Re: Ethernet card on i.mx35 with QNX os
11/24/2009 3:51 AM
post42456
I have downloaded the bsp for the platform from:
http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/FreescaleImx353ds
When I am using the (I have the QNX640 installed):
bsp-nto640-freescale-i.mx35-3ds-trunk
I get the following error:
# sloginfo
Time Sev Major Minor Args
Jan 01 00:00:00 1 7 0 init_card: unable to dlopen deva-ctrl-mx-mx35pdk.so
Jan 01 00:00:00 1 7 0 mount_card(): failed to initialize card mx-mx35pdk
ssibase=0x43fa0000,tevt=29,tchn=1,revt=28,rchn=2,rate=48000,mixer=mclk=12288000
Jan 01 00:06:34 5 14 0 tcpip starting
Jan 01 00:06:34 3 14 0 Unable to attach to pci server: No such file or directory
Jan 01 00:06:34 3 14 0 Using pseudo random generator. See "random" option
Jan 01 00:06:34 5 14 0 initializing IPsec... done
Jan 01 00:06:34 5 14 0 IPsec: Initialized Security Association Processing.
Jan 01 00:06:34 2 14 0 Unable to load devn-mx35.so: Library cannot be found
Couldn't find the devn-mx35.so in the QNX640 installation.
When I am using the:
bsp-ntotrunk-freescale-i.mx35-3ds-trunk
# sloginfo
Jan 01 00:00:35 5 14 0 tcpip starting
Jan 01 00:00:35 3 14 0 Unable to attach to pci server: No such file or directory
Jan 01 00:00:35 3 14 0 Using pseudo random generator. See "random" option
Jan 01 00:00:35 5 14 0 initializing IPsec... done
Jan 01 00:00:35 5 14 0 IPsec: Initialized Security Association Processing.
Jan 01 00:00:35 2 14 0 Unable to load devn-smc9118.so: Library cannot be found
And again, couldn't find the devn-smc9118.so in the QNX640 installation.
Is it not the correct bsp?
After importing the BSP to the IDE I added the necessary DLLs, Shared Libraries and Binaries, and built the project, but
as I mentioned I didn't find the files that the logs are complaining about.
Thanks you for your assistance.
11/26/2009 6:34 AM
post42628
I have provided additional information including logs, can you please take a look and tell me if I am using the correct
bsp, or what might be the problem with my configuration?
Thank you.
