Problem with io-pkt-v4-hc
05/27/2010 5:27 PM
post55707
Hi all,
As soon as I execute "#slay io-pkt-v4-hc" command, my keyboard and mouse (both are USB based) control is gone, I can't
do anything, it feels like system is hang.
Please advise.
Mital
Re: Problem with io-pkt-v4-hc
05/28/2010 7:53 AM
post55718
What network driver are you running?
On 10-05-27 5:27 PM, "Mital Kanabar" <community-noreply@qnx.com> wrote:
> Hi all,
> are USB based) control is gone, I can't do anything, it feels like system is
> hang.
> Please advise.
> Thanks,
> Mital
> Networking Drivers
> http://community.qnx.com/sf/go/post55707
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
05/28/2010 8:53 AM
post55722
Hi Hugh,
Thanks for your reply. I am using "devnp-e1000.so" with io-pkt-v4-hc stack. We have QNX 6.4.0 version. However, I have
to update devnp-e1000.so (downloaded from one of your foundry reply) in order to make it work.
Mital
05/28/2010 8:56 AM
post55723
I am guessing that this could be a problem with shared interrupts. Please
can you post the output from 'pci -vv'?
On 10-05-28 8:53 AM, "Mital Kanabar" <community-noreply@qnx.com> wrote:
> Hi Hugh,
> have QNX 6.4.0 version. However, I have to update devnp-e1000.so (downloaded
> Mital
> Networking Drivers
> http://community.qnx.com/sf/go/post55722
K2M 1W8
05/28/2010 9:20 AM
post55725
Sure, find it below:
PCI version = 3.00
Class = Bridge (Host/PCI)
Vendor ID = 8086h, Intel Corporation
Device ID = 40h, Auburndale/Havendale DRAM Controller
PCI index = 0h
Class Codes = 060000h
Revision ID = 12h
Bus number = 0
Device number = 0
Function num = 0
Status Reg = 2090h
Command Reg = 6h
I/O space access disabled
Memory space access enabled
Bus Master enabled
Special Cycle operations ignored
Memory Write and Invalidate disabled
Palette Snooping disabled
Parity Error Response disabled
Data/Address stepping disabled
SERR# driver disabled
Fast back-to-back transactions to different agents disabled
Latency Timer = 0h
Cache Line Size= 0h
Subsystem Vendor ID = 8086h
Subsystem ID = 37h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = NC
Interrupt line = 0
CPU Interrupt = 0h
Capabilities Pointer = e0h
Capability ID = 9h - Vendor Specific
Capabilities = 10ch - 8811a02dh
Device Dependent Registers:
0x040: 0190 d1fe 0000 0000 0140 d1fe 0000 0000
0x050: 0000 5003 0900 0000 0000 0000 0000 0000
0x060: 0000 0000 0000 0000 0180 d1fe 0000 0000
0x070: 0000 0000 0000 0000 0000 0000 0000 0000
0x090: 0000 0000 0000 0000 4000 4900 0000 0000
0x0a0: 3f00 8012 0000 00ce 0000 e0cd 0000 80cb
0x0b0: 00d0 0000 0000 0000 0000 0000 0000 0000
0x0c0: 0000 0000 0000 0000 0000 0000 0000 0000
0x0d0: 0000 0000 0303 0000 0000 0000 0000 0064
0x0e0: 0900 0c01 2da0 1188 8800 8600 0000 0000
0x0f0: 0000 0000 0d00 0000 ab0f 1300 0000 0000
Class = Display (VGA)
Device ID = 42h, Auburndale/Havendale Integrated Graphics Controller
PCI index = 0h
Class Codes = 030000h
Revision ID = 12h
Bus number = 0
Device number = 2
Function num = 0
Status Reg = 90h
Command Reg = 7h
I/O space access enabled
Bus Master enabled
Latency Timer = 0h
Cache Line Size= 0h
PCI Mem Address = fe000000h 64bit length 4194304 enabled
PCI Mem Address = d0000000h prefetchable 64bit length 268435456 enabled
PCI IO Address = f100h length 8 enabled
Subsystem ID = 37h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 11
CPU Interrupt = bh
Capabilities Pointer = 90h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 0h - 0h
Capability ID = 1h - Power Management
Capabilities = 22h - 0h
Capability ID = 13h - Unknown
Capabilities = 306h - 60140000h
0x040: 0900 0c01 2da0 1188 8800 8600 1617 1617
0x050: 0000 5003 0900 0000 0000 0000 0000 00ce
0x060: 0000 0202 0000 0000 0000 0000 0000 0000
0x090: 05d0 0000 0000 0000 0000 0000 0000 0000
0x0a0: 1111 1100 1300 0603 0000 1460 2504 3a30
0x0b0: 0000 0000 0000 0000 0002 0000 0000 0000
0x0d0: 01a4 2200 0000 0000 0000 0000 0001 0200
0x0e0: 0000 0000 0000 0000 0080 0000 0000 0000
0x0f0: 0000 0000 0000 0000 ab0f 1300 18c0 50cb
Class = Communication (Other)
Device ID = 3b64h, Ibex Peak HECI Controller
PCI index = 0h
Class Codes = 078000h
Revision ID = 6h
Bus number = 0
Device number = 22
Function num = 0
Status...
05/28/2010 9:38 AM
post55728
There are 2 network controllers on the board, so can you try the following
to see which interface is causing the problem:
slay io-pkt-v4-hc dhcp.client
io-pkt-v4-hc -de1000 vid=0x8086,did=0x10f0
dhcp.client or ifconfig wm0 ....
slay io-pkt-v4-hc
Does this cause the machine to hang? If not, then try the above again,
substituting the did=0x10f0 with did=0x107d.
Please let me know which of the above causes the machine to hang.
Thanks, Hugh.
> PCI version = 3.00
> PCI index = 0h
> Revision ID = 12h
> Bus number = 0
> Device number = 0
> Function num = 0
> Status Reg = 2090h
> Command Reg = 6h
> Bus Master enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> Subsystem ID = 37h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = NC
> Interrupt line = 0
> CPU Interrupt = 0h
> PCI index = 0h
> Revision ID = 12h
> Bus number = 0
> Device number = 2
> Function num = 0
> Status Reg = 90h
> Command Reg = 7h
> Bus Master enabled
> Latency Timer = 0h
> Cache Line Size= 0h
> Subsystem ID = 37h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = INT A
> Interrupt line = 11
> CPU Interrupt = bh
> Capabilities ...
05/28/2010 9:51 AM
post55731
Hi Hugh,
You pointed me right place, I have removed network card from PCI slots, reboot the machine, and I was able to slay io-
pkt-v4-hc without hang. I did my job, pluged-in those two PCI cards, and again reboot the machine. It seems to be
working now.
Well Hugh, I need one more favor, as you have already looked at pci -vv file. Actually, this machine has new board
(Intel's DH55HC with i5 series processor) and we brought it for testing it with QNX. Can you tell me looking at pci -vv
file, whether all PCIs are compatible/working with QNX satisfactorily? We need to know this before ordering many of
these machines for our project.
Mital
05/28/2010 10:08 AM
post55736
Good news about the Ethernet interfaces.
I'm not sure about the rest of the interfaces. I don't think that we have
support for the graphics controller or the IDE interface right now. The IDE
interface is most probably working in PIO mode. If you run the 'usb' command
and see USB interfaces, then that is most probably working.
On 10-05-28 9:51 AM, "Mital Kanabar" <community-noreply@qnx.com> wrote:
> Hi Hugh,
> the machine, and I was able to slay io-pkt-v4-hc without hang. I did my job,
> working now.
> Actually, this machine has new board (Intel's DH55HC with i5 series processor)
> to know this before ordering many of these machines for our project.
> Thanks,
> Mital
> Networking Drivers
> http://community.qnx.com/sf/go/post55731
K2M 1W8
05/28/2010 11:22 AM
post55743
Thanks for your response.
YES
does support for graphic controller matter if we are not looking for high quality graphics? I brought harddisk and
optical drive to AHCI from IDE using BIOS.
USB interfaces seems to be working
Thanks a lot again,
I appreciate your time and effort for this.
Cheers,
Mital
> > Hi Hugh,
> reboot
> > working now.
> processor)
> vv
> need
> > Thanks,
> > Mital
> > Networking Drivers
> K2M 1W8
05/28/2010 11:27 AM
post55744
If you are not looking for high quality graphics, then the current
configuration should be OK.
> YES
> quality graphics? I brought harddisk and optical drive to AHCI from IDE using
> BIOS.
> Thanks a lot again,
> Cheers,
> Mital
>>> Hi Hugh,
>> reboot
>>> working now.
>> processor)
>> vv
>> need
>>> Thanks,
>>> Mital
>>> Networking Drivers
>> K2M 1W8
> Networking Drivers
> http://community.qnx.com/sf/go/post55743
K2M 1W8
