Re: NetLink BCM5789 network driver under QNX6.3.2?
03/27/2008 7:01 AM
post6187
> Does qnx6.3.2 support the above pci card? only devn-bcm43**.so is available in
> the /lib/dll directory.
> The pci -v output is as follows:
> Class = Network(Ethernet)
> Vendor ID = 14e4h, Broadcom Corporation
> Device ID = 169dh, NetLink BCM5789
> Thank u.
Can you please try:
#sloginfo -c
#slay io-net
io-net -vv -dtigon3 vid=0x14e4,did=0x169d,pci=0,verbose=4 -ptcpip
PCI index = 0h
from pci -v output guessed
ls /dev/io-net
Do You see 'en0' here ?
if yes :
#ifconfig en0 192.168.1.3 //or choose someother suiting ip.
#ping another box.
This above test is just for the first interface.
Can You successfully ping around ?
If not, please do:
#sloginfo > mysloginfo.txt.
Provide mysloginfo.txt here.
Hope this helps.
Jeevan
