Forum Topic - autoIP half working?:
I'm attempting to get autoIP working between WinXP and QNX.  The two machines are directly connected via crossover cable
On the QNX side I execute:
io-pkt-v4 -de1000 -ptcpip
mount -T io-pkt -oif=wm0,ip=169.254.20.20,delay=200,abandon,force lsm-autoip.so
dhcp.client -I 10 -i wm0  &
if_up wm0 -a -s 1 -r 10
route add default 169.254.20.20
At this point the WinXP machine has establish an IP address of 169.254.78.131. From this machine I can successfully ping
 the QNX machine at 169.254.20.20, but, I cannot ping the WinXP machine from the QNX machine.
The route table on the QNX end is probably no correct.  It contains:
Routing tables
Internet:
Destination             Gateway                 Flags
0.0.0.0/8                link#2                     U
default                   169.254.20.20        UG
localhost.localdom 127.0.0.1                 UH
169.254.0.0/16      link#2                      U
169.254.20.20       00:17:3c:00:9d:5c  UHL
Any ideas on how to fix this?  What have I overlooked?
When I use DHCP everything works fine.
Re: autoIP half working?
If I remove the dhcp.client.... line to simplify things I get the same behavior.  Can ping to QNX from PC, can't ping
from QNX to PC.
The problem was due to a firewall setting on the PC.  Remove the firewall and ping is now working in both directions.
