Forum Topic - MDI Interface and emu phy access:
In our mpc8548 target board, MPC’s MII Bus is connected to a PHY and to a Switch.
The current trunk of mpc85xx network driver contains emu_phy, comment says this emu_phy can be used to configure the
switch connected at the MII BUS
We are not clear on how to use emu_phy/MDI utility (MII Read/Write) to configure the switch and the PHY
Kindly help us, give us a pointer
Regards
Senthil
RE: MDI Interface and emu phy access
The switch has to be configured via its own firmware. The phy_regs
structure is setup with default information to fake a PHY read
operation.
Sent: Friday, November 20, 2009 10:23 AM
To: drivers-networking
Subject: MDI Interface and emu phy access
In our mpc8548 target board, MPC's MII Bus is connected to a PHY and to
a Switch.
says this emu_phy can be used to configure the switch connected at the
MII BUS
Regards
Senthil
Networking Drivers
http://community.qnx.com/sf/go/post42315
Re: MDI Interface and emu phy access
we are trying to access the switch via MDI utilities(read/write) functions which has already registered in mpc85xx
code(mpc85xx_mii_read/write  functions).
I have attached below sample code, which will access the mpc85xx mdi read/write function. (Registered via
MDI_Register_Extended  mpc85xx/mii.c).
 Sample Code
 int mpc85xxphy_attach(struct device *parent, struct device *self, void *aux){
    struct ifnet *ifp = NULL;
    uint16_t  id2,phyid;
    mpc85xx_dev_t   *mpc85xx = NULL;
    int status = 0;
    phyid = 0x00; /* tsec0 = phyid = 0x00 */
   /* for getting the mpc85xx device structure */
    ifp = ifunit("tsec0");
    mpc85xx = ifp->if_softc;
   /* Accessing the registered MDI utility read function. */
    id1 = mpc85xx->mdi->Read(mpc85xx, phyid, MDI_PHYID_2);
    printf( "mdi Phy value :[%x]\n",id2);
Note :
We have an io-pkt entry function which will invoke dev_attach function, in turn invokes our mpc85xxphy_attach function.
While accessing the mpc8xx_mii_read/write function,its getting crashed.
 Error message
# mount -T io-pkt /tmp/devnp-mpc85xx_mii.so
Process 806926 (io-pkt-v4-hc) terminated SIGSEGV code=1 fltno=11 ip=480d1a3c(io-pkt-v4-hc@main+0x7c0) ref=00000000
mount: Can't mount / (type io-pkt)
mount: Possible reason: No such process
Can you give suggestions on the following
1)       Is that any possible to get mpc85xx_dev_t structure other than ifunit function from separate driver. Since we
are getting crash on accessing mpc85xx mdi structure read/write.
2)       How to access MDI utilities/library (Ex: MDI_FindPhy, MDI_AutoNegotiate) for tsec0 from separate driver.
3)     emu_phy usage related to switch attached to the MDIO Interface.
Thanks and Regards
K.Senthil.
Sounds like it's time you fire up the trusty old gdb. :-)
/P
Hi ,
we cant able to load the devnp-xx.so via gdb.
If know tell me how to debug the specifcally devnp-xxx.so.
Please tell me the procedures for debuggging drivers(.so files).
Because in gdb we tried mount -T io-pkt /lib/dll/devnp-xx.so,
it throws unknown command in gdb.
Thanks and Regards
K.Senthil
>>>gdb devnp-xxx.so
Thanks and Regards
K.Senthil
On Wed, Nov 25, 2009 at 10:05:06AM -0500, Senthil K wrote:
> Hi ,
Try 'shell  mount -T io-pkt /lib/dll/devnp-xx.so' from
gdb or run the mount command from another shell or
start the driver from the io-pkt command line.
Senthil K wrote:
> Hi ,
There's really not much special about how to debug in QNX. Please see
the gdb documentation:
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/g/gdb.html
http://www.qnx.com/developers/docs/6.4.1/neutrino/prog/using_gdb.html
There are also several resources on the web about gdb. This is however,
not a forum for teaching debugging techniques, although I'll try to
provide some helpful pointers...
Debugging a network driver is really the same as debugging any shared
library, not much special there.
If you had dumper running while the crash happened you should be able to
find a core file for io-pkt-v4-hc (where it is located depends on how
dumper was started, see pidin -p dumper arg).
That's because "mount" is not a command in gdb, its a program that's got
nothing to do with gdb. Please learn about gdb in the above links.
If you want to debug mount, you start 'gdb mount' and inside gdb you
would use the "run" command.
But you don't want to debug mount, you want to debug the stack which has
your shared library (in this case a network driver) being loaded into
it. Mount will make io-pkt dl_open() the driver. Or skip the whole use
of mount and simply load the driver via the io-pkt command line like
Sean suggested.
>>>> gdb devnp-xxx.so
See above links about what command line arguments gdb takes.
Hope this helps!
/P
