ethernet over USB (NCM device)
03/18/2014 1:06 PM
post109480
i updated my sabrelite to QNX 6.6
in the new build file, i uncommented the example of NCM device (ethernet over USB)
##### Example of NCM device (Ethernet over USB) #####
# Step 1 - Start USB device stack
io-usb-dcd -dusbncm-mx6sabrelite-ci ioport=0x02184000,irq=75
waitfor /dev/io-usb-dcd/io-usb 4
waitfor /dev/io-usb-dcd/devu-usbncm-mx6sabrelite-ci.so 4
# Step 2 - Start USB NCM function driver
# For best performance attach the usbdnet driver to an existing io-pkt stack. Alternatively multiple
# io-pkt stacks can be used (see SDP documentation for more details).
mount -Tio-pkt -o mac=123456789abc,protocol=ncm devnp-usbdnet.so
ulink_ctrl -l1
# Step 3 - Assign IP address to ncm interface using DHCP OR any static IP.
if_up -p ncm0
ifconfig ncm0 192.168.10.100
all steps are Ok, and a ncm0 is created with the right IP address.
My issue is when i connect the USB cable to my windows 7 computer, i got the message there is no windows driver
available for"QNX NCM Network device".
Is there any windows driver available ?
