Forum Topic - Serial Communication between two CPU's:
We have a dual board Machine. One of the board gets connected to the network using a LAN wire and the other board gets
connected to the first board using serial communication(COM port).
We have an existing code in QNX 6.2 which is
io-net -dspeedo -dfd fd=/dev/ser1,mac=000102030405,ahdlc -ptcpip
ifconfig en1 / netmask 255.255.255.252
Now we are porting it to QNX 6.5.0
I am trying to create a serial communication like above in QNX 6.5.
I wrote the code
io-pkt-v4-hc -d/lib/dll/devnp-speedo.so -d/lib/dll/devnp-shim.so /lib/dll/devn-fd.so fd=/dev/ser1,mac=000102030405,adhlc
 -ptcpip
But the above command throws and error. IT says unable to init the devnp-shim driver. I am new to QNX and i am stuck
with this serial communication problem for the last 3 weeks. I tried almost everything that is available on the internet
 but nothing seems to work. We have a release deadline on next tuesday for this. I have ported everything except this
serial communication between these 2 boards is not working. Please help me in solving this.
Re: Serial Communication between two CPU's
Try starting the drivers without specifying the devnp-shim on the command
line. The shim should be started automatically when a devn-* driver is
started.
> using a LAN wire and the other board gets connected to the first board using
> I wrote the code
> /lib/dll/devn-fd.so fd=/dev/ser1,mac=000102030405,adhlc -ptcpip
> driver. I am new to QNX and i am stuck with this serial communication problem
> internet but nothing seems to work. We have a release deadline on next tuesday
> for this. I have ported everything except this serial communication between
> Networking Drivers
> http://community.qnx.com/sf/go/post75059
Kanata, Ontario, Canada.
K2M 1W8
I tried but then it says cannot find devnp-shim driver. I think i need to set the Library path.
Please tell me what command shall i run in command prompt for setting library path if my shim driver is in /lib/dll
Your LD_LIBRARY_PATH should have /lib/dll in it.
> the Library path.
> Networking Drivers
> http://community.qnx.com/sf/go/post75063
K2M 1W8
So what can be other reason for this error cannot find Devnp-Shim Driver?
 Also like in previous versions of qnx we had multiple interfaces like en0 and en1. Do we have a similar fxp1 and Fxp0
networking interfaces?
If you just start io-pkt-v4 ­ddevn-fd ...... does that work?
Yes, you have multiple interfaces fxp0, 1 etc.
> en1. Do we have a similar fxp1 and Fxp0 networking interfaces?
> Networking Drivers
> http://community.qnx.com/sf/go/post75065
K2M 1W8
If i run
io-pkt-v4 ­ddevn-fd -v it runs and throws no error. But when i run ifconfig after running the above command i can see
only one network interface details lo0
But when i put "-" before ddevn-fd and run  io-pkt-v4 ­-ddevn-fd we get an error that
"Unable to load devn-devn-fd.so:Library cannot be found"
Sorry, my bad! You must run “io-pkt-v4 ­dfd .......”.
On 10-11-18 8:25 AM, "Raj Vardhan" <community-noreply@qnx.com> wrote:
> If i run
> after running the above command i can see only one network interface details
> lo0
> error that
> Networking Drivers
> http://community.qnx.com/sf/go/post75069
K2M 1W8
Sorry couldnot get you.
What is the command you want me to run?
I am running io-pkt-v4-hc. Is it ok or should i run io-pkt-v4?
You can run either. The ­hc variant has the security built in.
> Networking Drivers
> http://community.qnx.com/sf/go/post75072
K2M 1W8
So what is the command that i have to run?
io-pkt-v4-hc ­dspeedo ­dfd fd=/dev/ser1,mac=000102030405,ahdlc
That should work.
> Networking Drivers
> http://community.qnx.com/sf/go/post75075
K2M 1W8
I ran this command
io-pkt-v4-hc dspeedo dfd fd=/dev/ser1,mac=000102030405,adhlc -v
It gave no error but when i ran ifconfig i got only one network interface that is lo0.
Then i ran this command by putting"-" before dspeedo and dfd
io-pkt-v4-hc -dspeedo -dfd fd=/dev/ser1,mac=000102030405,adhlc -v
It threw an error
Unable to load devn-speedo.so:library cannot be found
Unable to load devn-fd.so:library cannot be found.
I think LD_library path is not set properly.
Is there a way to set LD_Library_Path through command line?
You must specify Œ-d¹ before the driver name. What is the output from Œenv¹?
Does it show LD_LIBRARY_PATH?
On 10-11-18 8:44 AM, "Raj Vardhan" <community-noreply@qnx.com> wrote:
> I ran this command
> is lo0.
> It threw an error
> Networking Drivers
> http://community.qnx.com/sf/go/post75081
K2M 1W8
An image is coming before env1.
Please tell me the syntax to run for checking LD_LIBRARY_PATH
What do you mean? Just run ³env².
> Networking Drivers
> http://community.qnx.com/sf/go/post75085
K2M 1W8
Do you want me to run 3env2? if i run this it says no such file or directory error.
Sorry for asking you so many questions. Actually i am very new into QNX
Please tell me what command you want me to run?
is it 3env2. There is no command like.
Sorry if i am asking silly questions.
Actually i am new to QNX
My e-mail client seems to be sending strange characters. You must just run
the env command to see your environment.
> Networking Drivers
> http://community.qnx.com/sf/go/post75093
K2M 1W8
Running env gives me the following output:
_=/bin/env
PATH=:/proc/boot:/bin:/sbin:/usr/bin:/usr/sbin
TERM=qansi
UGC=1
ETX_TYPE=0
SYSNAME=nto
I dont see/lib/dll in PATH.
How can i add /lib/dll in the Library path?
Please Help.
Please tell me how can i add /lib/dll in the library path?
export LD_LIBRARY_PATH = /lib/dll
What system are you running on? The LD_LIBRARY_PATH should already be setup
for you. You can see this by running the env command.
> Thanks
> Networking Drivers
> http://community.qnx.com/sf/go/post75112
K2M 1W8
We are running on the system whose BIOS chip has been written by my company. Its a unix based BIOS. So do i have to
change library path in the code for BIOS chip?
I dont have the code for the BIOS chip. Can i set LIBRARY PATH through command line or do i have to request my company
for the BIOS code?
If you boot the standard QNX development system, LD_LIBRARY_PATH should
already be setup for you. What does the command env show?
> Its a unix based BIOS. So do i have to change library path in the code for
> BIOS chip?
> line or do i have to request my company for the BIOS code?
> Networking Drivers
> http://community.qnx.com/sf/go/post75122
K2M 1W8
_=/bin/env
TERM=qansi
UGC=1
ETX_TYPE=0
SYSNAME=nto
There must be something wrong, as you are not getting the full environment.
Are you booting the standard QNX 6.5.0 image and development environment?
> _=/bin/env
> TERM=qansi
> UGC=1
> ETX_TYPE=0
> SYSNAME=nto
> Networking Drivers
> http://community.qnx.com/sf/go/post75125
K2M 1W8
I am booting QNX 6.5.0 image. Do you predict something wrong in the BIOS Chip Code?
I have run
io-pkt-v4-hc -dfd.so
It gives me error that "unable to load devn-fd.so:Library cannot be found"
