Forum Topic - QNX 4.25 on Dell 530 with Net.ether82557 driver:
We are a few problems with QNX 4.25 on a Dell Inspiron 530.  First, when we run /bin/Net the machine just hangs even
though it is on a working network.  The second problem is when we run:
    # /bin/Net.ether82557 -I0 -i5 -l1
It outputs:
    DriverInit: Unable to locate adapter.
This machine and network card work under Debian Lenny and Windows XP.  The machines have an Intel 82562V-2 10/100
Ethernet Controllers and according to the QNX website they use the 82557 driver.  Thanks in advance for any help.
Re: QNX 4.25 on Dell 530 with Net.ether82557 driver
If you run 'slay Net' and then run 'bin/Net &', does that work?
> run /bin/Net the machine just hangs even though it is on a working network.
> It outputs:
> machines have an Intel 82562V-2 10/100 Ethernet Controllers and according to
> Networking Drivers
> http://community.qnx.com/sf/go/post56786
Kanata, Ontario, Canada.
K2M 1W8
Thanks for the fast reply.  But no Net process is running.  When I run 'slay Net' it returns:
    slay: unable to find process 'Net'
and 'ps' does not have any process named Net running.
> > It outputs:
> > Networking Drivers
> K2M 1W8
OK, then just run "/bin/Net &". You must supply the '&'.
> Net' it returns:
>>> It outputs:
>>> Networking Drivers
>> K2M 1W8
> Networking Drivers
> http://community.qnx.com/sf/go/post56792
K2M 1W8
Hah thanks simple mistake.  This starts the Net process but I still cannot get the adaptor to work.  See the following:
     # /bin/Net.ether82557 &
     164 running /bin/Net.ether82557
Please can you post the output from 'show_pci -v'.
> Networking Drivers
> http://community.qnx.com/sf/go/post56794
K2M 1W8
Vendor ID		= 8086h, INTEL CORPORATION
Device ID		= 10c0h
PCI index		= 0h
Class Code	= 20000h Network (Ethernet) ProgIF=0
Revision ID	= 2h
Bus number	= 0
Device number	= 25
Function num	= 0
Status Reg	= 10h
Command Reg	= 7h
Header type	= 0h Single-function
BIST			= 0h Build-in-self-test not supported
Latency Timer	= 0h
Cache Line Size= 0h
Max Lat		= 0ns
Min Gnt		= 0ns
PCI Int Pin	= 1
PCI Int Pin	= INT A
Interrupt Line	= 5
Please try the attached driver and let me know if it works.
> Device ID  = 10c0h
> PCI index  = 0h
> Revision ID = 2h
> Bus number = 0
> Device number = 25
> Function num = 0
> Status Reg = 10h
> Command Reg = 7h
> Latency Timer = 0h
> Cache Line Size= 0h
> Max Lat  = 0ns
> Min Gnt  = 0ns
> PCI Int Pin = 1
> PCI Int Pin = INT A
> Interrupt Line = 5
> Networking Drivers
> http://community.qnx.com/sf/go/post56854
K2M 1W8
Attachment: Text Net.ether82557 49.87 KB
Thanks Hugh.  I was going to try new drivers as the next step as well.  Unfortunately, I have to finish a few other
things today and will test this out tomorrow.
Okay I found out what was wrong.  On Linux 'lspci' shows:
Ethernet controller: Intel Corporation 82562V-2 10/100 Network Connection (rev 02)
for this I needed a new driver e1000 from the new QNX 4.25 release.  Now the adapter is found.  Thanks for all your help
 Hugh.
