netmanager not starting interface
10/07/2011 10:14 AM
post89268
The laptop I am using requires a Realtek 8169 driver, the script for which is placed in /etc/system/devices/overrides.
The driver loads, but no IP address gets configured unless I manaully run 'netmanager', when it configures exactly as
phlip sets, both dhcp and manual.
I cannot see why netmanager does not run, since 'use(symbolic=netmgr) appears as a line after each recognised device,
including the script in overrides.
At what point in the boot process should netmanager run - or must it be started by adding to later scripts?
