12/03/2014 11:16 AM
post112526
"use -i ..." returns the build version of a binary.
If you mean which variant i.e. whether you are io-pkt-v4, io-pkt-v4-hc, io-pkt-v6-hc then I don't know that it really
matters. You could try doing something IPv6 and see if you get unknown protocol back, if not then you are io-pkt-v6-hc.
Then to determine between the two IPv4 only variants io-pkt-v4-hc listens on /dev/crypto and io-pkt-v4 doesn't.
