mystery slog entries -- ient xxxxxxxx from 0 to 1, ient xxxxxxx from 1 to 0
07/13/2010 12:22 PM
post59320
I'm getting repetitive entries in the slog:
Jan 01 00:57:05 5 14 0 ient 80f9c3c from 0 to 1
Jan 01 00:57:05 5 14 0 ient 80f9c3c from 1 to 0
I get 15 or 16 entries per second. Any idea where they're coming from?
Gary
Re: mystery slog entries -- ient xxxxxxxx from 0 to 1, ient xxxxxxx
from 1 to 0
07/13/2010 1:27 PM
post59323
from 1 to 0
What network driver are you running? Are you using io-pkt or io-net?
> Thanks,
> Gary
> Networking Drivers
> http://community.qnx.com/sf/go/post59320
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
RE: mystery slog entries -- ient xxxxxxxx from 0 to 1, ient xxxxxxx
from 1 to 0
07/13/2010 1:31 PM
post59324
from 1 to 0
io-pkt, QNX641.
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: Tuesday, July 13, 2010 10:28 AM
To: drivers-networking
Subject: Re: mystery slog entries -- ient xxxxxxxx from 0 to 1, ient xxxxxxx from 1 to 0
> Thanks,
> Gary
> Networking Drivers
K2M 1W8
Networking Drivers
http://community.qnx.com/sf/go/post59323
from 1 to 0
07/13/2010 1:37 PM
post59326
from 1 to 0
Yes, but what network driver are you running?
On 10-07-13 1:31 PM, "gary anderson" <community-noreply@qnx.com> wrote:
> io-pkt, QNX641.
> from 1 to 0
>> Thanks,
>> Gary
>> Networking Drivers
K2M 1W8
from 1 to 0
07/13/2010 1:51 PM
post59328
from 1 to 0
Running on an Intel platform with the devnp-e1000.so network driver plus another network driver (derived from the sam
ddk package) to implement to implement a private network over the PCIe bus. Jumbo packets are enabled (pagesize=8192,
mclbytes=8192) to improve performance of the PCIe implemented network.
Sent: Tuesday, July 13, 2010 10:37 AM
> io-pkt, QNX641.
> from 1 to 0
>> Thanks,
>> Gary
>> Networking Drivers
K2M 1W8
Networking Drivers
http://community.qnx.com/sf/go/post59326
from 1 to 0
07/13/2010 2:00 PM
post59332
from 1 to 0
There is no message like this in the e1000 driver, so I guess it could be
somewhere in the stack. ient is an interrupt entry, so do you have an
interrupt service routine in your driver?
> another network driver (derived from the sam ddk package) to implement to
> (pagesize=8192,mclbytes=8192) to improve performance of the PCIe implemented
> network.
> from 1 to 0
>> io-pkt, QNX641.
>> -----Original Message-----
>> from 1 to 0
>>> Thanks,
>>> Gary
>>> Networking Drivers
K2M 1W8
xxxxxxx from 1 to 0
07/13/2010 2:03 PM
post59333
xxxxxxx from 1 to 0
Yes, from the stack.
> > network.
> > from 1 to 0
> >> io-pkt, QNX641.
> >> from 1 to 0
> >>> Thanks,
> >>> Gary
> >>> Networking Drivers
> K2M 1W8
> Networking Drivers
> http://community.qnx.com/sf/go/post59332
xxxxxxx from 1 to 0
07/13/2010 6:08 PM
post59357
xxxxxxx from 1 to 0
I have a multiple CPU system with a PCIe network connection between the Monarch processor and every Endpoint processor.
In my startup code, as I discover CPU modules I execute a mount command to instantiate a driver for each discovered CPU
-- "mount -Tio-pkt -o<slot> libpcielan.so" where <slot> is passed to the driver to inform it which CPU to connect to
and it's also used to generate IP addresses. In my test system I have four CPUs -- the Monarch and three Endpoints so
three "mounts" are executed. After everything is init'ed I have the following ifconfig output from the Monarch CPU:
# ifconfig
wm0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
capabilities rx=1f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM>
capabilities tx=7f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM,TSO4,TSO6>
enabled=0
address: 00:17:3c:00:9a:60
media: Ethernet autoselect (1000baseT full-duplex)
status: active
inet 141.121.191.225 netmask 0xffffff00 broadcast 141.121.191.255
PCIe0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 8100
address: 00:01:02:03:00:07
inet 10.1.7.7 netmask 0xffffff00 broadcast 10.1.7.255
PCIe1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 8100
address: 00:01:02:03:00:05
inet 10.1.5.5 netmask 0xffffff00 broadcast 10.1.5.255
PCIe2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 8100
address: 00:01:02:03:00:0b
inet 10.1.11.11 netmask 0xffffff00 broadcast 10.1.11.255
At this point I start getting the "ient xxxxxxxx from 0 to 1, ient xxxxxxx from 1 to 0" entries in the syslog. If I
disable one of the PCIe NICs (ifconfig PCIe2 down) the syslog entries quit. Re-enabling the PCIe NIC causes the syslog
entries to resume.
The Monarch processor is configured with NAT to get from the public wm0 (Ethernet) port to the private network of
Endpoint CPUs. It seemingly all works but I don't understand the syslog entries.
Any ideas?
From: Sean Boudreau [mailto:community-noreply@qnx.com]
Sent: Tuesday, July 13, 2010 11:04 AM
> > network.
> > from 1 to 0
> >> io-pkt, QNX641.
> >> Subject: Re: mystery slog entries --...
xxxxxxx from 1 to 0
07/14/2010 9:19 AM
post59402
xxxxxxx from 1 to 0
. In my startup code, as I discover CPU modules I execute a mount command to instantiate a driver for each discovered
CPU -- "mount -Tio-pkt -o<slot> libpcielan.so" where <slot> is passed to the driver to inform it which CPU to connect
to and it's also used to generate IP addresses. In my test system I have four CPUs -- the Monarch and three Endpoints
so three "mounts" are executed. After everything is init'ed I have the following ifconfig output from the Monarch CPU:
> # ifconfig
> enabled=0
> status: active
entries to resume.
> Any ideas?
It's a debug slog from the stack. It's safe to ignore.
xxxxxxx from 1 to 0
07/14/2010 10:31 AM
post59419
xxxxxxx from 1 to 0
Is there any way to disable it? It is persistent and fills the syslog making the syslog unusable for any other logging.
Gary
Sent: Wednesday, July 14, 2010 6:19 AM
> # ifconfig
> enabled=0
> status: active
entries to resume.
> Any ideas?
Networking Drivers
http://community.qnx.com/sf/go/post59402
xxxxxxx from 1 to 0
07/14/2010 10:34 AM
post59422
xxxxxxx from 1 to 0
Not currently. A workaround may be 'io-pkt -t4 ...' where 4
is your number of interfaces. Or 'sloginfo | grep -v ient'.
I'll make a PR to disable it or only spit it out with
io-pkt -v.
logging.
> Thanks,
> Gary
processor. In my startup code, as I discover CPU modules I execute a mount command to instantiate a driver for each
discovered CPU -- "mount -Tio-pkt -o<slot> libpcielan.so" where <slot> is passed to the driver to inform it which CPU
to connect to and it's also used to generate IP addresses. In my test system I have four CPUs -- the Monarch and three
Endpoints so three "mounts" are executed. After everything is init'ed I have the following ifconfig output from the
Monarch CPU:
> > # ifconfig
> > enabled=0
> > status: active
entries to resume.
> > Any ideas?
> Regards,
> -seanb
> Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post59419
from 1 to 0
07/14/2010 12:13 PM
post59442
from 1 to 0
Hi Sean
I have asked this question earlier but since you mention about debug traces
of io-pkt here and enabling them thru io-pkt -v
Can you please let me know if there is a way to get io-net debug traces in
systlog? I have tried doing io-net -v but that doesn't seem to help.
Regards
Vineet
On Wed, Jul 14, 2010 at 8:04 PM, Sean Boudreau <community-noreply@qnx.com>wrote:
> io-pkt -v.
> -seanb
> > Thanks,
> > Gary
> xxxxxxx from 1 to 0
> Monarch processor and every Endpoint processor. In my startup code, as I
> each discovered CPU -- "mount -Tio-pkt -o<slot> libpcielan.so" where <slot>
> is passed to the driver to inform it which CPU to connect to and it's also
> Monarch and three Endpoints so three "mounts" are executed. After
> CPU:
> > > # ifconfig
> > > capabilities
> > > enabled=0
> > > status: active
> 141.121.191.255
> xxxxxxx from 1 to 0" entries in the syslog. If I disable one of the PCIe
> causes the syslog entries to resume.
> (Ethernet) port to the private network of Endpoint CPUs. It seemingly all
> > > Any ideas?
> > It's a...
from 1 to 0
07/13/2010 2:06 PM
post59334
from 1 to 0
Right now my PCIe network driver is run off the timer interrupt (as done in the 'sam' example).
Sent: Tuesday, July 13, 2010 11:00 AM
> network.
> from 1 to 0
>> io-pkt, QNX641.
>> from 1 to 0
>>> Thanks,
>>> Gary
>>> Networking Drivers
K2M 1W8
Networking Drivers
Re: RE: mystery slog entries -- ient xxxxxxxx from 0 to 1, ient xxxxxxx from 1 to 0
08/05/2010 2:46 PM
post61850
Is there anyway I can get the source to the PCIe lan implementation that Gary did?
