08/15/2015 3:46 PM
post114266
Is there a driver for the 10ec:8168 controller available for QNX 6.5.0?
Class = Network (Ethernet)
Vendor ID = 1814h, Realtek Semiconductor Co., Ltd.
Device ID = 3091h, RTL8111/8168B PCI Express Gigabit Ethernet controller
PCI index = 0h
Class Codes = 020000h
Revision ID = 6h
Andrey
Re: RTL8111/8168B support
08/17/2015 7:52 AM
post114269
Yes, devnp-rtl8169.so.
On 2015/8/15, 3:46 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
wrote:
>Hi,
>controller
>PCI index = 0h
>Revision ID = 6h
>Regards,
>Andrey
>Networking Drivers
>http://community.qnx.com/sf/go/post114266
08/17/2015 2:11 PM
post114274
Hello Hugh!
Unfortunately, this driver does not work for me. I've tried both 6.5.0 and 6.5.0SP1 versions with the same result. It
seems like driver does not forwarding telnet/ftp/nfs/... traffic up to the stack. ping utility works with huge (~1 min)
timeouts.
Please find logs attached:
- pidin mem;
- ifconfig;
- nicinfo;
- sloginfo;
- ping.
Andrey
08/18/2015 9:03 AM
post114282
Please will you run the attached debug driver with your ping and post the
sloginfo output?
Thanks, Hugh.
On 2015/8/17, 2:11 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
wrote:
>Hello Hugh!
>and 6.5.0SP1 versions with the same result. It seems like driver does not
>with huge (~1 min) timeouts.
>- pidin mem;
>- ifconfig;
>- nicinfo;
>- sloginfo;
>- ping.
>Regards,
>Andrey
>Networking Drivers
>http://community.qnx.com/sf/go/post114274
08/18/2015 2:11 PM
post114292
Hello Hugh!
Unfortunately, I have "Unresolved symbol "nic_delay" called from devnp-rtl8169.so" with this version. Thank you for your
help.
Andrey
08/18/2015 2:21 PM
post114293
Are you running 6.5.0 SP1?
On 2015/8/18, 2:11 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
wrote:
>Hello Hugh!
>devnp-rtl8169.so" with this version. Thank you for your help.
>Regards,
>Andrey
>Networking Drivers
>http://community.qnx.com/sf/go/post114292
08/18/2015 2:32 PM
post114294
Yes, it was updated to 650SP1 (qnxsdp-6.5.0SP1-x86-201206270843-nto.sh).
08/18/2015 2:57 PM
post114295
Please try the attached driver.
On 2015/8/18, 2:32 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
>Networking Drivers
>http://community.qnx.com/sf/go/post114294
08/18/2015 3:51 PM
post114297
Please find the sloginfo output attached. The only difference is that there is no driver timeouts.
08/19/2015 7:33 AM
post114303
OK, I think that I can see what is happening. For some reason this chip
returns a zero length for some receive instances. Could you please do one
more thing for me? Start the driver with ³verbose=3², do a few pings, and
send me the sloginfo output.
Thanks, Hugh.
On 2015/8/18, 3:51 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
>Networking Drivers
>http://community.qnx.com/sf/go/post114297
08/19/2015 1:17 PM
post114306
The debug driver is crashing with any verbose option. Default SP1 version running without faults. Both sloginfo outups
attached.
Andrey
> Thanks, Hugh.
08/20/2015 8:56 AM
post114310
I’ll take a look at this when I have a chance. I’m rather tied up right
now.
On 2015/8/19, 1:17 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
>running without faults. Both sloginfo outups attached.
>Thanks,
>Andrey
>>one
>>and
>> Thanks, Hugh.
>Networking Drivers
>http://community.qnx.com/sf/go/post114306
08/20/2015 1:32 PM
post114316
Ok. Thanks for your help.
Andrey
> now.
08/25/2015 12:53 PM
post114335
When does io-pkt crash - just after starting the driver or when you try to
ifconfig the interface? I have run the devnp-rtl8169.so driver that I sent
you with ³verbose=3² and I don¹t get a crash.
On 2015/8/20, 1:32 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
>Regards,
>Andrey
>> I¹ll take a look at this when I have a chance. I¹m rather tied up right
>> now.
>Networking Drivers
>http://community.qnx.com/sf/go/post114316
08/25/2015 1:42 PM
post114336
Hello Hugh!
It's crashing right after starting.
The only workaround is the following: "LD_DEBUG=libs io-pkt-v4-hc -ptcpip -drtl8169 verbose=3". sloginfo output for this
case is attached.
Andrey
08/25/2015 1:46 PM
post114337
Can you use this workaround for the time being, as it appears that the
driver is working when you do this? If so, I can send you a driver with
the debug removed until such time that I can update the driver.
Thanks, Hugh.
On 2015/8/25, 1:42 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
wrote:
>Hello Hugh!
>-drtl8169 verbose=3". sloginfo output for this case is attached.
>Regards,
>Andrey
>>to
>>sent
>Networking Drivers
>http://community.qnx.com/sf/go/post114336
08/25/2015 2:08 PM
post114338
Ok. Thaks!
08/25/2015 2:24 PM
post114339
I have attached the driver to this email. Please will you also try the
following and see if it works:
io-pkt-v4-hc -ptcpip stacksize=8192
mount -Tio-pkt devnp-rtl8169.so
Thanks, Hugh.
On 2015/8/25, 2:08 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
wrote:
>Ok. Thaks!
>Networking Drivers
>http://community.qnx.com/sf/go/post114338
08/25/2015 2:45 PM
post114340
It seems like this driver works well. Thank you very much.
Andrey
08/25/2015 2:47 PM
post114341
Good news.
Thanks, Hugh.
On 2015/8/25, 2:45 PM, "Andrey Docuchaev" <community-noreply@qnx.com>
>Regards,
>Andrey
>Networking Drivers
>http://community.qnx.com/sf/go/post114340
