Forum Topic - Broadcom 5715 (did=1678) support needed:
we need support for the following ethernet controller:
Class          = Network (Ethernet)
Vendor ID      = 14e4h, Broadcom Corporation
Device ID      = 1678h,  NetXtreme BCM5715 Gigabit Ethernet
PCI index      = 0h
PCI Mem Address = fbff0000h enabled
PCI Mem Address = fbfe0000h enabled
PCI Int Pin    = INT A
Interrupt line = 7
CPU Interrupt  = 7h
PCI index      = 1h
PCI Mem Address = fbfd0000h enabled
PCI Mem Address = fbfc0000h enabled
PCI Int Pin    = INT B
Interrupt line = 11
CPU Interrupt  = bh
Some of the topics suggested that it should work with the tigon3 driver but it doesn't. Any ideas? What about QNX 6.5?
Albrecht
Re: Broadcom 5715 (did=1678) support needed
If you start the driver as follows
io-pkt-v4 -dtigon3 vid=0x14e4,did=0x1678
does the driver work?
On 10-04-14 8:14 AM, "Gunter Geigemueller" <community-noreply@qnx.com>
wrote:
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 7
> CPU Interrupt  = 7h
> PCI index      = 1h
> PCI Int Pin    = INT B
> Interrupt line = 11
> CPU Interrupt  = bh
> Thanks,
> Albrecht
> Networking Drivers
> http://community.qnx.com/sf/go/post51642
Kanata, Ontario, Canada.
K2M 1W8
Since there are two chips of this type, we first tried to get one working, by issuing
io-pkt-v4-hc -dtigon3 vid=14E4,did=1678,pci=0
No device created.
io-pkt-v4-hc -dbge vid=14E4,did=1678,pci=0
didn't help either. Is it possible to omit the 0x?
-Albrecht
No, you have to specify the 0x.
On 10-04-14 10:36 AM, "Gunter Geigemueller" <community-noreply@qnx.com>
> issuing
> No device created.
> -Albrecht
> Networking Drivers
> http://community.qnx.com/sf/go/post51662
K2M 1W8
Did starting the driver with the device ID work?
> issuing
> No device created.
> -Albrecht
> Networking Drivers
K2M 1W8
