Verifying mbuf leaks in Ethernet driver
03/11/2011 1:04 AM
post83917
I am looking for a tool in Momentics which can display leaks in statically allocated buffers. More specifically mbufs in
ethernet driver. Please clarify the points given below.
1) what is the size of a mbuf used in ethernet driver?
2) Does these mbufs are globally shared accross the tsec interfaces available in the card ?
3) Is it possbile to check the mbufs stats per interface by using "netstat -m" command ?
4) Does Momentics include any tool to verify the leaks in mbufs used in mpc85xx Ethernet driver ?
Thanks & Regards,
Ramakrishna
