Forum Topic - Issue with Ethernet chipset SiS984L / QNX6 SP3:
It seems the Ethernet driver devn-sis9.so under QNX 6.3 (service pack 3) did not work properly with Ethernet chipset
SiS 964L SouthBridge.
(Silicon Integrated Systems Corp.)
I can ping from the QNX to any host and also from any host to my QNX but when the ftp, telnet, phindows, voyager started
, the IP traffic is stuck and the sloginfo displays the message "MORE bit to clear".
Please help. Thank you
Trong
RE: Issue with Ethernet chipset SiS984L / QNX6 SP3
You can try the attached experimental version of the driver.
Sent: Wednesday, April 23, 2008 10:50 AM
To: drivers-networking
Subject: Issue with Ethernet chipset SiS984L / QNX6 SP3
not work properly with Ethernet chipset  SiS 964L SouthBridge.
when the ftp, telnet, phindows, voyager started, the IP traffic is stuck and
Trong
Networking Drivers
http://community.qnx.com/sf/go/post7209
Attachment: Text devn-sis9.so 49.35 KB
Re: RE: Issue with Ethernet chipset SiS984L / QNX6 SP3
Thanks Hugh,
The driver is working with ping/telnet/ftp/voyager, but sometimes, inthe first connection from the other host by telnet
/ phindows, it takes ~30 seconds to get a prompt login (telnet)  OR to get in by Phindows.
I have the  devc-speedo chipset under QNX 6 SP3  and have never seen
the handshaking time so long like this.
Again, it happened sometines.
Do I need to start the logger to see what's happened ?
An other question:
When connected  USB Keyboard and USB Mouse to the USB slot, after a while, the keyboard or mouse will not be replied. It
 is frozen. Do you have another solution of io-net or  devb-umass ?
Thanks for helping
Trong
RE: RE: Issue with Ethernet chipset SiS984L / QNX6 SP3
I put a Sis9 adapter in my PC, ran the driver and telnet'd into the machine
without any problem. Maybe this has something to do with the version of the
chip that you have, but without the hardware, there is not much that I can
do.
Sent: Thursday, April 24, 2008 1:51 PM
Subject: Re: RE: Issue with Ethernet chipset SiS984L / QNX6 SP3
Thanks Hugh,
first connection from the other host by telnet / phindows, it takes ~30
An other question:
the keyboard or mouse will not be replied. It is frozen. Do you have another
Thanks for helping
Trong
Networking Drivers
http://community.qnx.com/sf/go/post7265
Re: RE: RE: Issue with Ethernet chipset SiS984L / QNX6 SP3
Hugh,
Sorry for taking a while to back this question.
I did the FTP tranfering a file from my PC 172.27.18.166 to the machine QNX6.3 (Having chipset SiS984L) 172.27.18.130
I used the freeware WireShrak analyser to log the data
It appears that have the RE-TRANSMISSION from my PC and the driver
devn-sis9.so (the beta driver that you gave me) return the duplicate ACK.
The driver is working OK, accept too long for transfering the file.
Can you please have a look in the log file  A5.pcap attached
Thank you for your help
Trong
Attachment: Text A5.pcap 1.3 MB
RE: RE: RE: Issue with Ethernet chipset SiS984L / QNX6 SP3
I'll have to try this again and see if I can reproduce the problem.
Sent: Thursday, June 12, 2008 4:19 PM
Subject: Re: RE: RE: Issue with Ethernet chipset SiS984L / QNX6 SP3
Hugh,
ACK.
Trong
Networking Drivers
http://community.qnx.com/sf/go/post9066
Once again I have tried this out without any problems. As I don't have
the same hardware as you, I am unable to reproduce this problem.
Hugh,
ACK.
Trong
Networking Drivers
Re: RE: RE: RE: Issue with Ethernet chipset SiS984L / QNX6 SP3
Thanks Hugh,
I will install window and see the chipset can work correctly.
Otherwise, we will contact QNX for supporting.
Trong
> From: Trong Nguyen [mailto:nguyen_trong@cat.com]
> Hugh,
> ACK.
> Trong
> Networking Drivers
