intel 82754 network driver problem
12/14/2012 6:00 AM
post98114
I'm using a motherboard with 2 82754 chips. The first run fine, but the second doesn't work.
The driver seems to be devn-e1000.so.
Is there an updated release of this driver ?
Where can I download it ?
Thank you
Paolo
Re: intel 82754 network driver problem
12/14/2012 7:21 AM
post98116
What version of the O/S are you running? Also, please post the output of
'pci -v'.
Thanks.
>Thank you
>Paolo
>Networking Drivers
>http://community.qnx.com/sf/go/post98114
12/14/2012 9:23 AM
post98138
The O/S version is 6.5.0
Here is the output of pci -v :
PCI version = 3.00
Class = Bridge (Host/PCI)
Vendor ID = 8086h, Intel Corporation
Device ID = 104h, Sandy Bridge DRAM Controller
PCI index = 0h
Class Codes = 060000h
Revision ID = 9h
Bus number = 0
Device number = 0
Function num = 0
Status Reg = 2090h
Command Reg = 6h
Latency Timer = 0h
Cache Line Size= 0h
Subsystem Vendor ID = 8086h
Subsystem ID = 104h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = NC
Interrupt line = 0
CPU Interrupt = 0h
Capabilities Pointer = e0h
Capability ID = 9h - Vendor Specific
Capabilities = 10ch - a0806196h
Class = Bridge (PCI/PCI)
Device ID = 101h, Sandy Bridge PCI Express Root Port
PCI index = 0h
Class Codes = 060400h
Revision ID = 9h
Bus number = 0
Device number = 1
Function num = 0
Status Reg = 10h
Command Reg = 7h
Header type = 1h Multi-function
Latency Timer = 0h
Cache Line Size= 10h un-cacheable
Primary Bus Number = 0
Secondary Bus Number = 1
Subordinate Bus Number = 1
Secondary Latency Timer = 0h
I/O Base = f0h
I/O Limit = 0h
Secondary Status = 0h
Memory Base = fff0h
Memory Limit = 0h
Prefetchable Memory Base = fff1h
Prefetchable Memory Limit= 1h
Prefetchable Base Upper 32 Bits = 0h
Prefetchable Limit Upper 32 Bits = 0h
I/O Base Upper 16 Bits = 0h
I/O Limit Upper 16 Bits = 0h
Bridge Control = 10h
PCI Int Pin = INT A
Interrupt line = 11
CPU Interrupt = bh
Capabilities Pointer = 88h
Capability ID = dh - PCI Bridge Subsystem Vendor ID
Capabilities = 0h - 1018086h
Capability ID = 1h - Power Management
Capabilities = c803h - 8h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 0h - 0h
Capability ID = 10h - PCI Express
Capabilities = 142h - 8000h
Device ID = 109h, Sandy Bridge PCI Express Root Port
PCI index = 0h
Revision ID = 9h
Bus number = 0
Device number = 1
Function num = 2
Status Reg = 10h
Command Reg = 7h
Latency Timer = 0h
Secondary Bus Number = 2
Subordinate Bus Number = 2
I/O Base = f0h
I/O Limit = 0h
Memory Base = fff0h
Memory Limit = 0h
PCI Int Pin = INT A
Interrupt line = 11
CPU Interrupt = bh
Capabilities = 0h - 1098086h
Class = Display (VGA)
Device ID = 106h, Sandy Bridge Integrated Graphics Controller
PCI index = 0h
Class Codes = 030000h
Revision ID = 9h
Bus number = 0
Device number = 2
Function num = 0
Status Reg = 90h
Command...
12/14/2012 9:43 AM
post98139
The latest driver and enumeration file can be found here
http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/Experimental
DriversAndUtilities
>PCI version = 3.00
>PCI index = 0h
>Revision ID = 9h
>Bus number = 0
>Device number = 0
>Function num = 0
>Status Reg = 2090h
>Command Reg = 6h
>Latency Timer = 0h
>Cache Line Size= 0h
>Subsystem ID = 104h
>Max Lat = 0ns
>Min Gnt = 0ns
>PCI Int Pin = NC
>Interrupt line = 0
>CPU Interrupt = 0h
>PCI index = 0h
>Revision ID = 9h
>Bus number = 0
>Device number = 1
>Function num = 0
>Status Reg = 10h
>Command Reg = 7h
>Latency Timer = 0h
>I/O Base = f0h
>I/O Limit = 0h
>Memory Base = fff0h
>Memory Limit = 0h
>PCI Int Pin = INT A
>Interrupt line = 11
>CPU Interrupt = bh
>PCI index = 0h
>Revision ID = 9h
>Bus number = 0
>Device number = 1
>Function num = 2
>Status Reg = 10h
>Command Reg = 7h
>Latency Timer = 0h
>I/O Base = f0h
>I/O Limit = 0h
>Memory Base = fff0h
>Memory Limit = 0h
>PCI Int Pin = INT A
>Interrupt line = 11
>CPU Interrupt =...
11/03/2014 1:39 PM
post112240
Hi all,
I have the same problem using a motherboard with 2 Intel 82574L ethernet ports.
I've already downloaded and installed the last devnp-e1000.so driver release (found on the Experimentals linked page)
but it doesn't solve the problem.
Attached to this post you'll find a ZIP archive containing some LOGs, obtained from QNX 6.5.0.
More in details, the ZIP archive contains the following files:
- pci.txt
pci device list (both ethernet are listed)
- ifconfig.txt
"ifconfig" command's output
- net.txt
"/etc/system/enum/include/net" file contents
- routeShow.txt
"route show" command's output (you can see that the address "10.3.2.200" appears associated to the wm0 interface (see
the MAC Address in ifconfig for confirmation), while the address "10.3.2.201" - related to the wm1 interface, is not
listed in the routing table
- pingWM0.txt
"ping 10.3.2.200" command's output
- pingWM1.txt
"ping 10.3.2.201" command's output
Is there a solution for this problem? What can be related to?
11/04/2014 7:38 AM
post112243
The issue you are seeing is because you have configured two interfaces
on the same network within a single instance of io-pkt. Note that each
instance of io-pkt has one routing table and it will discard redundant
routes. In this case the route entry for wm1 is redundant since the
entry for wm0 already points to the network. This is why you see pings
working with wm0 but not wm1. In fact wm1 should be able to receive
incoming packets but will be unable to transmit any since the packets
will be sent of via wm0 (again because of the way the routing table is
setup). This is by design. Normally it is not recommended to configure
two interfaces on the network. You could either use a separate instance
of io-pkt for each interface (which gives each interface its own routing
table) or you might want to look into using a bridge.
On 2014-11-03 01:39 PM, Loris Colasante wrote:
> Hi all,
> - pci.txt
> - ifconfig.txt
> - net.txt
> - routeShow.txt
(see the MAC Address in ifconfig for confirmation), while the address "10.3.2.201" - related to the wm1 interface, is
not listed in the routing table
> - pingWM0.txt
> - pingWM1.txt
> Networking Drivers
> http://community.qnx.com/sf/go/post112240
> To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
11/04/2014 9:26 AM
post112244
First of all thank you for your quick reply. Now it's more clear what this behaviour is related to.
Anyway, because I need to use both interfaces, I'm trying to start 2 different instances of io-pkt but with no success.
I've modified the "etc/system/enum/include/net" file as reported below:
# macro definitions for network
all
set(IOPKT_CMD, io-pkt-v4-hc -i1 unit=0 -ptcpip)
set(IOPKT_CMD, io-pkt-v4-hc -i2 unit=1 -ptcpip)
but in this way the following errors occurs at the startup:
mount: Can't mount / (type io-pkt)
mount: Possible reason: Invalid argument
By specifying only the '-i1' and -i2' option (without 'unit=xx') the same error occurs.
So ,which is the right way to create 2 separate instances of io-pkt, one for each interface 'wm0' and 'wm1', running at
startup?
Could you help me, please?
Thank you in advance
> > Hi all,
> ports.
> (found on the Experimentals linked page) but it doesn't solve the problem.
> > - pci.txt
> > - ifconfig.txt
> > - net.txt
> > - routeShow.txt
> appears associated to the wm0 interface (see the MAC Address in ifconfig for
> is not listed in the routing table
> > - pingWM0.txt
> > - pingWM1.txt
> > Networking Drivers
11/04/2014 9:31 AM
post112245
Not only do you need to identify each instance of io-pkt via -iX you
also need to specify an alternative prefix for each additional instance
of io-pkt otherwise it will overlap the first one causing some problems.
Try:
io-pkt-v4-hc -i1 -ptcpip
io-pkt-v4-hc -i2 -ptcpip prefix=/alt1
io-pkt-v4-hc -i3 -ptcpip prefix=/alt2
Now when you want to access the default instance:
ifconfig
For the second instance you need to use the SOCK environment variable to
tell the socket layer which instance you are "talking" to:
SOCK=/alt1 ifconfig
For the third instance:
SOCK=/alt2 ifconfig
Basically you need to use SOCK to tell any application that uses the
socket layer which tcpip stack to connect with (except for the default
one which in my example was the first one).
> all
at startup?
>>> Hi all,
>> ports.
>>> - pci.txt
>>> - ifconfig.txt
>>> - net.txt
11/04/2014 10:05 AM
post112246
I'm sorry, but there are still some problem:
Attached to this post you'll find my "/etc/system/enum/include/net" file.
Using this file, the following error occurs at startup:
netmanager error: Could not open socket: Address family not supported by protocol family
error creating socket
bad addr or host: <NULL> (No address associated with hostname)
Memory fault
So, the first thing should be to solve this problem, then I'd like to have a way that allow both interfaces -wm0 and
wm1 - to be running without using any specific variables (like suggested SOCK).
Is there a way to do this? Is there a way to "instruct" QNX to add both the wm0 and wm1 interfaces to the routing table
and give them both reacheable (and so, 'pingable')?
In the past, I've tried to install Windows 7 on the same machine and both interfaces was working fine, without doing
nothing special...
I'd like to add some instructions (somewhere in QNX files...) ONLY ONCE in order to have both the interfaces running in
the future, without adding specific code to the applications running on the machine: is that possible?
Thank you.
> Try:
> ifconfig
> SOCK=/alt1 ifconfig
> SOCK=/alt2 ifconfig
> > all
> error occurs.
> each interface 'wm0' and 'wm1', running...
| Attachment: |
net
195 bytes
11/04/2014 10:15 AM
post112247
-i instance
The stack instance number, which is useful if you're running
multiple instances of io-pkt. The io-pkt manager will service mount
requests of type io-pktX, where X is the instance number. For example:
io-pkt-v4 -i1 -ptcpip prefix=/alt
mount -Tio-pkt1 /lib/dll/devnp-i82544.so
This is taken from the io-pkt documentation we have online. You need to
tell 'mount' which instance is going to load the driver.
> Memory fault
table and give them both reacheable (and so, 'pingable')?
nothing special...
in the future, without adding specific code to the applications running on the machine: is that possible?
> Thank you.
>> Try:
>> ifconfig
>> SOCK=/alt1 ifconfig
>> SOCK=/alt2 ifconfig
>>> all
11/04/2014 10:23 AM
post112248
I've already read the io-pkt online documentation but, as I told you before, using the "-i" option it seems to cause an
error mounting io-pkt (please refers to my previous post)
Also, I'm not sure about the right syntax to use inside the 'net' file.
Please, could you send me back a 'net' file with the full right commands? It could be more helpful for me in order to
better understand the commands I have to use and the right syntax.
Thank you in advance (and sorry but I'm not a QNX expert, as you can imagine...)
> -i instance
> protocol family
> protocol family
> > Memory fault
> way that allow both interfaces -wm0 and wm1 - to be running without using
> wm0 and wm1 interfaces to the routing table and give them both reacheable (and
> so, 'pingable')?
> interfaces was working fine, without doing nothing special...
> order to have both the interfaces running in the future, without adding
> > Thank you.
> >> Try:
> >> ifconfig
> >> SOCK=/alt1 ifconfig
> >> SOCK=/alt2 ifconfig
> >> socket layer which tcpip stack to connect with (except for...
11/04/2014 10:28 AM
post112249
# mount -t io-pkt1
The above will mount into the instance that was passed -i1
an error mounting io-pkt (please refers to my previous post)
> > -i instance
> > protocol family
> > protocol family
> > > Memory fault
> > so, 'pingable')?
> > > Thank you.
> > >> Try:
> > >> ifconfig
11/04/2014 10:47 AM
post112250
Well... maybe I'm a bit stupid (or I have a really bad english...) but:
1. Trying to write the "net" file adding what suggested by Gervais Mulongoy (the 'net' file is attached), at the startup
a non-finite list of "Expected token at net(8)" appears (now I'm using a live-CD to recover the file in order to make
QNX runing again)
2. Trying what suggested by Sean Boudreau directly at command prompt, a different error occurs (I'm sorry but at this
moment I don't have the exact description)
In conclusion, by considering that I'm not an expert, if you really want to help me, please give me all the instructions
, step-by-step, or send me a 'net' file containing the right commands.
Otherwise, I think I have no possibility to solve the issue...
Again... thank you in advance
> # mount -t io-pkt1
> using the "-i" option it seems to cause an error mounting io-pkt (please
> could be more helpful for me in order to better understand the commands I
> > > -i instance
> > > protocol family
> > > protocol family
> > > > Memory fault
> have a
> using
> the
> (and
> > > so, 'pingable')?
> > > > In the past,...
11/04/2014 11:06 AM
post112251
Try this from the command line:
1) slay -f io-pkt-v4
2) io-pkt-v4 -i1 -ptcpip prefix=/alt1
3) mount -Tio-pkt1 -opci=0 /lib/dll/devnp-e1000.so
4) SOCK=/alt1 ifconfig
5) io-pkt-v4 -i2 -ptcpip prefix=/alt2
6) mount -Tio-pkt2 -opci=1 /lib/dll/devnp-e1000.so
7) SOCK=/alt2 ifconfig
The ifconfig utility called in step 4 should list lo0 and wm0, the one
called in step 7 should also list lo0 and wm0 but compare the MAC
addresses which should be different. Now take those commands and add
them to your /etc/rc.d/rc.local and remove the entries from your 'net'
file since you are now manually starting the networking stack instead of
leaving it to the enumerator which doesn't understand SOCK (it wasn't
designed for those types of use cases).
11/04/2014 12:07 PM
post112253
Well, thank you for the informations but unfortunately also using these commands the 2nd ethernet doesn't work.
I've added all the commands to the /etc/rc.d/rc.local" file (except the slay command), then:
1. If I simply comment all the lines inside the 'net' file, a lot of errors occurs at the startup
2. If I rename the 'net' file to 'net.old', there are no errors at the startup but trying to ping the wm0 interface (10.
3.2.200) it works fine, while truing to ping the wm1 interface (10.3.2.201) I receive an "Host is down" message.
I don't know... maybe there is still something wrong but it seems to be 'impossible' to have both interfaces working...
it seems there is no way to have 'wm1' working...
11/04/2014 2:12 PM
post112257
It isn't impossible as I have done this myself. You just need to
troubleshoot your setup - try doing this step by step making sure that
you have confirmed behavior before proceeding. First check the output of
pci -v to make sure that the NICs have distinct "PCI Index" values. Then
try each instance on its own - so one at a time. Configure the interface
and make sure it is pingable. Only once you have confirm that both
instances work should you proceed to testing both at the same time.
(10.3.2.200) it works fine, while truing to ping the wm1 interface (10.3.2.201) I receive an "Host is down" message.
. it seems there is no way to have 'wm1' working...
> Networking Drivers
> http://community.qnx.com/sf/go/post112253
11/04/2014 2:15 PM
post112258
Note the interface will be named 'wm0' in each instance. Not
sure if you're confused looking explicitly for 'wm1'.
... it seems there is no way to have 'wm1' working...
> > Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post112257
11/04/2014 6:10 PM
post112260
I suspect that the problem here is the same as in topc25682:
The PCI driver does not reserve and allocate memory correctly. Please look at that topic as well as topc25206.
The problem is that the scan_windows() function in server.c adds up memory based on *sane* memory allocation methods but
pci_allocate_resources() and the E1000 driver force all PCI memory windows to be aligned on 1 MB boundaries.
You will end up running out of PCI memory with additional Gigabit ethernet parts.
You should look in your sloginfo print out to be sure that you do not see an error from addup_resources() in the PCI
system.
