r RECEIVE 1
1 7 procnto 10r RECEIVE 1
1 8 procnto 10r RECEIVE 1
1 9 procnto 10r RECEIVE 1
1 10 procnto 10r RECEIVE 1
1 11 procnto 10r RECEIVE 1
2 1 sbin/tinit 10o REPLY 1
4099 1 proc/boot/pci-bios 12o RECEIVE 1
4100 1 proc/boot/slogger 10o RECEIVE 1
4101 1 proc/boot/io-usb 10o SIGWAITINFO
4101 2 proc/boot/io-usb 21r RECEIVE 4
4101 3 proc/boot/io-usb 21r RECEIVE 7
4101 4 proc/boot/io-usb 21r RECEIVE 10
4101 5 proc/boot/io-usb 21r RECEIVE 13
4101 6 proc/boot/io-usb 21r RECEIVE 1
4101 7 proc/boot/io-usb 10o RECEIVE 16
4101 8 proc/boot/io-usb 10r NANOSLEEP
4101 9 proc/boot/io-usb 10o RECEIVE 16
4102 1 proc/boot/io-hid 10o SIGWAITINFO
4102 2 proc/boot/io-hid 10o RECEIVE 4
4102 3 proc/boot/io-hid 10o RECEIVE 4
4102 4 proc/boot/io-hid 10r REPLY 4101
4102 5 proc/boot/io-hid 15r RECEIVE 12
4102 6 proc/boot/io-hid 15r RECEIVE 16
4103 1 /boot/devc-con-hid 10o RECEIVE 1
4103 2 /boot/devc-con-hid 10o REPLY 4102
8200 1 roc/boot/devb-eide 10o SIGWAITINFO
8200 2 roc/boot/devb-eide 21r RECEIVE 1
8200 3 roc/boot/devb-eide 21r RECEIVE 4
8200 4 roc/boot/devb-eide 10o RECEIVE 10
8200 6 roc/boot/devb-eide 10o RECEIVE 7
8200 7 roc/boot/devb-eide 10o RECEIVE 7
8200 8 roc/boot/devb-eide 10o RECEIVE 7
8200 10 roc/boot/devb-eide 10o RECEIVE 7
8200 12 roc/boot/devb-eide 10o RECEIVE 7
8201 1 oc/boot/umass-enum 10o SIGWAITINFO
8201 2 oc/boot/umass-enum 10r REPLY 4101
16394 1 sbin/pipe 10o SIGWAITINFO
16394 2 sbin/pipe 10o RECEIVE 1
16394 3 sbin/pipe 10o RECEIVE 1
16394 4 sbin/pipe 10o RECEIVE 1
20491 1 sbin/mqueue 10o RECEIVE 1
49164 1 sbin/enum-devices 10o REPLY 16394
77838 1 sbin/devp-pccard 21o RECEIVE 1
77839 1 sbin/enum-pccard 29f RECEIVE 1
77840 1 sbin/io-audio 10o SIGWAITINFO
77840 2 sbin/io-audio 10o RECEIVE 1
77840 3 sbin/io-audio 10o RECEIVE 1
77840 4 sbin/io-audio 10o RECEIVE 1
77840 5 sbin/io-audio 50r INTR
94225 1 sbin/devc-par 10o RECEIVE 1
94225 2 sbin/devc-par 9r CONDVAR 8053e00
94227 1 sbin/io-net 10o SIGWAITINFO
94227 2...
RE: RE: RE: RE: Unable to mount io-net
05/22/2008 9:15 AM
post8372
I'm guessing that this is right after booting? If you don't want qnet to
start up on booting you have to remove the /etc/system/config/useqnet
(See Creating useqnet here:
http://www.qnx.com/developers/docs/6.3.2/neutrino/user_guide/qnet.html
To kill io-net after it's running, you have to become root and do a "slay -s
SIGKILL io-net"
Robert.
Sent: Thursday, May 22, 2008 5:10 AM
Subject: Re: RE: RE: RE: Unable to mount io-net
Thanks.
Output of pidin:
Re: RE: RE: RE: RE: Unable to mount io-net
05/22/2008 10:18 AM
post8378
Thx so much.
I deleted the file you specified, and i mount the qnet-compat again, now it worked. A little strange abt that is the
useqnet is a total empty file without any scripts, then the system will still start the qnet service everytime it boots?
Eric
RE: RE: RE: RE: RE: Unable to mount io-net
05/22/2008 10:42 AM
post8382
Hi Eric:
What happens is that the startup script (/etc/system/sysinit) just
looks for the existence of that file and acts accordingly. That's covered
in the section of the docs that I sent the link for.
Glad that things are working for you now.
Robert.
Sent: Thursday, May 22, 2008 10:19 AM
Subject: Re: RE: RE: RE: RE: Unable to mount io-net
Thx so much.
worked. A little strange abt that is the useqnet is a total empty file
everytime it boots?
Eric
Networking Drivers
http://community.qnx.com/sf/go/post8378
