Forum Topic - devnp-rum.so and devnp-ural.so device/vendors:
Is there a list of supported device/vendor ids for these drivers. I have a Linksys WUSB54GC version 3 USB 802.11g dongle
, which reports with usb -v command:
<pre>
Vendor                     : 0x1737 (Ralink)
Product                    : 0x0077 (802.11 g WLAN)
</pre>
Neither driver recognizes the device:
<pre>
# io-pkt-v4-hc -drum
# sloginfo
Feb 03 01:12:11    2    14     0 Unable to init devnp-rum.so: No such device or address
</pre>
Re: devnp-rum.so and devnp-ural.so device/vendors
This device is supported by the devnp-run.so driver. I have attached 2
versions, one for ARM and the other for x86.
>a Linksys WUSB54GC version 3 USB 802.11g dongle, which reports with usb
>-v command:
><pre>
></pre>
><pre>
># sloginfo
>device or address
></pre>
>Networking Drivers
>http://community.qnx.com/sf/go/post94696
Attachment: Text devnp-run.so 105.12 KB Text devnp-run.so.armle 115.64 KB
Thanks for the drivers! I'm still having some issues. I can associate with our office network, but can't seem to do
anything useful (ping, telnet, etc.). I notice that the system log gets swamped with messages from the driver (attached)
. I also see that the driver is using 25% of the CPU. My hardware is a Beagleboard-xM and I am running QNX 6.4.2.
Commands I run to reproduce the behavior:
io-pkt-v4-hc -d /fs/hd1/lib/devnp-run.so
wpa_supplicant -B -i run0 -c /fs/hd1/etc/wpa_supplicant.conf
ifconfig run0 172.23.93.19
ifconfig
run0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
        ssid mgtsciences nwkey 65536:"","","",""
        powersave off
        bssid 00:09:5b:a1:89:2b chan 9
        address: 00:23:69:e0:27:8f
        media: IEEE802.11 autoselect (DS1 mode 11g)
        status: active
        inet 172.23.93.193 netmask 0xffff0000 broadcast 172.23.255.255
sloginfo > sloginfo.txt
Here is my wpa_supplicant.conf:
network={
ssid="mgtsciences"
key_mgmt=WPA-PSK
psk="abcdefghij"
Attachment: Text sloginfo.txt 21.07 KB
Unfortunately this is an experimental/un-supported driver that was ported
from a FreeBSD driver and hasn't gone through any official testing, so
that is why it isn't released.
>with our office network, but can't seem to do anything useful (ping,
>from the driver (attached). I also see that the driver is using 25% of
>ifconfig
>        powersave off
>        status: active
>network={
>ssid="mgtsciences"
>key_mgmt=WPA-PSK
>psk="abcdefghij"
>Networking Drivers
>http://community.qnx.com/sf/go/post94723
Ok, understood. Is there a list of wireless USB dongles supported by the released drivers? Or just a suggested dongle?
Only the drivers that you previously mentioned. The devnp-rum.so driver
supports the Ralink RT2501/2601USB chipsets and the devnp-ural.so driver
supports the Ralink RT2500USB chipset. We don't have the vendor names of
dongles that contain these chipsets.
>Networking Drivers
>http://community.qnx.com/sf/go/post94729
Would it be possible to get the source code for the ARM version of the devnp-run.so driver?
> >-v command:
> ><pre>
> ></pre>
> ><pre>
> ># sloginfo
> >device or address
> ></pre>
> >Networking Drivers
I have attached the archive. Please be advised that this is a ported
FreeBSD driver and that there is no support for it.
>>have
>> >-v command:
>> ><pre>
>> ></pre>
>> ><pre>
>> ># sloginfo
>> >device or address
>> ></pre>
>> >Networking Drivers
>Networking Drivers
>http://community.qnx.com/sf/go/post95156
Attachment: Text run.src.tar.gz 26.8 KB
Thanks, looks like more than I want to chew on. Can we get the source code for the rum and ural drivers? It looks like
the newer RT5201USB chipset (RF5226 & RT2571W) is pretty close to the RT2501USB chipset (RF2528 & RT2571W). Might not be too hard to adapt the existing driver.
Archive attached.
>code for the rum and ural drivers? It looks like the newer RT5201USB
>>2
>Networking Drivers
>http://community.qnx.com/sf/go/post95240
Attachment: Text rum_ural.tar.gz 37.29 KB
