Forum Topic - How to tell if ethernet cable is unplugged?:
How do I programmatically detect if the Ethernet cable has been unplugged?  I tried the ioctl SIOCGIFFLAGS command to
look at the IFF_UP and IFF_RUNNING flags, but these are always set.  ifconfig seems to know because when the cable is
plugged in, it displays:
  status: active
Since the source code is nearly impossible to access, I can't see how it knows.  Does anyone know the magic function to
determine this?
Re: How to tell if ethernet cable is unplugged?
IFM_STATUS_DESC(ifms, bit)
in net/if_media.h should do what you need.
And the ioctl you need is SIOCGIFMEDIA.
>    status: active
to determine this?
> Networking Drivers
> http://community.qnx.com/sf/go/post100294
> To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
Thank you sir, this is what I was looking for.
