running second instance of io-pkt in 6.5.0 gets the default interface down
09/14/2011 2:49 AM
post88813
I'm trying to load a USB network dongle on x86 machine running QNX 6.5.0 SDP.
when I try to load the USB dongle driver using the io-pkt, the default ethernet interface disappears. So running the
second io-pkt instance cause any problem to the existing io-pkt instance?
If I slay the new io-pkt instance used to load the USB dongle driver, then the default ethernet interface shows up.
Should I specify any option to the io-pkt while loading the USB dongle driver in order to retain the default interface,
would someone help me on this, appreciate your quick response on this.
GK
