Forum Topic - Intel i350:
Intel i350
Is the Intel i350 Network Control supported ?  On the road map ? Should I get in touch with our representative ;-)
Re: Intel i350
No, this device isn't currently supported. I'm not sure when it will be.
Hugh Brown
QNX Software Systems Limited
1001 Farrar Rd.,
Ottawa. ON. K2K 0B3.
Telephone: 613-591-0931
>Networking Drivers
>http://community.qnx.com/sf/go/post91985
Re: Intel i350
Mario,
Do you have one of these devices? If so, what is the device ID?
Thanks, Hugh.
Hugh Brown
1001 Farrar Rd.,
>Networking Drivers
RE: Intel i350
> -----Message d'origine-----
> De : Hugh Brown [mailto:community-noreply@qnx.com]
> Envoyé : 9 mars 2012 10:12
> À : drivers-networking
> Objet : Re: Intel i350
> Mario,
No I don`t.  It`s part of all the new series of motherboards that supermicro has recently released (X9 series).    I was
 looking at getting an eval kit, but decided not to when you told me there was no driver for it, but if it could be of
any help I could arrange to get one ?
> Thanks, Hugh.
> Hugh Brown
> 1001 Farrar Rd.,
> >Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post92014
Re: Intel i350
I have just looked at the latest e1000 driver and it does support the
I350! My bad!
Hugh Brown
1001 Farrar Rd.,
>> Mario,
>supermicro has recently released (X9 series).    I was looking at getting
>it, but if it could be of any help I could arrange to get one ?
>> Thanks, Hugh.
>> Hugh Brown
>> 1001 Farrar Rd.,
>>Should I
>> >Networking Drivers
>> Networking Drivers
>Networking Drivers
>http://community.qnx.com/sf/go/post92017
RE: Intel i350
> Envoyé : 9 mars 2012 10:42
> I have just looked at the latest e1000 driver and it does support the I350! My bad!
Sweet as.
> Hugh Brown
> 1001 Farrar Rd.,
> >> Mario,
> >> Thanks, Hugh.
> >> Hugh Brown
> >> 1001 Farrar Rd.,
> >>Should I
> >> >Networking Drivers
> >> Networking Drivers
> >Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post92018
Re: RE: Intel i350
At the time this post was written, the latest driver I have on hand ( date is 2012/05/03, experimental ) works on that
chipset but the one with SP1 doesn't. It detects the NIC but it always reports a speed of 0 half duplex.  But the SP1
driver is data 2012/06/20. Is it because something go broken or the experimental driver has some changes that didn't
make it into SP1?
Re: Intel i350
Does the attached driver work for you? If not, can you please start the
driver with "verbose=3" and post the sloginfo output.
>date is 2012/05/03, experimental ) works on that chipset but the one with
>duplex.  But the SP1 driver is data 2012/06/20. Is it because something
>go broken or the experimental driver has some changes that didn't make it
>into SP1?
>Networking Drivers
>http://community.qnx.com/sf/go/post95454
Attachment: Text devnp-e1000.so 270.39 KB
Re: Intel i350
Didn't work. Sloginfo ouput attached. Nicinfo shows incoming packets.  It's important to note our cisco switch takes
around 30 seconds to auto-negoticate and do some fancy test detection before showing the port as active.  Though I'd
mention it in case it could be related.
> >into SP1?
> >Networking Drivers
Attachment: Text sloginfo.txt 2.58 KB
Re: Intel i350
Now the thread shows up again! Please try the attached driver and let me
know if it works.
>It's important to note our cisco switch takes around 30 seconds to
>as active.  Though I'd mention it in case it could be related.
>>with
>>it
>> >into SP1?
>> >Networking Drivers
>Networking Drivers
>http://community.qnx.com/sf/go/post95456
Attachment: Text devnp-e1000.so 270.33 KB
RE: Intel i350
This one is working!
> Envoyé : 10 septembre 2012 08:25
> À : drivers-networking@community.qnx.com
> know if it works.
> >> the driver with "verbose=3" and post the sloginfo output.
> >port as active.  Though I'd mention it in case it could be related.
> >> >( date is 2012/05/03, experimental ) works on that chipset but the
> >> >one
> >>with
> >> >half duplex.  But the SP1 driver is data 2012/06/20. Is it because
> >> >didn't make
> >>it
> >> >into SP1?
> >> >Networking Drivers
> >Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post95464
> To cancel your subscription to this discussion, please e-mail drivers-
Re: Intel i350
OK, so there must be a difference between the trunk and 6.5.0 branches.
I'll investigate.
Thanks, Hugh.
>> know if it works.
>> >> >one
>> >>with
>> >> >didn't make
>> >>it
>> >> >into SP1?
>> >> >Networking Drivers
>> >Networking Drivers
>> Networking Drivers
>Networking Drivers
>http://community.qnx.com/sf/go/post95465
Re: Intel i350
Please try this one.
Thanks, Hugh.
>> know if it works.
>> >> >one
>> >>with
>> >> >didn't make
>> >>it
>> >> >into SP1?
>> >> >Networking Drivers
>> >Networking Drivers
>> Networking Drivers
>Networking Drivers
Attachment: Text devnp-e1000.so 270.57 KB
RE: Intel i350
This one doesn't work but nicinfo does show proper link speed with some TX and RX packets, but can't see the network
with ping or qnet.
Thanks!
> Envoyé : 10 septembre 2012 11:06
> Thanks, Hugh.
> >> me know if it works.
> >> >> start the driver with "verbose=3" and post the sloginfo output.
> noreply@qnx.com>
> >> >> >hand ( date is 2012/05/03, experimental ) works on that chipset
> >> >> >but the one
> >> >>with
> >> >> >0 half duplex.  But the SP1 driver is data 2012/06/20. Is it
> >> >>it
> >> >> >into SP1?
> >> >> >Networking Drivers
> >> >Networking Drivers
> >> Networking Drivers
> >> drivers- networking-unsubscribe@community.qnx.com
Re: Intel i350
How about this one.
Thanks, Hugh.
>TX and RX packets, but can't see the network with ping or qnet.
>Thanks!
>> Thanks, Hugh.
>>packets.
>> noreply@qnx.com>
>> >> >> >but the one
>> >> >>with
>> >> >>it
>> >> >> >into SP1?
>> >> >> >Networking Drivers
>> >> >Networking Drivers
>> >> >To cancel your subscription to this...
Attachment: Text devnp-e1000.so 270.36 KB
RE: Intel i350
This one work, if you need to do more testing, don`t hesitate, glad I can help.
> Envoyé : 11 septembre 2012 10:23
> How about this one.
> Thanks, Hugh.
> >Thanks!
> >> Thanks, Hugh.
> >> >> let me know if it works.
> noreply@qnx.com>
> >>packets.
> >> >> >showing the port as active.  Though I'd mention it in case it could be
> related.
> >> noreply@qnx.com>
> >> >> >> >chipset but the one
> >> >> >>with
> >> >> >> >of
> >> >> >>it
> >> >> >> >into SP1?
Re: Intel i350
Good news! The changes that I made to the trunk driver were made after the
SP1 release was frozen, so that is why the changes were not in SP1.
Thanks, Hugh.
>help.
>> How about this one.
>> Thanks, Hugh.
>> >Thanks!
>> >> Thanks, Hugh.
>> noreply@qnx.com>
>> >>packets.
>>could be
>> related.
>> >> noreply@qnx.com>
>> >> >> >> >chipset but the one
>> >> >> >>with
>> >> >> >> >of
>> >> >> >> >0 half...
