Forum Topic - Unable to detect 82574L port with QNX6.5 SP1: (2 Items)
My x86 board has two Ethernet ports which is displayed in BIOS. While the first port(Topcliff) get detected, the second
port (82574L) does not get detcted.
Without any initialization the first port(wm0) is getting detected, but when I am including the following line in "/etc/
rc.d/rc.local"
io-pkt-v4-hc -de1000 did=0x10d3 vid=0x8086 pci=0x0 -ptcpip &
 or
io-pkt-v4-hc -de1000 did=0x10d3 -de1000 did=0x8802 -ptcpip&
even the first port wm0  does not get detected.
I have attached the pci-vvv output.
Attachment: Text pci_vvv.txt 57.7 KB
Re: Unable to detect 82574L port with QNX6.5 SP1
You must not have spaces in the command line. Try running the following
command and let us know if the driver starts on the second port:
io-pkt-v4-hc -de1000 vid=0x8086,did=0x10d3
If this doesn¹t work, then you might need a newer version of the e1000
driver.
On 2015/5/12, 6:15 AM, "Samya Deb Bhattacharya"
>first port(Topcliff) get detected, the second port (82574L) does not get
>detcted.
>when I am including the following line in "/etc/rc.d/rc.local"
> or
>Networking Drivers
>http://community.qnx.com/sf/go/post113798
