04/17/2008 10:15 AM
post6973
is there a driver for Marvell GigaBit Ehternet PCI-Express adapter?
VendorID: 11abh, DeviceID: 4362h, 88E8053?
This chip seems quite common as a Gigabit Ethernet. Found it on three evaluated CoreDuo systems.
thanks,
steve
RE: Marvell 88E8053 driver
04/17/2008 10:21 AM
post6975
We cannot get docs from Marvell, so don't support their chipsets.
Sent: Thursday, April 17, 2008 10:16 AM
To: drivers-networking
Subject: Marvell 88E8053 driver
thanks,
steve
Networking Drivers
http://community.qnx.com/sf/go/post6973
04/17/2008 11:42 AM
post6993
While we don't have a version for io-net, the Core Networking project has
ported the MSK NetBSD driver (devnp-msk.so) which should work with that
chipset.
Robert.
thanks,
steve
Networking Drivers
Re: RE: Marvell 88E8053 driver
06/11/2008 3:31 PM
post9025
Hello Craig,
thanks for your help here is my success story:
(- installed my target with a high end runtimekit)
- downloaded Core Networking Milestone 1 build.zip
- unzipped the file under Windows and got a file named patch-630SP3-CE-CN-Milestone-1.tar.gz
- transfered this file to my target with a usb stick to /home
- this target has 2 Marvell GBit Lans
on my target:
- logged in as root
- opened a terminal
- ran the commands as mentioned in the wiki/faq:
gzip -d patch-630SP3-CE-CN-Milestone-1.tar.gz
tar -xvf patch-630SP3-CE-CN-Milestone-1.tar
- copied the extracted files under....../x86 to the same locations seem from root (meaning ....../x86/sbin -> /sbin, ...
.../x86/lib -> /lib and so on)
( -> I did not need to change LD_LIBRARY_PATH, a reboot was enough)
- rebooted system
- opened terminal
- slay io-net
- io-pkt-v6-hc -d msk -tcpip
- dhcp.client&
- ifconfig
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
msk0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
address: 00:10:f3:14:73:ea
media: Ethernet autoselect (100baseTX full-duplex,flowcontrol,rxpause,tx
pause)
status: active
inet 192.168.2.200 netmask 0xffffff00 broadcast 192.168.2.255
inet6 fe80::210:f3ff:fe14:73ea%msk0 prefixlen 64 scopeid 0x2
msk1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
address: 00:10:f3:14:73:eb
media: Ethernet autoselect (none)
status: no carrier
inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255
inet6 fe80::210:f3ff:fe14:73eb%msk1 prefixlen 64 scopeid 0x3
- qconn&
-> after setting up a new target on my MomenticsIDE I had a connection
- changed inetd.conf to open phrelay and all telnet ports
- inetd&
-> telnet connection from my windows PC working
-> phindows connection from my windows PC working
Tomorrow I will try to find out how to change the startup scripts to replace io-net on this box.
Thanks a lot,
steve
PS: only thing to complain: ifconfig is saying msk0: msk1: instead of wm0: wm1: as the faq says
RE: RE: Marvell 88E8053 driver
06/11/2008 4:01 PM
post9027
Hi Stefan:
Glad to hear that the driver is working for you! With regards to
the driver naming, the name used is dependent upon the driver, so the
i82544 driver gives you a wm interface, the BGE driver gives you a bge
interface and the msk interface gives you an msk interface. I've
updated the Wiki FAQ to be more explicit.
In terms of the installation, if you copy the files into the appropriate
system directories as you did, you don't have to update the
LD_LIBRARY_PATH since the system directories are already in the path.
If you want to have your system automatically start up and mount the
driver, the "best" way to do this is to modify the enumerator
configuration files under etc/system/enum.
You have to change the include/net file to start io-pkt-v4 instead of
io-net and you have to add the appropriate device / vendor id
information into devices/net to get it to mount the msk driver.
Robert.
Sent: Wednesday, June 11, 2008 3:32 PM
Subject: Re: RE: Marvell 88E8053 driver
Hello Craig,
on my target:
- logged in as root
- opened a terminal
from root (meaning ....../x86/sbin -> /sbin, ....../x86/lib -> /lib and
so on)
- rebooted system
- opened terminal
- slay io-net
- dhcp.client&
- ifconfig
pause)
status: active
status: no carrier
- qconn&
- inetd&
Thanks a lot,
steve
Networking Drivers
http://community.qnx.com/sf/go/post9025
Re: RE: RE: Marvell 88E8053 driver
06/12/2008 1:11 PM
post9059
Hi Craig,
give me a hint what to replace exactly in the enum area to get it started during boot up
I added to /etc/system/enum/include/pci-vendors a line:
set(PCI_VEND_MARVELL,4362)
I copied and modifyed a section in /etc/system/enum/devices/net :
#Marvell
device( pci, ven=$(PCI_VEND_MARVELL),dev=11ab
tag(devn)
append(legacy, ",nonet")
requires($IONET_CMD),)
uniq(netnum,devn-en, 0)
mount(-Tiopkt-v6-hc "-opci=$(index),vid=0x$(ven),did=0x$(dev)" /lib/dll/devn-msk.so, "/dev/io-net/en$(netnum)")
use(symbolic=netmgr)
-> result: didn't work
after some looking around I found the $IONET_CMD in
/etc/system/enum/include/net which was still pointing to io-net.
and I found /etc/system/enum/overrides where I set the following
all
set(IONET_CMD, io-pkt-v6-hc -tcpip)
tried again on the command line with
-> result: works
How do I set the Marvell section to add this "-d msk" thing?
stefan
RE: RE: RE: Marvell 88E8053 driver
06/12/2008 2:01 PM
post9061
Hi Stefan:
Change the include/net file:
set(INET_CMD, io-pkt-v4-hc -ptcpip)
Add to the devices net file
device( pci, ven=$(PCI_VEND_MARVELL),dev=11ab)
mount(-Tio-pkt /lib/dll/devnp-msk.so,)
I THINK that'll do it.
Robert.
Sent: Thursday, June 12, 2008 1:11 PM
Subject: Re: RE: RE: Marvell 88E8053 driver
Hi Craig,
#Marvell
tag(devn)
all
-> result: works
stefan
Networking Drivers
http://community.qnx.com/sf/go/post9059
Antwort: RE: RE: RE: Marvell 88E8053 driver
06/16/2008 11:49 AM
post9199
Unfortunatly it does not work:
mount: Can't mount / (type io-pkt-v4-hc)
mount: Possible reason: Invalid argument
maybe we should create a new issue on this one because the original
problem with the Marvell driver is solved
Stefan
Stefan Thiel
Electronic Engineering
Multitest elektronische Systeme GmbH
Äussere Oberaustrasse 4
D-83026 Rosenheim
s.thiel@multitest.com
Tel.: 08031406-464
Web: www.multitest.com
Geschaeftsfuehrer: Dipl.Ing. MBA Karl H. Funke
Registergericht Traunstein - HRB 12453
Robert Craig <rcraig@qnx.com>
12.06.2008 20:01
Bitte antworten an
post9061@community.qnx.com
An
drivers-networking <post9061@community.qnx.com>
Kopie
Thema
Hi Stefan:
Robert.
Hi Craig,
#Marvell
tag(devn)
all
-> result: works
stefan
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post9061
_______________________________________________________________________
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom
they are addressed. If you have received this email in error please
notify the system manager.
This footnote also confirms that this email message has been swept by
MessageLabs (http://www.messagelabs.com) for the presence of computer
viruses.
viruses.
RE: Antwort: RE: RE: RE: Marvell 88E8053 driver
06/16/2008 12:01 PM
post9202
Hi Stefan:
Can you start up a new thread? When you do, include the output from sloginfo after the system comes up. There's
also a typo in the info that I sent
IONET_CMD
Robert.
Sent: Monday, June 16, 2008 11:49 AM
Subject: Antwort: RE: RE: RE: Marvell 88E8053 driver
Stefan
Stefan Thiel
D-83026 Rosenheim
Tel.: 08031406-464
12.06.2008 20:01
Bitte antworten an
An
Kopie
Thema
Hi Stefan:
Robert.
Hi Craig,
#Marvell
tag(devn)
all
-> result: works
stefan
Networking Drivers
Networking Drivers
viruses.
they are addressed. If you have received this email...
