Forum Topic - Error while loading sample driver using io-pkt-v4 command:
I have couple of question
Question -1
While loading sample ethernet driver (devnp-sam.so) via io-pkt-v4 command it throws an error.
command:
io-pkt-v4 -d /lib/dll/devnp-pe.so
Error
Nov 09 17:26:14    5    14     0 tcpip starting
Nov 09 17:26:14    3    14     0 Using pseudo random generator.  See "random" option
Nov 09 17:26:14    5    21     0 run fault pid 892961 tid 2 signal 11 code 1 ip 0x80854b8 sbin/io-pkt-v4
Question 2
How to set the mac address for en0 interface via ifconfig command?
Thanks and Regards
K.Senthil
Re: Error while loading sample driver using io-pkt-v4 command
On Mon, Nov 09, 2009 at 06:54:36AM -0500, Senthil K wrote:
> Question -1
> command:
> Error
Time to fire up gdb.
> Question 2
# ifconfig wm0 link 00:01:02:03:04:05           <- add
# ifconfig wm0 link 00:01:02:03:04:05 active    <- activate
# ifconfig wm0 link 00:01:02:03:04:05 delete    <- delete
RE: Error while loading sample driver using io-pkt-v4 command
Indeed.  Before you start io-pkt ensure that
dumper is running.
After the fault occurs, look in /var/dumps/
for a file that looks like io-pkt-v4.core.
You can then run:
# gdb /sbin/io-pkt-v4 /var/dumps/io-pkt-v4.core
Hint #1:  compile your driver with "-g -O0" to make
the backtrace MUCH more helpful.
Hint #2: learn about a file called ~/.gdbinit
aboyd
Don't forget to turn off the sigsegv handler!!!!!
(-S option to io-pkt)
> dumper is running.
> You can then run:
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post41602
cburgess@qnx.com
You don't really need to - I never bother, anyways.
Just skip the first couple of frames in the
offending thread, which is the sigsegv handler.
aboyd
