Forum Topic - General advice for Marvell 88E6176 switch driver development?:
This is more of a "broad brushstroke" question, mainly due to my lack of QNX knowledge.
Our hardware has a 88E6176 switch attached on the MII bus. We would like to give the user the ability to set the various
 registers over a local socket. It would be a low level interface, i.e. "set this register to this value."
So here are some basic questions:
- Can I simply call mmap_device_memory to write to the device? Probably not, because the existing ethernet driver will
be writing stuff to the MII bus.
- Which category would this driver belong in? It's not really an io-pkt driver.
- Is there already a device driver for something similar, with associated source code?
- Is there a PDF describing how to write device drivers? I found one called "QNX  Momentics  DDK - Network Devices" but
it's for Neutrino 6.3. Also the MII_ functions it describes don't seem to be supported in Neutrino 6.5 SP1. For example,
 a help file search for MII_Register_Extended returns no results (Momentics version is 4.7).
Thanks!
Re: General advice for Marvell 88E6176 switch driver development?
You can add a devctl call to the driver so that an external program can
read/write the switch registers. Here is a programming guide for io-pkt
drivers.
http://community.qnx.com/sf/sfmain/do/downloadAttachment/projects.networkin
g/discussion.drivers.topc20933/post89118;jsessionid=8628BFDB82FF9A97611B177
AAA18FDA4?id=atch11180
On 2014/8/15, 10:10 AM, "Derek Ross" <community-noreply@qnx.com> wrote:
>Hello,
>QNX knowledge.
>to give the user the ability to set the various registers over a local
>this value."
>not, because the existing ethernet driver will be writing stuff to the
>MII bus.
>driver.
>source code?
>called "QNX  Momentics  DDK - Network Devices" but it's for Neutrino 6.3.
>Neutrino 6.5 SP1. For example, a help file search for
>Thanks!
>Networking Drivers
>http://community.qnx.com/sf/go/post111453
> drivers.
There's an updated version of that note in the SDP 6.6 documentation:
http://www.qnx.com/developers/docs/660/topic/com.qnx.doc.core_networking.user_guide/topic/native_drvr.html?cp=3_0_2_7
along with a couple of other appendices on writing network drivers.
We've updated the io-pkt documentation since that original document and include it as part of the 6.6.0 documentation:
http://www.qnx.com/developers/docs/660/index.jsp?topic=%2Fcom.qnx.doc.core_networking.user_guide%2Ftopic%2Fabout.html&cp
=3_0_2
"Writing Network Drivers for io-pkt" is the updated version and there is also a link to the sample code there as well.
