Forum Topic - io-pkt-v4-hc kills off ppp:
I have a problem with a PC/104 board running QNX 6.6.0 that communicates over an RS232 serial link with a card that
communicates using Modus RTU over a PPP link. This worked fine until the original PC/104 card became obsolete (Kontron
MOPSlcdLX) and we had to find a replacement (Diamond Systems Rhodeus). Now every time the software attempts to connect
to the Modbus link it fails The old hardware still works fine.
I wanted to debug the system over an Ethernet connection so the first thing to do was get the network hardware working
which I eventually did. The problem is that this seems to have killed off the PPP support.
Here's the problem. After rebooting I can run ifconfig and I see this:
ppp0: flags=8050<POINTTOPOINT,RUNNING,MULTICAST>mtu 1500
After executing these commands:
io-pkt-v4-hc -ptcpip -drtl &
waitfor /dev/socket 10
ifconfig en0 172.27.12.104 netmask 255.255.255.0 broadcast 172.27.12.255
route add default 172.27.12.253
inetd &
I then do another ifconfig and I get this:
en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu 1500
        address: 00:05:b7:e6:a3:7b
        media: Ethernet 100baseTX full-duplex
        status: active
        inet 172.27.12.104 netmask 0xffffff00 broadcast 172.27.12.255
ppp0 has vanished! Why is this? ppp0 isn't using any network hardware at all, just a serial port, so why does
configuring the network have any effect on it?
Any help appreciated.
Re: io-pkt-v4-hc kills off ppp
You now have a second io-pkt instance running the Ethernet interface and this is hiding the first instance that is
running the ppp interface.
I suspect you actually just wanted to load the Ethernet interface in to the original io-pkt:
mount -T io-pkt devn-rtl.so
It is also possible to run two separate io-pkt instances, that's a little more involved because you have to use the SOCK
 environment variable everywhere to specify which one you want to talk to.
