Forum Topic - Getting MAC for a given IP:
I am trying to get the MAC address for a given IP.
I can do an "arp -a | grep xxx | sed yyy", but I need it within my sourcecode.
I have been trying to set up the ioctl function that should return this value, but it always fails with errno 6 "No such
 device or address".
Here is what I am trying to do:
struct arpreq req;
struct	sockaddr_in	*sin = (struct sockaddr_in *)&req.arp_pa;
memset(&req, 0, sizeof(req));
sin->sin_family = AF_INET;
memcpy(&sin->sin_addr.s_addr, &servAddr.sin_addr.s_addr, sizeof(sin->sin_addr.s_addr));
if(ioctl(sd, SIOCGARP, (caddr_t)&req)  != EOK)
	printf("errno %d %s", errno, strerror(errno));
Before this snippet, I have created a socket with
sd = socket(AF_INET, SOCK_STREAM, 0);
and connected to the server with
connect(sd, (struct sockaddr *) &servAddr, sizeof(servAddr));
The connection is built up without Problems, so I assume the servAddr-struct is valid.
Regards
Christian
Re: Getting MAC for a given IP
That ioctl command (SIOCGARP) isn't supported.
The arp command uses the sysctl MIB interface to look a the ARP table
contents, see lib/io-pkt/utils/a/arp.c:dump(). If you want to trigger an
ARP request to populate the table with addresses which are of interest
to you you can simply trigger traffic to that destination in any number
of ways...
Hope this helps,
/P
On 11/03/10 04:29 AM, Christian Reinecke wrote:
> Hello,
such device or address".
> struct arpreq req;
> memcpy(&sin->sin_addr.s_addr,&servAddr.sin_addr.s_addr, sizeof(sin->sin_addr.s_addr));
> connect(sd, (struct sockaddr *)&servAddr, sizeof(servAddr));
> Regards
> Christian
> Networking Drivers
> http://community.qnx.com/sf/go/post49249
Okay, but it is listed in help file for ioctl ;)
Are you referring to this entry in the table: "SIOCGARP    Get ARP
entry    Passed to devctl()"?
http://www.qnx.com/developers/docs/6.4.1/neutrino/lib_ref/i/ioctl.html
All that means is that it is passed to devctl() :-) It is still up to
the resource manager owning the file descriptor to implement it.
Seriously though, I don't know if it is possible to compile a list of
supported ioctl commands. Or does anybody know if there already is one?
Cheers!
/P
Yes.
YMYD :D
> Cheers!
> /P
Christian
> Cheers!
> /P
So, what's your final solution?
You can get the MAC address for given IP?
I encounter the same problem.
I just ran into the same problem. Again: Is there a solution? How does arp do it?
Cheers,
Christoph
