RE: Unable to ping one pandaboard from another with both having QNX on it
08/02/2012 12:59 PM
post94600
Is your dongle consistently working by connecting to your desktop for example. We are not getting anything on either
side. What is the version of your devn-asix.so?
From: Johnson Thomas [mailto:community-noreply@qnx.com]
Sent: Thursday, August 02, 2012 12:52 PM
To: drivers-networking
Subject: Unable to ping one pandaboard from another with both having QNX on it
Hi all,
I have QNX 6.5.0 running on two pandaboards (Board1 & Board2) connected by a crosswire ethernet cable. I am using a ASIX USB to Ethernet dongle on both the boards since for some reason the mac address of the ethernet port on both boards are all 0's. I use the following lines in the build script to start up io-pkt-v4
io-pkt-v4 -dasix promiscuous,mac=<MAC ADDRESS>,verbose=4 -ptcpip
waitfor /dev/socket
if_up -p en0
display_msg Getting Static IP
ifconfig en0 <IP> netmask 255.255.254.0
ifconfig en0
The following are the sloginfo for both boards
Board 1
Time Sev Major Minor Args
Jan 01 00:00:00 2 19 1800 devb-mmcsd-blaze 1.00A (Aug 2 2012 12:28:51)
Jan 01 00:00:00 2 5 0 libcam.so (Jun 15 2010 01:01:35) bver 6040207
Jan 01 00:00:00 2 5 100 cam-disk.so (Jun 15 2010 01:01:50)
Jan 01 00:00:02 5 14 0 tcpip starting
Jan 01 00:00:02 3 14 0 Unable to attach to pci server: No such file or directory
Jan 01 00:00:02 3 14 0 Using pseudo random generator. See "random" option
Jan 01 00:00:03 5 14 0 devn-ax: MII transceiver found at address 16.
Jan 01 00:00:03 5 14 0 io-pkt shim
Jan 01 00:00:03 5 14 0 Vendor .............. 0x0
Jan 01 00:00:03 5 14 0 Device .............. 0x0
Jan 01 00:00:03 5 14 0 Revision ............ 0x0
Jan 01 00:00:03 5 14 0 MAC address ......... 0050b6 0a3c66
Jan 01 00:00:03 5 14 0 Asix
Jan 01 00:00:03 5 14 0 LanIdx .............. 18
Jan 01 00:00:03 5 14 0 DevIdx .............. 0
Jan 01 00:00:03 5 14 0 Vendor .............. 0xb95
Jan 01 00:00:03 5 14 0 Device .............. 0x7720
Jan 01 00:00:03 5 14 0 MAC address ......... <MAC ADDRESS>
Jan 01 00:00:06 5 10 0 devn-ax: link up (100 BaseT Full Duplex)
Board2
Jan 01 00:00:00 2 19 1800 devb-mmcsd-blaze 1.00A (Aug 2 2012 12:26:08)
Jan 01 00:00:03 5 14 0 MAC address ......... 0050b6 0a546c
Jan 01 00:00:36 5 10 0 devn-ax: link up (100 BaseT Full Duplex)
nicinfo:
Board1
en0:
Asix Ethernet Controller
Physical Node ID ........................... <MAC ADDRESS>
Current Physical Node ID ................... <MAC ADDRESS>
Current Operation...
Re: Unable to ping one pandaboard from another with both having QNX on it
08/02/2012 1:01 PM
post94601
What is <MAC ADDRESS>? Why are you specifying it if the Asix dongle
already has a MAC address?
On 2012-08-02 12:51 PM, "Johnson Thomas" <community-noreply@qnx.com> wrote:
>Hi all,
dongle
> waitfor /dev/socket
> if_up -p en0
> ifconfig en0
>Board 1
>12:28:51)
>6040207
>file or directory
>"random" option
>address 16.
>Board2
>12:26:08)
>6040207
>file or directory
>"random" option
>address 16.
>nicinfo:
>Board1
>en0:
> Physical Node ID...
