start io-pkt-v4?dose it work?
09/06/2010 9:50 AM
post66067
I am working on at91sam9263 board.and the NIC is dm9000,I am trying to make the network running.but there is no response
to the
"io-pkt-v4 -d at91sam9xx syspage"
I think if it work successfully,there would be
/dev/io-net/ip0
and /dev/io-net/en0
Now my problem is that I do not make sure whether the NIC has been started.
this is the sloginfo of runing "io-pkt-v4 -d at91sam9xx syspage"
Jan 01 06:06:02 5 14 0 tcpip starting
Jan 01 06:06:02 3 14 0 Unable to attach to pci server: No such file or directory
Jan 01 06:06:02 3 14 0 Using pseudo random generator. See "random" option
Jan 01 06:06:02 2 14 0 at91sam9xx_attach(): IF 0: Base register 0xFFFBC000
Jan 01 06:06:02 2 14 0 at91sam9xx_attach(): IF 0: IRQ 0
Jan 01 06:06:02 2 14 0 at91sam9xx_attach(): IF 0: PHY address -278528
Jan 01 06:06:02 5 10 0 AT91SAM9XX EMAC
Jan 01 06:06:02 5 10 0 Vendor .............. 0x0
Jan 01 06:06:02 5 10 0 Device .............. 0x0
Jan 01 06:06:02 5 10 0 Revision ............ 0x0
Jan 01 06:06:02 5 10 0 Memory base ......... 0xfffbc000
Jan 01 06:06:02 5 10 0 MAC address ......... 662200 031615
# ifconfig
emac0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
address: 66:22:00:03:16:15
media: Ethernet none
can you tell me the reason of this secret,thanks.
best regards!
yang
