Forum Topic - Ethernet errors detection:
I need a way to detect any ethernet errors (e.g. crc check failed, cable unplugged, etc). Is there any api to obtain
these errors programmatically? I tried to investigate io-pkt, but this tool is only allows to write and launch own
drivers, but I couldn't find api to check health status of those drivers.
Thank you.
Re: Ethernet errors detection
Take a look at the output of the "nicinfo" command, this reports the Ethernet stats. Note that this is entirely driver
dependent - different drivers report different stats.
The code for this is:
	struct drvcom_stats	dstats;
	nic_stats_t		*statp;
	statp = &dstats.dcom_stats;
		ifdcp->ifdc_cmd = DRVCOM_STATS;
		ifdcp->ifdc_len = sizeof(*statp);
		if ((ret = devctl(s, SIOCGDRVCOM, ifdcp,
		    sizeof(struct drvcom_stats), NULL)) == EOK) {
			dump_stats(s, statp);
Link state is a separate API:
#include <errno.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <sys/socket.h>
#include <sys/ioctl.h>
#include <netinet/in.h>
#include <net/if.h>
int main(int argc, char **argv)
    int			s;
    struct ifdatareq	ifdata;
    if (argc != 2) {
      fprintf(stderr, "Incorrect usage\n");
      return 1;
    s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
    if (s == -1 && errno != EPROTONOSUPPORT) {
      fprintf(stderr, "can't open IPv4 socket %s", strerror(errno));
      return 1;
    memset(&ifdata, 0, sizeof(ifdata));
    strlcpy(ifdata.ifdr_name, argv[1], IF_NAMESIZE);
    if (ioctl(s, SIOCGIFDATA, &ifdata) == -1) {
	fprintf(stderr, "ioctl failed: %s\n", strerror(errno));
	exit(1);
    fprintf(stdout, "Linkstate %d\n", ifdata.ifdr_data.ifi_link_state);
    return 0;
Thanks a lot for response!
> stats. Note that this is entirely driver dependent - different drivers report
> different stats.
> 	nic_stats_t		*statp;
Could you tell me what header files do I need for this code?
Also, as I understand, do we need to reach driver suppliers in order to extend information about Ethernet interface?
See net/ifdrvcom.h and hw/nicinfo.h
You will need to look at the valid_stats field in nic_ethernet_stats_t to determine which stats the driver supports. If
that doesn't have everything you need then yes, you will need to contact the driver vendor to add support.
