Forum Topic - Atheros Driver - Error recovery request.:
Dear QNX team,
I enabled the EEPROM write functinality in QNX atheros driver and I ported diag/eeprom utility.
It works very well but I found a little problem.
If I chaged the "Target_Power_Start_Location" in atheros register 0xC5 with the value which is incorrect, io-pkt fails
to load atheros driver at the next booting cycle.
Because EEPROM cannot be re-writeen without atheros driver, it could not be recovered.!! ( If I connect this corrupted
wifi module to desktop and run ART.exe program then ART program automaticlly detect that the calibration value is
invalid and fix it to default value(0x0182)
I think, even though the calibration value is invalid, driver should be loaded correctly doesn't it?
Please let me know whether QNX team could fix this issue.
Dooeui
RE: Atheros Driver - Error recovery request.
Hi Dooeui:
	This might be something that we can help you to fix yourselves given
that you have the source to work with.  First thing to check... Make sure
that you have slogger running on the system.  What's the output from
sloginfo?  That should let us know how far along the initialization gets
before the failure.
	Robert.
Sent: Tuesday, April 15, 2008 2:42 AM
To: drivers-networking
Subject: Atheros Driver - Error recovery request.
Dear QNX team,
the value which is incorrect, io-pkt fails to load atheros driver at the
next booting cycle.
recovered.!! ( If I connect this corrupted wifi module to desktop and run
value is invalid and fix it to default value(0x0182)
Dooeui
Networking Drivers
http://community.qnx.com/sf/go/post6770
