Forum Topic - "Dummy phy" for direct to Marvell switch?:
Is there a way to create a "dummy PHY" for an MII-to-MII connection that goes directly to the switch? The switch is a
Marvell 88E6717. We understand there are ways to revamp a device driver to work around the problem, but it would be nice
 if there was an easier way.
In my searches, I found the command line option "emu_phy" for one device driver. However there was no documentation
describing it.
This is with an IMX6, derived from a SabreLite board.
Thanks!
Re: "Dummy phy" for direct to Marvell switch?
I have attached the source code for the emu_phy routines. All you have to
do is to point your mii_read() function to point to the emu_phy_read()
function and call the emu_phy_init() function when the driver starts. The
mii_write() function does nothing.
>goes directly to the switch? The switch is a Marvell 88E6717. We
>problem, but it would be nice if there was an easier way.
>driver. However there was no documentation describing it.
>Thanks!
>Networking Drivers
>http://community.qnx.com/sf/go/post111320
Attachment: Text emu_phy.c 4.97 KB
