How to place only one fid in MME track session while using iPod to avoid unintentional repetition of iPod track sessions
06/04/2009 9:17 PM
post30913
Just wonder how to place only one fid in MME track session while using iPod to avoid unintentional repetition of iPod
track session, which mentioned by the development guide document of Aviage.
I am currently using Aviage 1.2 formal release version, and using the explore API functions to browsing iPod categories
, then create the corresponding file-base track session to play tracks on iPod. Due to the problem of iPods manage
their own track sessions, consequently, I am facing a problem of repeatedly playing tracks on the iPod as the example
below:
A, B, C, D, E
B, C, D, E
C, D, E
D, E
E
For solving the problem, the development guide of Aviage suggests that place only on fid in MME track session. It seems
there is no MME API function to do that directly. To attain this goal, does it mean we need to modify the trksessionview
table manually? And if yes, just wonder is there any suggested way to modify the table ? Thanks.
Chris
Re: How to place only one fid in MME track session while using iPod
06/05/2009 8:21 AM
post30946
You can create a file-based track session with only the "A" file in the
tracksession. (ie, don't add A through E, just A) When you play this
tracksession the MME will tell the iPod to play this file; the iPod will
oblige, adding the rest of the files in the same "directory" to its
playback engine automatically.
Ryan J. Allen
QNX Software Systems
Chris Li wrote:
categories, then create the corresponding file-base track session to play tracks on iPod. Due to the problem of iPods
manage their own track sessions, consequently, I am facing a problem of repeatedly playing tracks on the iPod as the
example below:
> A, B, C, D, E
> B, C, D, E
> C, D, E
> D, E
> E
seems there is no MME API function to do that directly. To attain this goal, does it mean we need to modify the
trksessionview table manually? And if yes, just wonder is there any suggested way to modify the table ? Thanks.
> Regards,
> Chris
> http://community.qnx.com/sf/go/post30913
Re: How to place only one fid in MME track session while using iPod to avoid unintentional repetition of iPod track sessions
06/05/2009 8:44 AM
post30948
> to avoid unintentional repetition of iPod track session, which mentioned by
> only on fid in MME track session. It seems there is no MME API function to do
This sounds like you are synchronizing the iPod and using library mode tracksessions. I would recommend that you instead
user "explorer mode" on the iPod and use file based tracksessions to play it. As well, you should use the "fnames=short
" on the iPod driver command line for optimal performance and only fetch the titles on an as needed process using
explorer mode.
When you are ready to play you can then use file based tracksessions and only add a single file. As well, you could add
a folder (i.e. "/Music/Songs") as the file to play and the iPod will play the whole folder. If you play a single file,
the iPod will start at that file and play the rest of the contents of the folder (more or less, there are some exception
with random mode, i.e. not all songs in the database view get loaded into the playback engine when random is enabled).
Finally, just to get going with FIDs (i.e. assuming you are synchronizing the iPod, again something I don't really
recommend) you can create a single FID traskession like this:
mmecli newtrksession l "SELECT 45 AS fid" assuming fid 45 is one of the entries from the iPod.
Gilles
06/05/2009 9:12 AM
post30954
>> place only on fid in MME track session. It seems there is no MME API
>> to modify the trksessionview table manually? And if yes, just wonder is
>tracksessions. I would recommend that you instead user "explorer mode" on
>use the "fnames=short" on the iPod driver command line for optimal
>explorer mode.
>only add a single file. As well, you could add a folder (i.e.
>folder. If you play a single file, the iPod will start at that file and
>exception with random mode, i.e. not all songs in the database view get
>the iPod, again something I don't really recommend) you can create a
>single FID traskession like this: mmecli newtrksession l "SELECT 45 AS
"select fid from library where fid=## limit 1" is another approach
Peter
06/08/2009 8:19 PM
post31172
Hi all,
Much thanks your information and advices.
> tracksessions. I would recommend that you instead user "explorer mode" on the
According to the requirement, I need to develop a way for users to browse the folders/tracks/playlists in the connected
mediastore, so I don't use any kind of synchronization method and instead, just fully rely on explore APIs and build up
a corresponding file-based track session to play tracks inside which based on the user selection.
> "fnames=short" on the iPod driver command line for optimal performance and
> only fetch the titles on an as needed process using explorer mode.
Yes, good idea. Previously I used "fnames=long" because it can get the track titles straightaway during exploring.
However, it really takes time to explore the iPod which has lots of tracks in a category (e.g., more than 5000 songs in
Songs category). The method of fetching the titles on demand is very helpful for this case or even just explore a range
of items (i.e, the ones need to be displayed on screen) but not all in the browsing category of the iPod.
> add a single file. As well, you could add a folder (i.e. "/Music/Songs") as
> file, the iPod will start at that file and play the rest of the contents of
> the folder (more or less, there are some exception with random mode, i.e. not
> is enabled).
For the case of playing tracks on iPods from a file-based track, to prevent unintentional repetition problem, create a
file-based track session with only one file inside will help, just a little bit concern about the random mode and repeat
mode. Not sure whether the iPod will shuffle or repeat all tracks in the current browsing list if the selected track
which added in the track session is not the first track in the list (i.e., the iPod only shuffles or repeats the
selected track and the tracks following that in the iPod playback engine, but not all tracks in the current browsing
category), thanks.
Chris
06/12/2009 4:35 PM
post31678
> unintentional repetition problem, create a file-based track session with only
> repeat mode. Not sure whether the iPod will shuffle or repeat all tracks in
> the current browsing list if the selected track which added in the track
> repeats the selected track and the tracks following that in the iPod playback
> engine, but not all tracks in the current browsing category), thanks.
If you have shuffle on and select a track in the database engine for playback, that track is normally put first and the
remainder of the database selection tracks (those before the one selected for playback as well as after) are all
shuffled. Basically, the iPod shuffles and repeats all tracks in the browsing category (if I understand your question).
Only one other point, if you are browsing the all songs, have random off and the current browsing (i.e. database)
selection has 5000 songs and you issue a play at index 2500, the playback engine will have 5000 songs and the one you
selected will be at index 1. However, if random was one, the playback engine could have less than 5000 songs, as iTunes
has a per song setting "don't include in shuffle mode" which the user can set. As well, some things like audiobooks or
podcasts, not sure anymore, are automatically excluded.
Gilles
