Re: io-pkt leak data section - ppc8260 ethernet driver
11/23/2016 9:58 AM
post117178
Just to let you know, this problem is fixed in the latest 6.5.0 io-pkt, so
the only way that we can give you the latest io-pkt is for you to send us
your hardware and source code to your driver. The latest io-pkt requires a
new libc, so the driver needs to be recompiled and tested on your hardware.
On 2016-11-23, 9:29 AM, "Thomas Luetzel" <community-noreply@qnx.com> wrote:
>Hi, yes the VM is connected to the a network but if the VM is running
>without the shell script
>run.sh
>while [ 0 -lt 1 ]
>do
> df >> /dev/null
>done
>the memory increases very fast!
>To the answer to Hugh - I am not running any BSP on a target hardware! I
>can reproduce this issue on a VM provided from the QNX homepage. My DUT
>(device under test) is delivered now from QNX, nothing implemented
>installed done from my side!
>Attched you will also find the timeline tracelog. I've marked a REPLY
>BLOCED from io-pkt by the df procress. This happens multiple times.
>Anything else what I can do to generate log which will help to isolate
>this behaviour.
>Thanks in advance
>Networking Drivers
>http://community.qnx.com/sf/go/post117176
