QNX7 devnp-e1000.so works for Intel Integrated I350 NIC for x86_64 but not x86_32
12/29/2017 4:26 PM
post118299
I made a bsp with the alpha qnx7 momentics and was able to get a x86_64 bsp to work with a Dell R720 and all it's pci
and integrated interfaces.
I tried to create a x86_32 bsp and the nic isn't compatible. Am I doing something wrong? I made sure to set the
stacksize to 4096 and made sure all of the 32bit architecture parameters were accounted for.
When I would run a ifconfig the bottom of the output would state ifconfig: link_status: ioctl: Bad Address
Along with nicinfo -v would output bad address next to dvcr_config and another attribute.
I am assuming that the x86_32 bit version of the e1000 driver is not compatible with the NIC.
Am I wrong in this assumption?
Thanks! Also if there is any additional information out there for building bsps I would appreciate the help. I have
pulled all the documentation from qnx and foundry but any additional info would be nice!
