Re: ptpd very long synchronisation time
08/21/2019 4:01 PM
post119819
Hi Lomash,
> Our test records indicate a sync time of 9 minutes while running ptpd and
> about 5 when running ptpd-avb.
Thanks for the data.
> Regarding ptpd-avb not syncing, are you using ptpd-avb as the master? If so,
> we recently discovered a bug in the implementation which affects time sync. So
> , you could ask QNX support for an experimental release with the fix for JI:
> 2773204.
Yes, I was using ptpd-avb as the master. I will ask for this release
> However, ptpd-avb should still be able to sync with a ptp4l master without the
> fix.You could try that out.
I have tried and got mixed results. I did see it synchronise once but most of the time it does not. More specifically,
the slave clock diverges from the master rather than converging.
Most of my tests were using P2P with direct cable connection between master and slave interfaces. I am using ptp4l
version 1.6 on Ubuntu 16.04 with i210 master.
What is your test configuration?
John
