Failed to get album art from the track which resumed by mme_play_resume_msid( ) on iPod
05/26/2009 9:13 PM
post30103
Just found that if a track on an iPod is resumed playback by using mme_play_resume_msid( ) function, it would fail to
get the album art of track by using mme_metadata_image_load() function. The function returned success and mdimage_rid
was set, but the MME_EVENT_METADATA_IMAGE event reported the error as follows:
ptMME_event_metadata_image>error = 22
ptMME_event_metadata_image>mdinfo_irid = 2
ptMME_event_metadata_image->url.len = 0
(ptMME_event_metadata_image is a pointer pointed to mme_event_metadata_image_t)
No problem for the case of the track session is built up by client application which using appropriate API functions.
BTW, I am using mme_metadata_getinfo_current( ) with asynchronous way to get the album art info in all cases, all info
can be achieved successfully. The Aviage I am using is version 1.2 alpha build 20.14.
Chris
Re: Failed to get album art from the track which resumed by
05/27/2009 8:40 AM
post30124
On Tue, 26 May 2009, Chris Li wrote:
>Hi,
>mme_play_resume_msid( ) function, it would fail to get the album art of
>success and mdimage_rid was set, but the MME_EVENT_METADATA_IMAGE event
Hi Chris,
This should be fixed in the final release. It was noted and corrected
around the Apr 24th time frame for a build. (PR 66925)
The 20.14 alpha looks like it was posted in March, so the next update
should have the fix for you.
Thanks for the feedback and detailed description.
Peter
>get the album art info in all cases, all info can be achieved
>Regards,
>Chris
>General
>http://community.qnx.com/sf/go/post30103
Re: Failed to get album art from the track which resumed by mme_play_resume_msid( ) on iPod
05/28/2009 1:52 AM
post30207
Have tested it on the latest release of Aviage MM version 1.2 and the issue has been solved. That's great, however, it
comes with another issue which about image splash on iPod.
Actually, I call mme_play_resume_msid() to resume playback right after the iPod is connected and with the album art
loading routine follows on. If the resumed track is the one with the album art (size of 128X128 pixels), for a big color
image (size of 310X136 pixels) which need to be splashed on iPod screen, it just fails to be splashed. For a small
splash image like size of 166X71 pixels, it doesn't have such problem. So I thought the album art loading process might
interrupt the image splashing process and cause the iPod can not splash the image on its screen.
Just wonder any advice for solving this problem, much thanks.
Chris
05/28/2009 10:02 AM
post30233
> iPod is connected and with the album art loading routine follows on. If the
> big color image (size of 310X136 pixels) which need to be splashed on iPod
> screen, it just fails to be splashed. For a small splash image like size of
> loading process might interrupt the image splashing process and cause the iPod
Hi Chris,
Just to explain the process. When loading a splash screen, we try to do it as a background task (it can take several
seconds or more, especially on serial connections, but even on USB it we still need to wait for iPod ACKs for data
packets and what not, so it isn't just a simple transfer at 400 mbits/second). Anyway, all this to say that usually time
to audio is what is important and we try to allow other commands into the iPod while loading the splash screen. This
does have the potential to delay the splash screen loading.
Can you specify which iPod model you are using? Apple has put some limitation in *some* models of iPods that if the
splash screen isn't loaded completely in the first 15 seconds, it will not show. As a second note, I've noticed that the
iPods tend to be single minded when requesting album art, they don't send time updates or respond to any of our
requests until they are done transmitting the album art.
My initial guess would be that you are using something like an nano 3rg Gen or Classic 5th gen, and it simply isn't
showing the splash screen because it took too long to load. Also, if you have verbosity on the ipod driver command line
(i.e. especially level 5 say) and it logs every byte of data it sends/receives, this slows things down as well.
Gilles
One
05/28/2009 7:58 PM
post30294
Hi Gilles,
Thanks your info.
Yes, the iPods I am using are 3rd Gen Nano, iPod Classic and 5th Gen iPod, they all have the same problem. From the
Apple spec, it claims the splash image must be loaded with 15 seconds, according to the transmit rate of high speed USB
port, it should satisfy the time requirement.
However, it seems the fact is that it not only needs to load the whole image data on iPod within 15 seconds but also
can not interrupt the whole loading process like insert an get album art process which significant take long for iPod to
finish the whole job. I got a feeling for that from the Apple spec about the saying of use of SetDisplayImage command
should be limited to drawing bitmap image only immediately after entering extended mode. So I thought its process is not
interruptable, not sure whether my assumption is correct or not, thanks.
Chris
05/28/2009 9:47 PM
post30296
> they all have the same problem. From the Apple spec, it claims the splash
> speed USB port, it should satisfy the time requirement.
It isn't quite that fast. We also wait for acknowledgement that the iPod accepted each image segment sent. Just like
when we read an image from the iPod it doesn't go at wire rate neither.
> data on iPod within 15 seconds but also can not interrupt the whole loading
> iPod to finish the whole job.
Well, you can query the iPod in between image segments, or sent it commands, and it does still work, as long as the
whole things gets there in the first 15 seconds.
> about the saying of use of SetDisplayImage command should be limited to
> thought its process is not interruptable, not sure whether my assumption is
The iPod does allow interleaved commands, this works and has been tested, so we do allow this in the driver. We could
have chosen to lock out any iPod calls at the driver level until the whole thing is transmitted, but this would affect
time to audio. In many applications (especially automotive comes to mind) time to audio is critical and if you asked the
automotive customers I know that some might favour time to audio over a splash screen. Splash screens don't even work
on iPod touch or iPhone anyway.
If you said that the splash screen is more important than early audio to you, we could consider an option to the iPod
driver to immediately fully load the splash screen before it allows any other commands. Or perhaps a way to determine if
the splash screen is done loading (i.e. you might want to issue the resume() command but only load the artwork form the
iPod once you knew the splash screen was loaded, to get some form of early audio). Unfortunately we've just released 1.
2, and it doesn't have these features. I think the best option for MW 1.2 driver is to perhaps delay slightly after you
call mme_play_resume_msid() before you request artwork.
Gilles
06/03/2009 1:53 AM
post30652
Hi Gilles,
Much thanks your detail explanation.
Yes, the current workaround for my application is it has to be added a time delay (like 2 seconds) before calling
mme_play_resume_msid() to allow the iPod finishes the splash process first and then do the resume playing a track with
an album art later while plug in the iPod.
Hopefully in the future Aviage release, it will has much option for that like the client has a way to know when the
iPod finishes splashing an image, or maybe just fix the issue of it can not splash an image on iPod and get an album
art from the iPod simultaneously if both processes are finished within 15 seconds.
Regards
Chris
06/03/2009 12:30 PM
post30716
> the client has a way to know when the iPod finishes splashing an image, or
> album art from the iPod simultaneously if both processes are finished within
> 15 seconds.
Hi Chris,
I've filled a problem report internally so that we don't lose track of the issue.
Gilles
