Forum Topic - i82544 interrupts.:
i82544 interrupts.
On my QNX 6.5 SP1 / PPC platform
It seems that  the i82544 driver doesn't receive the interrupts form the controller (intel 82546B dual port Ethernet
Controller on a PCI board).
I have a PCI analyser and I can see the interrupt fired when I connect a cable. The PCI interrupt line is then
transformed in a MSI (0x3b for instance) on PCIe by a bridge PCI/PCIe . But the driver doesn't react to this interrupt
(no access to the bus). However if, at this time,  I run a little piece of code wich attach to the same interrupt (0x3b)
 the system hangs up that I suppose is normal because I run for ever in my Interrupt handler which actually does nothing
Moreover the nicinfo command shows interrupt 0x3b.
Any idea will be greatly welcomed  =;o)
Re: i82544 interrupts.
Why are you running the i82544 driver? You should use the e1000 driver as
the i82544 driver has been replaced.
On 2014/11/26, 4:31 AM, "Philippe Elskens" <community-noreply@qnx.com>
wrote:
>Hello,
>controller (intel 82546B dual port Ethernet Controller on a PCI board).
>cable. The PCI interrupt line is then transformed in a MSI (0x3b for
>this interrupt (no access to the bus). However if, at this time,  I run a
>little piece of code wich attach to the same interrupt (0x3b) the system
>handler which actually does nothing.
>Networking Drivers
>http://community.qnx.com/sf/go/post112444
Hello Hugh,
unfortunatly I do the test with the e1000 driver with the same results.
I see that you are on PPC, but I don¹t have one to try this, so maybe one
of our FAE¹s can take a look at this.
On 2014/11/26, 8:00 AM, "Philippe Elskens" <community-noreply@qnx.com>
wrote:
>Hello Hugh,
>Networking Drivers
>http://community.qnx.com/sf/go/post112450
