Re: Micrel KS8841 driver and PI7C9X110 PCIe2PCI bridge
03/02/2011 10:37 AM
post83688
Looking at the driver source, it uses descriptors for transmit and receive,
so it will only run in DMA mode. Maybe there is some bridge setup required
to get it working.
Hugh.
On 11-03-02 10:15 AM, "Christophe Hannoyer" <community-noreply@qnx.com>
wrote:
> Hello Hugh,
> Thank you for the reply.
> For the moment we are still not able to see if the problem is related to the
> HW or a configuration of the bridge and/or the 8841.
> For the moment a PCI scan show that the 8841 tries to read from the main
> memory and never gets an answer. In this case the 8841 requesting the PCI bus
> all the time.
> Do you know if it's possible to use the devn-micrel8841.so without DMA?
> Thanks,
> Christophe
>> > There should no difference in the performance of the network driver,
>> whether
>> > it is behind a PCI bridge or not.
>> > See my answers in-line.
> Networking Drivers
> http://community.qnx.com/sf/go/post83686
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
