Forum Topic - Sample Ethernet driver compilation in QNX Momentics:
Please tell  me how to compile sam.c(sample ethernet driver in QNX Momentics).
The following steps i itried it throws error.
1. Copy the iopkt build header files in to /usr/include directory and i gave make \
Error:No rule to make target.
Thanks and Regards
K.Senthil
Re: Sample Ethernet driver compilation in QNX Momentics
On Tue, Oct 20, 2009 at 06:35:34AM -0400, Senthil K wrote:
Which directions are those?  The build procedure
is documented here:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Source_Guide
Which Makefile are you using?  Do you even
have a Makefile?
Hi Sean,
I download the QNX 6.4.1 Source code.
I copied the sam(ethernet driver)  folder from the downloaded source code and create new project in QNX Momentics and
add the sam folder.
After add the sam folder,make file is already present in the folder.
I right click and gave the make.
I faced the error.
Thanks and Regards
K.Senthil
On Sun, Oct 25, 2009 at 10:25:42AM -0400, Senthil K wrote:
> Hi Sean,
add the sam folder.
> I faced the error.
I've never tried compiling it via the ide.  Maybe
someone else has some ideas.
I'm getting an error when compiling the sample driver sam.c under 6.4.1.
I get the error
In file included from C:/QNX641/target/qnx6/usr/include/io-pkt/iopkt_driver.h:35,
                 from C:/workspace/pci_network_driver/sam.c:20:
C:/QNX641/target/qnx6/usr/include/io-pkt/sys/systm.h:237: warning: 'struct lwp' declared inside parameter list
C:/QNX641/target/qnx6/usr/include/io-pkt/sys/systm.h:237: warning: its scope is only this definition or declaration,
which is probably not what you want
In systm.h, 'struct lwp' is not defined.  Its definition is inside a #ifndef __QNXNTO__ .. #endif so it is excludes
since __QNXNTO__ is defined during compilation.
Is the definition of 'struct lwp' supposed to be found somewhere other than systm.h?
Gary Anderson
If the only line in the file to be compiled is
  #include <io-pkt/iopkt_driver.h>
you get the same error.  It looks like the io-pkt header files may not work correctly with 6.4.1.
I suspect you don't have _KERNEL defined.
The header file inclusions for building drivers is somewhat... complicated... since it assumes that there's a lot of BSD
 kernel headers available for use.  It was simplified considerably by creation of a single header file that pulls in a
number of others, but it does require a specific order to the includes.  Have you modified the sample driver at all?
If you
before the sys/io-pkt.h include, does it make any difference?
  R.
Oops.  Ignore that previous e-mail.  I can see that this is what you were doing.  Make sure that you've got a clean
install in place as well and that none of the system headers have been modified.
  R.
> I get the error
Can you post the full make output?
Sean,
Your suspicion about _KERNEL not being defined did the trick.  I simply added #define _KERNEL at the beginning of sam.c
and it now compiles and produces a dot-so.
I'm trying to create an io-pkt driver for a shared memory (in PCIe space) interface between two processors so I'm
starting with sam.c.
Gary
On Wed, Nov 25, 2009 at 04:46:23PM -0500, gary anderson wrote:
> Sean,
c and it now compiles and produces a dot-so.
Since you're making a driver it should probably go in
CCFLAGS or the equivalent in your Makefile so that all files
are affected.
If you look in the prodroot_pkt.mk file one level above the sample directory, you can see
CCFLAGS += -D_KERNEL
the sample driver common.mk has
include $(PRODUCT_ROOT)/prodroot_pkt.mk
so this should be taken care of for you unless the makefiles have been modified somehow (?)
    Robert
