Get a Alloc Mem error in e1000
03/26/2014 5:34 PM
post109622
So I have an e1000 device (single port) on one PCI bus and another 4 port 82580 chip on another PCI bus. The startup
enumeration finds 3 of the 4 ports. The last port fails with the following error:
Mar 26 15:42:09 2 17 0 addup_resources: Alloc mem failed
Mar 26 15:42:09 2 10 0 pci_attach_device failed
Anyone have ideas why this would happen? It does not appear to have any reason to occur. Put the same card in a PC and
the hardware *is* working.
Thanks.
Re: Get a Alloc Mem error in e1000
03/27/2014 7:41 AM
post109628
Please can you post the full sloginfo output as well as the Œpci -v¹
output.
>82580 chip on another PCI bus. The startup enumeration finds 3 of the 4
>reason to occur. Put the same card in a PC and the hardware *is* working.
>Thanks.
>Networking Drivers
>http://community.qnx.com/sf/go/post109622
03/27/2014 9:15 AM
post109631
Hugh:
The log is pretty long so I posted a file to the attachments. The snippet from the last post was actually a partial
sloginfo dump rather than a pci-v output.
Thanks for looking.
Ray
03/27/2014 9:21 AM
post109633
Ray,
You didn¹t post the Œpci -v¹ output.
Thanks, Hugh.
On 2014/3/27, 9:15 AM, "Ray Mack" <community-noreply@qnx.com> wrote:
>Hugh:
>snippet from the last post was actually a partial sloginfo dump rather
>Thanks for looking.
>Ray
>Networking Drivers
>http://community.qnx.com/sf/go/post109631
03/27/2014 9:29 AM
post109634
Oops. Too early and not enough coffee yet :-)
Attached now
Thanks.
03/27/2014 10:18 AM
post109635
Please will you run the attached pci-bios-v2 and see if it resolves the
problem. If not, please send me the sloginfo and Œpci -v¹ output again.
>Attached now
>Thanks.
>Networking Drivers
>http://community.qnx.com/sf/go/post109634
03/27/2014 11:21 AM
post109642
Here is the result of running the utility you sent:
# pci-bios-v2
unknown symbol: hwi_off2tag
unknown symbol: hwi_find_item
unknown symbol: __hwi_find_string
ldd:FATAL: Could not resolve all symbols
It was not clear to me if you intended me to run this from the command line or if this file is supposed to replace the
file /sbin/pci-bios for use during the system init process. I just ran it from the command line. Good guess that I am
running an x86 system.
New sloginfo file attached. Turns out you can only attach one file at a time. Also includes pci -v results
03/27/2014 11:23 AM
post109643
Are you running 6.5.0 SP1?
># pci-bios-v2
>line or if this file is supposed to replace the file /sbin/pci-bios for
> Good guess that I am running an x86 system.
>Networking Drivers
>http://community.qnx.com/sf/go/post109642
03/27/2014 11:25 AM
post109644
03/27/2014 11:27 AM
post109645
OK, I¹ll have to setup a 6.5.0 system and build you a new pci-bios-v2. It
will take a while, as I¹m busy right now.
On 2014/3/27, 11:25 AM, "Ray Mack" <community-noreply@qnx.com> wrote:
>Yes to 6.5.0. No to SP1
>Networking Drivers
>http://community.qnx.com/sf/go/post109644
03/27/2014 12:35 PM
post109646
Here is a 6.5.0 version of pci-bios-v2. Please rebuild your boot image
with this version and reboot your system.
Thanks, Hugh.
>Networking Drivers
03/28/2014 2:40 PM
post109680
Hugh:
Our O/S build guy did the new build and I tested this morning. We still see the Alloc Mem error on PCI when it goes to
add that 5th ethernet port.
The sloginfo and pci -v output look just as they did before. The hardware is certainly visible since we see all 4 PCI
index values for the IC.
Can you give some insight into what is different in the v2 bios image you sent?
Thanks.
Ray
03/28/2014 2:45 PM
post109683
The pci-bios-v2 that I sent you contains a fix to not allocate memory
above 0xfe000000, as this is the area for the APIC.
I will still need the Œpci -v¹ output together with the sloginfo output to
compare it with the last one.
Thanks, Hugh.
On 2014/3/28, 2:40 PM, "Ray Mack" <community-noreply@qnx.com> wrote:
>Hugh:
>see the Alloc Mem error on PCI when it goes to add that 5th ethernet port.
>hardware is certainly visible since we see all 4 PCI index values for the
>IC.
>sent?
>Thanks.
>Ray
>Networking Drivers
>http://community.qnx.com/sf/go/post109680
03/28/2014 2:53 PM
post109684
Here is the latest log and pci -v output
Is there some change you need me to make in the log level to give more details on the error?
I'll try setting it to verbose=3 while you peruse this data to see if anything jumps out.
Ray
03/28/2014 2:59 PM
post109685
What I really need you to do is to create a larger slog buffer, so that
you can capture all of the output. ¹slogger -s256k¹ should do the trick.
Looking at the output that you sent me, it still looks as though the old
pci-bios-v2 is running.
>anything jumps out.
>Ray
>Networking Drivers
>http://community.qnx.com/sf/go/post109684
03/28/2014 3:36 PM
post109686
I agree that it looks suspiciously like the original from March 26. I have to get with the old timers and figure out
where to go next with the build, etc. I am the new kid in town. I need to understand this in any event, so it may be
Tuesday before I get back to you.
04/04/2014 12:01 PM
post109800
Hugh:
I spent the past week getting my brain around all things QNX especially getting the BIOS built and loaded on our system.
Here is an update on where I am in the process:
Our BSP is based on the Cinnamon Bay board from ADI. I have the PCI BIOS src from that distribution. I can build and
make changes now (more or less).
I am running into configuration issues where changes are not being picked up by the build system. I am making changes
to server.c in the PCI bios directory and they are not being included into the IPL image. I can tell because the
datestamp of pci-adi (our equivalent of pci-bios if I understand correctly) is not changing. I have tried to force a
change by doing a clean and build and I *still* do not pick up the changes.
Here is the text from the man page for pci-bios and pci-bios-v2
If you're using pci-bios-v2, you must name it pci-bios in order for the enumerators to work correctly. In your
buildfile, add pci-bios-v2 like this:
pci-bios=pci-bios-v2
This is terribly un-useful for someone who is not a build file expert. I presume this is an indication that I should
change fastboot.sd.build to pick up either my changes or the file that you sent me a week ago. What is not clear is *
which* part of fastboot.sd.build I should place that configuration line.
I have gone so far as to delete pci-adi in both the "x86/o" directory and in the "install" directory without picking up
changes I have made to server.c. I have been trying to increase the verbosity of the PCI server so we can see where the
allocation problem is arising but without success.
I *was* able to get the slogger size increased to 256k by editing fastboot.sd.build.
Looking for insight into how to get the file you sent installed or how to do debugging in server.c (printfs or slog
would be nice)
Thanks.
Ray
04/04/2014 1:44 PM
post109803
Ray,
If you place the pci-bios-v2 that I sent you in a temporary directory (eg.
/tmp) and then change the pci-bios line in your build file to read
³pci-bios=/tmp/pci-bios-v2², then when you rebuild your boot image, it
should pick up my pci-bios-v2.
You can change the verbosity of the pci-bios in your build file by adding
the following lines after the procmgr_symlink line:
slogger -s256k
pci-bios -vvv
waitfor /dev/pci
After you have rebuilt your boot image and rebooted the target, you should
have all the verbose output in sloginfo.
Hugh.
On 2014/4/4, 12:01 PM, "Ray Mack" <community-noreply@qnx.com> wrote:
>Hugh:
>getting the BIOS built and loaded on our system. Here is an update on
>src from that distribution. I can build and make changes now (more or
>less).
>up by the build system. I am making changes to server.c in the PCI bios
>because the datestamp of pci-adi (our equivalent of pci-bios if I
>understand correctly) is not changing. I have tried to force a change by
>enumerators to work correctly. In your buildfile, add pci-bios-v2 like
>this:
>presume this is an indication that I should change fastboot.sd.build to
>is not clear is *which* part of fastboot.sd.build I should place that
>configuration line.
>in the "install" directory without picking up changes I have made to
>so we can see where the allocation problem is arising but without
>success.
>fastboot.sd.build.
>do debugging in server.c (printfs or slog would be nice)
>Thanks.
>Ray
>Networking Drivers
>http://community.qnx.com/sf/go/post109800
04/07/2014 4:46 PM
post109833
Hugh:
I finally sorted out all of my tool issues. A lot of newbie mistakes...
I finally got the pci bios you sent installed but it does not start up correctly in our system. It does not play well
with the rest of the system. The sloginfo output is really short:
# sloginfo
Time Sev Major Minor Args
Apr 07 20:43:00 6 17 0 pci_dll_load
Apr 07 20:43:00 2 17 0 pci-bios: No BIOS present - Status 0xffffffff - errno 14!
Apr 07 20:43:00 2 17 0 pci-bios: HWI failed!
Apr 07 20:43:00 2 17 0 pci_server: No dll loaded!
Apr 07 20:43:10 2 19 1800 devb-mmcsd 1.00A (Apr 7 2014 14:03:47)
Apr 07 20:43:10 2 5 0 libcam.so (Jul 9 2010 13:53:08) bver 6040207
Apr 07 20:43:10 2 19 1800 sdhci_init: pci_attach failed
I got our pci bios as delivered as part of our Cinnamon Bay BSP to work and give us some useful verbose information. I
have attached a combination file of sloginfo and pci -v. Look around line 908 for what happens when the software sees
Since I actually have source that I can recompile, any suggestions on changes I can make to increase debug information
is doable now.
Does anything in the latest sloginfo point out an issue with memory allocation?
Thanks.
Ray
04/08/2014 1:39 PM
post109856
Well there is something really wrong here if it cannot even find the BIOS.
The first thing that the PCI server does is to look for the BIOS and if it
cannot find it, it puts out the message you see in sloginfo.
On 2014/4/7, 4:46 PM, "Ray Mack" <community-noreply@qnx.com> wrote:
>Hugh:
>correctly in our system. It does not play well with the rest of the
># sloginfo
>6040207
>and give us some useful verbose information. I have attached a
>happens when the software sees that 5th ethernet port.
>changes I can make to increase debug information is doable now.
>allocation?
>Thanks.
>Ray
>Networking Drivers
>http://community.qnx.com/sf/go/post109833
04/08/2014 3:47 PM
post109859
I must have taken too long to compose my last message and it disappeared when I did save :-(
Is there a more interactive way to do this rather than clogging up the forum with a million messages?
I looked through server.c and did an fgrep on BIOS in my BSP tree. I suspect that maybe the file you sent was for a "
regular" BIOS and we are doing fastboot. Is that a possible source of the the problem? We are using version 6.4.1
Cinnamon Bay BIOS so we may be behind the version that is shipping with QNX version 6.5.0, but just guessing at that. I
did not find "BIOS" or "pci_dll_load" in a slog message in my version of server.c.
Is it possible to send just the few lines of code that you changed in server.c (guessing it was that small a change) and
the original lines so I can compare and do the changes in our local copy?
Thanks.
04/08/2014 4:43 PM
post109862
I suspect this points to the issue (from the file pinfo.mk):
define PINFO
PINFO DESCRIPTION=Intel 854 non-BIOS PCI server
endef
But then again, I have been confused by the variations in this project before.
04/14/2014 6:17 PM
post109915
I finally understand what is happening. I am not sure how to resolve it.
So, the PCI server allocates a block of memory for all busses from 0xff900000 to 0xffdfffff. There are a number of
devices that are on Bus 1 that start allocating that memory in fairly small chunks starting at 0xffdfffff and working
down.
Next the 82574 driver grabs 0x24000 in memory starting at 0xff900000. It grabs a full 1 MB of memory even though it
only needs a little more than 128kB. Both requests are given an alignment value of 0x80000.
Then the driver for the Intel 82580 in e1000 starts grabbing memory. It grabs two buffers for each ethernet port in the
52850. the first is 0x80000 bytes and the second is 0x4000. The problem is that for some reason *both* allocation
requests are given an alignment value of 0x80000. That means we only need 16kB for that small buffer but we chew up an
entire 1 MB of memory for the two buffers.
By the time it allocates buffers for the first 4 ethernet ports, we have chewed up 4 MB of memory when the devices
arguably only need 2 MB plus another 64 kB.
Now that 5th ethernet port comes along and *should* be able to grab 1/2 MB for its big buffer at 0xffd00000 and another
16 kB at 0xffd80000 for its small buffer. However, since the request sets a 0x80000 alignment, the request fails.
So, is there some reason that the e1000 driver needs to have those memory buffers on 1 MB boundaries? Is there memory
available at 0xff800000 that would give us the space we need for one more buffer?
Thanks.
04/23/2014 1:10 PM
post110003
The PCI server determines the size of the memory/I/O aperture by writing
all F¹s to the register and then reading it back. You can see the size of
the apertures by starting the PCI server with Œ-vvv¹ and looking at the
sloginfo output. There you should see something like ³MEM 0xffc00000
0x80000². This is where the PCI server has determined the size of the
aperture. You could maybe expand the find_all() function in the PCI server
to dump the base address registers to see what the BIOS assigns to them.
>0xff900000 to 0xffdfffff. There are a number of devices that are on Bus
>0xffdfffff and working down.
>grabs a full 1 MB of memory even though it only needs a little more than
>grabs two buffers for each ethernet port in the 52850. the first is
>reason *both* allocation requests are given an alignment value of
>up an entire 1 MB of memory for the two buffers.
>chewed up 4 MB of memory when the devices arguably only need 2 MB plus
>another 64 kB.
>MB for its big buffer at 0xffd00000 and another 16 kB at 0xffd80000 for
>the request fails.
>buffers on 1 MB boundaries? Is there memory available at 0xff800000 that
>Thanks.
>Networking Drivers
>http://community.qnx.com/sf/go/post109915
04/23/2014 4:19 PM
post110008
A quick test to see why my posts are not making it to the forum. I have tried at least 5 messages recently that have
not made it to the forum.
I know what is happening just not why. devb-mmcsd is starting libcam.so which gets 0x100 bytes from ethernet memory and
cam-disk.so is getting allocated 0x400 bytes from ethernet memory.
If this post works, I'll try again with appropriate information.
04/23/2014 4:26 PM
post110010
OK, that post finally got through.
Please look at the attached sloginfo dump. I highlighted where things are "interesting". Set your Word or Wordpad to
landscape and A3 paper so you can see the long lines. Also turn on display of line numbers.
PCI finds Bus0 and reserves 0x80000000 to 0xffe00000 at line 5.
Pci goes out and finds the 82547 on Bus0/Bus1 and discovers it needs 0x24000 bytes. Then it finds the 4 units of the
82580 on Bus0/Bus2. It adds up all the needed memory and discovers it needs 5 MB of total memory for ethernet
controllers. it reserves the memory from 0xff900000 to 0xffe00000 at line 268 for Bus0/Bus1 and Bus0/Bus2.
At line 316 devb-mmcsd starts. libcam.so gets its 0x100 bytes from the ethernet section starting at 0xffdfff00 rather
than somewhere that is correct. Then cam-disk.so gets its 0x400 bytes starting at 0xffdff800 rahter than where it
should.
So why does the memory manager grab memory from the ethernet area when it is specifically reserved for Bus0/Bus1 and
Bus0/Bus2?
04/24/2014 7:40 AM
post110024
I¹ll take a look at this as soon as I get a chance.
Hugh.
>are "interesting". Set your Word or Wordpad to landscape and A3 paper so
>0x24000 bytes. Then it finds the 4 units of the 82580 on Bus0/Bus2. It
>for ethernet controllers. it reserves the memory from 0xff900000 to
>ethernet section starting at 0xffdfff00 rather than somewhere that is
>rahter than where it should.
>is specifically reserved for Bus0/Bus1 and Bus0/Bus2?
>Networking Drivers
>http://community.qnx.com/sf/go/post110010
04/25/2014 11:12 AM
post110051
Please try the attached pci-bios-v2 and let me know if it solves your
problem.
Thanks, Hugh.
>Networking Drivers
04/28/2014 5:47 PM
post110074
Hugh:
I suspect I will not be successful with this file. You may recall that we are using the fastboot method, so we do not
have an actual BIOS installed.
I will try it and get a response back.
Ray
04/28/2014 6:18 PM
post110075
I get the same "No BIOS present ...." error that I got before.
What was changed in this file? Are there changes I can make to server.c in the pci-adi directorythat should resolve the
issue?
04/29/2014 7:22 AM
post110077
In the pci_alloc_resource function in the server.c code, there is a line
commented out (rreq.flags |= RSRCDBMGR_FLAG_RANGE). Un-comment this line
and comment out the previous line.
>in the pci-adi directorythat should resolve the issue?
>Networking Drivers
>http://community.qnx.com/sf/go/post110075
04/29/2014 3:21 PM
post110081
Hugh:
That was the magic to solve that issue. Many thanks!!!!!!!
It is now doing the memory allocation on other strange boundaries and still failing on the last ethernet port. It has
something to do with the rreq structure that gets filled in. The first port get 0xff900000 0xff923ffff. the next 3 get
memory from 0xffa00000 up to 0xffcfffff. Somehow the top of the memory pool gets changed from 0xffdfffff to 0xffcfffff.
I'll do some more troubleshooting. I hope I can figure it out on my own.
Ray
04/30/2014 5:40 PM
post110104
I think we are really really close on nailing this issue. I have been reverse engineering as much of the PCI server as
I can.
The problem appears to be in the PCI DLL at this point and appears to be an issue with PCI devices that have multiple
units.
The problem has its source at these lines in pci_alloc_resource:
if (BaseReg->Flags & PCI_MEM_PREFETCH) {
(*pci_drivers->entry->map_addr) (ll_handle, busmap->prefetch_mem_start, &rreq.start, PCI_MEM_SPACE |
PCI_MAP_ADDR_CPU);
(*pci_drivers->entry->map_addr) (ll_handle, busmap->prefetch_mem_end, &rreq.end, PCI_MEM_SPACE | PCI_MAP_ADDR_CPU);
else {
(*pci_drivers->entry->map_addr) (ll_handle, busmap->mem_start, &rreq.start, PCI_MEM_SPACE | PCI_MAP_ADDR_CPU);
(*pci_drivers->entry->map_addr) (ll_handle, busmap->mem_end, &rreq.end, PCI_MEM_SPACE | PCI_MAP_ADDR_CPU);
printf("pci_alloc_resource: PCI memory driver start: %llx end: %llx\n", rreq.start, rreq.end);
The rreq.end value is off by 1 MB. Here is the console output from my printf:
PCI_attach_device vendor 0x8086 - device 0x150e
PCI_attach_device device Bus mem start 0 device Bus mem end 0
pci_alloc_resource Base register: 8047a20 alignment: 80000 bus: 2
Base Reg length: 84000 flags: 0
pci_alloc_resource: PCI memory driver start: ff200000 end: ff4fffff
Memory Request Start 0xff200000 - End 0xff4fffff - Size = 0x84000 - Name pcimemory/Bus0/Bus2
rsrcdbmgr_attach result: 0 EOK: 0
pci_alloc_resource Address = 0xff200000 - End 0xff283fff
pci_alloc_resource New BaseReg Address ff200000
PCI_attach_device complete
You can see that the DLL has given me only 3 MB rather than the full 4 MB required.
I am not sure how to proceed because I do not have code for the PCI DLL or the DLL map_addr() function.
Also, I think there might be an issue with the line where the BaseReg -> Address is updated at the end of
pci_alloc_resource:
if (verbose > 2)
pci_slogf (_SLOGC_PCI, _SLOG_INFO, "Address = 0x%llx - End 0x%llx", rreq.start, rreq.end);
printf("pci_alloc_resource Address = 0x%llx - End 0x%llx\n", rreq.start, rreq.end);
BaseReg->Address |= rreq.start; //Or address with flags
printf("pci_alloc_resource New BaseReg Address %x\n\n", BaseReg->Address);
return (PCI_SUCCESS);
As you can see, the comment does not match up with what is actually happening. It appears that this needs to act
differently if we are allocating bottom up vs. top down. My guess is that this value is supposed to be at the end of
what we are allocating. The line is correct as-is for top down because the lowest address is at the edge of the pool.
For bottom up it appears the line should say BaseReg->Address |= (rreq.end + 1); but I could be wrong on what is
intended.
05/05/2014 2:03 PM
post110150
The DLL code is in bios-v2.c and is statically linked with server.c. At
the top of the file you will see a list of entry points.
>reverse engineering as much of the PCI server as I can.
>an issue with PCI devices that have multiple units.
>PCI_MAP_ADDR_CPU);
> else {
>printf:
>pcimemory/Bus0/Bus2
>required.
>Address is updated at the end of pci_alloc_resource:
> if (verbose > 2)
>BaseReg->Address);
>happening. It appears that this needs to act differently if we are
>supposed to be at the end of what we are allocating. The line is correct
>(rreq.end + 1); but I could be wrong on what is intended.
>Networking Drivers
>http://community.qnx.com/sf/go/post110104
05/05/2014 2:25 PM
post110151
Awesome!!!! Just knowing where to look is 90% of the task.
Thank you so much.
11/05/2014 10:15 AM
post112278
I have finally gotten the PCI/E1000 combination to work. The problem is that the scan_windows() function fills in the
bus map database with just the amount of memory needed to handle an ethernet NIC. The later addup_resources() call when
you actually attach the ethernet controller to the PCI bus forces the allocations on 1MB boundaries. The code is very
upfront about requiring the 1MB calculations. The solution is for the scan_windows() function to force all size
calculations to round up to the nearest 1MB.
Portion of code from server.c below:
if (verbose)
pci_slogf (_SLOGC_PCI, _SLOG_INFO, "MEM 0x%llx 0x%llx %s", PCI_MEM_ADDR (addr64), size, addr64 & 0x08 ? "pref" : "")
BaseReg->Address = device_enabled ? addr64 : (addr64 &= 0x0f);
if (! device_enabled) {
PCI_write_config32 (bus, devfn, Offset, 1, (char *)&addr64);
if (reg_64) {
addr64 >>= 32;
PCI_write_config32 (bus, devfn, Offset + 4, 1, (char *)&addr64);
else {
uint64_t Address;
(*pci_drivers->entry->map_addr) (ll_handle, addr64, &Address, (uint32_t) BaseReg->Flags | PCI_MAP_ADDR_CPU);
original_size = size;
if ((size % 0x100000) > 0)
size += 0x100000;
size &= 0xfff00000;
if (alloc_resource (PCI_MEM_ADDR (Address), (uint32_t) size, RSRCDBMGR_PCI_MEMORY, bus,
(BaseReg->Flags & PCI_MEM_PREFETCH) ? 1 : 0)) {
pci_slogf (_SLOGC_PCI, _SLOG_ERROR, "%s: Alloc failed 0x%llx - Size 0x%llx",
__FUNCTION__, Address, size);
// BaseReg->Address = 0;
// BaseReg->Flags &= ~PCI_DEVICE_ENABLED;
// dword = 0;
// PCI_write_config32 (bus, devfn, Offset, 1, (char *)&dword);
// else {
BaseReg->Address = Address;
BaseReg->Flags |= PCI_DEVICE_ENABLED;
