how to bring up network (QNX 6.3.2. - target PPC5200B)
11/09/2009 10:38 AM
post41618
Hi folks,
sorry fo tho old QNX-version I have to use .....but I have some problems bringing up the network on an PPC5200B board
(with slightly changed BSP).
While trying to make some network travel using ping or telnet I only see some ARP requests on wireshark. These requests
are answered by the partner but that's all. No communication ever will be established.
What else do I have to push on for get it working? What could be wrong with my mount command?
I try to start the driver as follows:
io-net -dmpc5200 mac=ca6a7e000144,verbose -ptcpip #-pqnet
waitfor /dev/io-net/en0 10
mount -T io-net devn-mpc5200.so
ifconfig en0 192.168.0.100
QNX complains about impropper mounting:
mount: Can't mount / (type io-net)
mount: Possible reason: Invalid argument
No error is vissible at sloginfo: ('mpc5200_init ...' is no error, it was coded in the driver just for see it starting)
# sloginfo
Time Sev Major Minor Args
Jan 01 00:00:00 2 10 0 mpc5200_init ...
Jan 01 00:00:00 5 10 0 Motorola MPC5200
Jan 01 00:00:00 5 10 0 Vendor .............. 0x0
Jan 01 00:00:00 5 10 0 Device .............. 0x0
Jan 01 00:00:00 5 10 0 Revision ............ 0x0
Jan 01 00:00:00 5 10 0 Interrupt ........... 0x45
Jan 01 00:00:00 5 10 0 Interrupt ........... 0x8c
Jan 01 00:00:00 5 10 0 MAC address ......... ca6a7e 000144
Jan 01 00:00:00 5 10 0 devn-mpc5200: MII transceiver found at address 0.
Jan 01 00:00:00 5 14 0 tcpip starting
Jan 01 00:00:00 3 14 0 Using pseudo random generator. See "random" option
Jan 01 00:00:00 2 10 0 devn-mpc5200: no MAC address, you must specify one
Jan 01 00:00:03 5 10 0 devn-mpc5200: link up (100 BaseT Full Duplex)
Wireshark's info:
81047 8250.775647 ca:6a:7e:00:01:44 Broadcast ARP Who has 192.168.0.4? Tell 192.168.0.100
Ping ends in that mannor:
# ping 192.168.0.4
PING 192.168.0.4 (192.168.0.4): 56 data bytes
ping: sendto: Host is down
thanks in advance
--jens
