RE: devn-i82544.so support for Intel Pro/1000 PT
06/10/2010 9:11 AM
post56507
Try either specifying "did=0x10a4" to the devn-i82544.so
at the command line, or try running devn-e1000.so, which
is probably a better bet.
Try doing this as root:
# slay io-net
# slay dhcp.client
# io-net -d i82544 did=0x10a4 -p tcpip
# dhcp.client -u
or
# slay io-net
# slay dhcp.client
# io-net -d e1000 -p tcpip
# dhcp.client -u
aboyd
From: Rashid Mirza [mailto:community-noreply@qnx.com]
Sent: Thursday, June 10, 2010 8:54 AM
To: drivers-networking
Subject: devn-i82544.so support for Intel Pro/1000 PT
I have been experimenting with a setup of a X86 machine with QNX 6.3
installed, and with a Pro/1000 PT card (4 port).
It seems the card is not recognised, as per the 'pci' utility.
The device id, shows the 10a4h, Unknown Unknown entry.
I have doubts as to whether the driver devn-i82544.so has a entry has
this device id.
As per topic 2188 it should support,(chipset 82572) but in my case it
the system does not recognize the hardware.
Any suggestions?
Also, how can i invoke a forced execution of the driver?
i have tried running io-net...but it says driver not found..
then i had doubts on the setting the library path, LD_LIBRARY_PATH, but
could not figure out how to access this, or change it,
Networking Drivers
http://community.qnx.com/sf/go/post56503
Re: devn-i82544.so support for Intel Pro/1000 PT
06/10/2010 9:22 AM
post56510
You can try the attached version of the driver, but if it doesn't work, I'm
afraid that you are out of luck with 6.3.2.
> I have doubts as to whether the driver devn-i82544.so has a entry has this
> device id.
> As per topic 2188 it should support,(chipset 82572) but in my case it the
> Any suggestions?
> then i had doubts on the setting the library path, LD_LIBRARY_PATH, but could
> Networking Drivers
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
