Running my h264 decoder with MME
04/22/2009 9:51 AM
post27733
Hi Peter,
I have tried running h264 decoder filter with MME. It is not able to load the DLL(it is there in the DLL dir). What is
the issue?
io-media-local.cfg, I have added following lines
format {
url = "*.264"
parser = "h264_decoder"
keepdll {
name = "h264_decoder"
optional = yes
I have started MME with folowing commands
io-fs-media -d tmp -cpages=4 -cbundles=0
qdb -c /db/qdb.cfg -v -Otempstore=/fs/tmpfs -Rset
mcd /tmp/stage/etc/mme/mcd.conf
io-media-generic -DD -c /tmp/stage/etc/io-media-local.cfg -M mmf,dlldir=/tmp/stage/armle/lib/dll/mmedia
mme-generic -c /tmp/stage/etc/mme.conf
See the error log below
Jan 01 00:39:34 5 27 0 MME:mmpl_connect(236): Thread 11 connecting to database.
Jan 01 00:39:34 5 27 0 MME:mmpl_connect(247): Thread 11 connected to database.
Jan 01 00:39:34 5 27 0 MME:ocb_calloc(70): Connection to MME opened (ocb 2bc580).
Jan 01 00:39:34 5 27 0 MME:io_handle_msg(613): RCV -> MME_IOMSG_TYPE_PLAY_FILE: "msid=1, filename=BA_MW_D.264"
Jan 01 00:39:34 5 27 0 MME:mme_ms_unlock(702): Unlock call for media store 1 of type playback.
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd STOP
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Dcmd STOP returning 0
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd GETSTATUS
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Dcmd GETSTATUS returning 0
Jan 01 00:39:34 5 27 0 MME:_suspend_sync(1124): Suspending sync: ccid 1, msid 1
Jan 01 00:39:34 5 27 0 MME:mme_ms_lock(541): Lock call for media store 1 of type playback.
Jan 01 00:39:34 5 27 0 MME:_getgraph(3373): Detaching input from graph on controlcontext 1
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETSPEED
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Dcmd SETSPEED returning 0
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETNOTIFICATION
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Dcmd SETNOTIFICATION returning 0
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd ATTACHINPUT
Jan 01 00:39:34 5 27 0 MME:cleanup_thread(262): Got pulse with code 0 and index 0.
Jan 01 00:39:34 6 20 1 io-media-generic/mmf: URL '/media/drive/BA_MW_D.264' matches pattern '*.264'
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Tag 'format' has 0 kids
Jan 01 00:39:34 6 20 1 io-media-generic/mmf: Setting long resource 'StreamerStickyError' (value='1')
Jan 01 00:39:34 5 20 1 io-media-generic/trackplayer: Skipping video subgraph because there is no video device
specified.
Jan 01 00:39:34 6 20 1 io-media-generic/mmf: Setting long resource 'TrickPlayVolumeFade' (value='10')
Jan 01 00:39:34 5 20 1 io-media-generic/mmf: Configuring the queue for -1 bytes, lw = 0, hw = 0.
Jan 01 00:39:34 4 20 1 io-media-generic/trackplayer: Couldn't load the h264_decoder filter (based on the
parser tag)
Jan 01 00:39:34 7 20 1 io-media-generic/trackplayer: Hint mode allows a filter search for this input
Jan 01 00:39:36 6 20 1 io-media-generic/mmf: Setting long resource 'AVSyncDelay' (value='0')
Jan 01 00:39:36 7 20 1 io-media-generic/mmf: Resource 'AVSyncDelay' is not supported (but optional)
Jan 01 00:39:36 5 20 1 io-media-generic/trackplayer: Skipping video subgraph because there is no device
specified.
Jan 01 00:39:36 7 20 ...
RE: Running my h264 decoder with MME
04/22/2009 10:18 AM
post27741
What happens if you remove the "optional=yes" line?
From: Venkatarao Patnaik Balivada [mailto:community-noreply@qnx.com]
Sent: April 22, 2009 9:52 AM
To: general-multimedia
Subject: Running my h264 decoder with MME
Hi Peter,
load the DLL(it is there in the DLL dir). What is the issue?
format {
url = "*.264"
keepdll {
optional = yes
returning 0
code 0 and index 0.
'format' has 0 kids
video subgraph because there is no video device specified.
load the h264_decoder filter (based on the parser tag)
resource...
Re: RE: Running my h264 decoder with MME
04/22/2009 10:44 AM
post27751
Hi Peter,
Still doesn't work.
There could be issue with some interface function problem? Because I specified filter as "wav_parser" for *.264, still
it gives error saying couldn't load the wav_parser filter. Before loading the filter, does it try to match with input
channel of the filter, where it is failing.?
Re: Running my h264 decoder with MME
04/22/2009 11:24 AM
post27757
Venkatarao Patnaik Balivada wrote:
> Still doesn't work.
I didn't expect removing the "optional" line to make it work; I was
hoping it would help us narrow down the nature of the failure.
The "Couldn't load the h264_decoder filter..." message is not entirely
accurate -- all it really means that a library function that is supposed
to load the named filter and connect it to the output of the previous
filter in the graph has failed. There are several possible reasons it
could fail:
#1 The named filter DLL does not exist
#2 The DLL exists but failed to load
#3 The DLL could be loaded but turned out incompatible with the Addon
Interfaces (AOI) library
#4 The DLL was recognized by the AOI library but turned out not to
implement enough interfaces to be recognized as an MMF filter
#5 The DLL is a filter but the creation of a filter instance fails for
some reason
#6 The filter was actually created but then it rejected the output from
the previous filter (io-media wants the RateStream() or RateFormat()
function to return a rating of at least 20).
Without the "optional=yes" line, io-media will fail to start up unless
the DLL is loaded and confirmed to be a correct AOI DLL. If removing
the line didn't change the error messages that you're seeing, that means
that the problem must be #4, #5, or #6. You can narrow it down by
adding some debug messages to the interface functions in your filter.
In particular, if your Create() function never gets called, that would
mean #4. If you tell me which of your functions get called and which
ones don't, that should give me a good idea of what the problem is.
04/22/2009 11:38 AM
post27762
Thanks Peter. I will try and let you know tomorrow. Now I have got some idea how I can put debug messages, found in
aoi_errlog.h.
04/22/2009 12:00 PM
post27764
aoi_errlog.h.
Keep in mind that if you use the AO_LOG() macro, AO_LOG_DEBUG1 and
AO_LOG_DEBUG2 level messages are completely #ifdefed out by default --
you can switch them on by #defining AO_LOGLVL before you include
<aoi/aoi_errlog.h>. (Or you can just call AoLog() directly.)
Wojtek (not Peter)
04/23/2009 7:54 AM
post27858
I feel it is better to try with MP4 file, otherwise I need to write some stubs.
I am trying with MP4 file which has H264 video content.
04/23/2009 9:16 AM
post27871
Hi Peter,
I could play the H.264 mp4 file with VLC media player.
Does the mp4_parser handle H264 AVC1 format? I debugged the parser and it fails in the following condition as has_esds
field found to be zero. I don't know much about MP4 format.
if (fu->file_info->tracks[i].has_esds && esds->has_type4) {
mp4v_type = esds->descr_type_4.object_type_id;
AoLog(AO_LOG_DEBUG1,"mp4_parser->SetChannelParameters() mp4v_type = %d", mp4v_type);
04/24/2009 4:47 AM
post27957
Peter,
Figured out that MP4 file has quicktime mov format, I tried another mp4 file, it seems to detect it properly. But to
enable video stream to work, I need to specify output device.
Can you give some quick help, what all required to do to enable video output device.
Do I need to include in mme_data.sql?
I will try first include display device in BSP.
04/24/2009 7:14 AM
post27969
Hi Peter,
I have added display driver. I modified mme_data.sql to add following line
INSERT INTO outputdevices(type, permanent, name, devicepath) VALUES(1, 1, 'defaultoutput2', 'gf:0000,0000,0');
device entry found from
# ls -l /dev/io-display/
total 0
crw-rw---- 1 0 0 0, 1 Jan 01 00:59 0000,0000,0
Then I tried to decode MP4 file, it still gives error saying "no device specified".
Jan 01 00:56:36 6 20 1 io-media-generic/mmf: URL '/media/drive/a1vts_750_001.mp4' matches pattern '*.mp4'
Jan 01 00:56:36 7 20 1 io-media-generic/trackplayer: Tag 'format' has 0 kids
Jan 01 00:56:36 6 20 1 io-media-generic/mmf: Setting long resource 'StreamerStickyError' (value='1')
Jan 01 00:56:36 5 20 1 io-media-generic/trackplayer: Skipping video subgraph because there is no video device
specified.
Jan 01 00:56:36 6 20 1 io-media-generic/mmf: Setting long resource 'TrickPlayVolumeFade' (value='10')
Jan 01 00:56:36 5 20 1 io-media-generic/mmf: Configuring the queue for -1 bytes, lw = 0, hw = 0.
Jan 01 00:56:36 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() num_vid_tracks = 1,
num_aud_tracks = 1
Jan 01 00:56:36 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() fourcc = mp4v
Jan 01 00:56:36 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() fourcc = mp4a
Jan 01 00:56:36 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() mp4v_type = 32
Jan 01 00:56:36 5 20 1 io-media-generic/aoi: MP4Parser: max sample size = 18429.
Jan 01 00:56:36 5 20 1 io-media-generic/aoi: MP4Parser: max sample size = 403.
Jan 01 00:56:36 6 20 1 io-media-generic/trackplayer: Loaded the mp4_parser filter based on the parser tag
Jan 01 00:56:36 6 20 1 io-media-generic/mmf: Setting long resource 'AVSyncDelay' (value='0')
Jan 01 00:56:36 5 20 1 io-media-generic/trackplayer: Skipping video subgraph because there is no device
specified.
Jan 01 00:56:36 7 20 1 io-media-generic/trackplayer: No video stream found.
Jan 01 00:56:36 7 20 1 io-media-generic/trackplayer: Found audio stream.
04/24/2009 8:28 AM
post27975
> Hi Peter,
> total 0
> specified".
> has 0 kids
> SetChannelParameters() num_vid_tracks = 1, num_aud_tracks = 1
> size = 18429.
> size = 403.
> subgraph because there is no device specified.
> found.
> stream.
It's still not picking up your graphics device. There is another entry to modify in the mme_data.sql file:
INSERT INTO zoneoutputs(zoneid, outputdeviceid) SELECT 1, outputdeviceid FROM outputdevices WHERE name='defaultoutput2';
04/24/2009 9:10 AM
post27982
Still it doesn't work. device entry need to be non-zero ids? Is that a problem?
> > Hi Peter,
> > total 0
> > specified".
> > has 0 kids
> video
> > size = 18429.
> > size = 403.
> video
> stream
> > found.
> > stream.
04/24/2009 9:38 AM
post27991
> > > Hi Peter,
> > > total 0
> > > specified".
> 'format'
> > > has 0 kids
> resource
> > video
> resource
> queue
> sample
> > > size = 18429.
> sample
> > > size = 403.
> resource
> > video
> > stream
> > > found.
> > > stream.
> FROM
Is the entry iin your /dev/io-display directory actually 0000,0000,0? Can you send an updated slog from the newest
failure, it might give us some more clues.
04/24/2009 9:46 AM
post27994
Yes you are right.
See the slog below
Jan 01 00:01:38 7 20 1 io-media-generic: open('graphs/trackplayer/default')
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph create function
Jan 01 00:01:38 6 20 1 io-media-generic/trackplayer: Created graph instance 'default'
Jan 01 00:01:38 6 20 1 io-media-generic: open( 'graphs/trackplayer/default' ): success
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd GRAPHOPTIONS
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Dcmd GRAPHOPTIONS returning 0
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETNOTIFICATION
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Dcmd SETNOTIFICATION returning 0
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETTRANSITION
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Dcmd SETTRANSITION returning 0
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd CAPABILITIES
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Dcmd CAPABILITIES returning 0
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd ATTACHOUTPUT
Jan 01 00:01:38 5 20 1 io-media-generic/mmf: writer hint snd:* found
Jan 01 00:01:38 6 20 1 io-media-generic/mmf: URL 'snd:/dev/snd/pcmPreferredp' matches pattern 'snd:*'
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Dcmd ATTACHOUTPUT returning 0
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETVOLUME
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Dcmd SETVOLUME returning 0
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETSPEED
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Dcmd SETSPEED returning 0
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd GETSTATUS
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Dcmd GETSTATUS returning 0
Jan 01 00:01:38 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd ATTACHINPUT
Jan 01 00:01:40 6 20 1 io-media-generic/mmf: URL '/media/drive/a1vts_750_001.mp4' matches pattern '*.mp4'
Jan 01 00:01:40 7 20 1 io-media-generic/trackplayer: Tag 'format' has 0 kids
Jan 01 00:01:40 6 20 1 io-media-generic/mmf: Setting long resource 'StreamerStickyError' (value='1')
Jan 01 00:01:40 5 20 1 io-media-generic/trackplayer: Skipping video subgraph because there is no video device
specified.
Jan 01 00:01:40 6 20 1 io-media-generic/mmf: Setting long resource 'TrickPlayVolumeFade' (value='10')
Jan 01 00:01:40 5 20 1 io-media-generic/mmf: Configuring the queue for -1 bytes, lw = 0, hw = 0.
Jan 01 00:01:40 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() num_vid_tracks = 1,
num_aud_tracks = 1
Jan 01 00:01:40 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() fourcc = mp4v
Jan 01 00:01:40 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() fourcc = mp4a
Jan 01 00:01:40 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() mp4v_type = 32
Jan 01 00:01:40 5 20 1 io-media-generic/aoi: MP4Parser: max sample size = 18429.
Jan 01 00:01:40 5 20 1 io-media-generic/aoi: MP4Parser: max sample size = 403.
Jan 01 00:01:40 6 20 1 io-media-generic/trackplayer: Loaded the mp4_parser filter based on the parser tag
Jan 01 00:01:40 6 20 1...
04/24/2009 9:53 AM
post27996
The system is trying to hook up your decoder to the audio stream. Can you take the modifications to the config file out
and change the Rating function in your h264 decoder to accept the AVC1 fourcc. That should be sufficient to fix this
problem (assuming you're using the mp4 parser and using h264 mp4 files).
04/24/2009 10:07 AM
post28001
I understand that. But it is not finding video stream before that, because it says "no device specified".
04/24/2009 10:29 AM
post28009
After you updated your mme_data.sql file, did you delete your database? You'll need to do that so that your changes can
be used.
04/27/2009 8:27 AM
post28116
Hi Andrian Boak,
Thanks. It worked. I think I have come to a stage where I can debug my decoder now.
04/28/2009 9:38 AM
post28227
Now I am getting problem with gf_writer filter. It fails in CreateGFSurfs(), fails in this condition, what could be the
problem?
if (gf_layer_update(f->user->layer, 0) != GF_ERR_OK) {
AO_LOG(AO_LOG_ERROR,"failed to update layer.");
return MM_EINVAL;
Also see the error log below.
Time Sev Major Minor Args
Jan 01 00:00:55 7 20 1 io-media-generic: open('graphs/trackplayer/default')
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph create function
Jan 01 00:00:55 6 20 1 io-media-generic/trackplayer: Created graph instance 'default'
Jan 01 00:00:55 6 20 1 io-media-generic: open( 'graphs/trackplayer/default' ): success
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd GRAPHOPTIONS
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Dcmd GRAPHOPTIONS returning 0
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETNOTIFICATION
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Dcmd SETNOTIFICATION returning 0
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETTRANSITION
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Dcmd SETTRANSITION returning 0
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd CAPABILITIES
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Dcmd CAPABILITIES returning 0
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd ATTACHOUTPUT
Jan 01 00:00:55 5 20 1 io-media-generic/mmf: writer hint gf:* found
Jan 01 00:00:55 6 20 1 io-media-generic/mmf: URL 'gf:0000,0000,0?layer=1&aspn=72&aspd=77&sat=25' matches pattern 'gf:*'
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Dcmd ATTACHOUTPUT returning 0
Jan 01 00:00:55 1 27 0 MME:_setiomoutputattr(5725): Output device type 2 not supported
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd SETSPEED
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Dcmd SETSPEED returning 0
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd GETSTATUS
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Dcmd GETSTATUS returning 0
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Calling graph handler for dcmd ATTACHINPUT
Jan 01 00:00:55 6 20 1 io-media-generic/mmf: URL '/media/drive/test.mp4' matches pattern '*.mp4'
Jan 01 00:00:55 7 20 1 io-media-generic/trackplayer: Tag 'format' has 0 kids
Jan 01 00:00:55 6 20 1 io-media-generic/mmf: Setting long resource 'StreamerStickyError' (value='1')
Jan 01 00:00:55 2 20 1 io-media-generic/trackplayer: Skipping audio graph -- no audio device.
Jan 01 00:00:55 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() num_vid_tracks
= 1, num_aud_tracks = 0
Jan 01 00:00:55 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() fourcc = avc1
Jan 01 00:00:55 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() escaped 0!
Jan 01 00:00:55 5 20 1 io-media-generic/aoi: MP4Parser: max sample size = 19295.
Jan 01 00:00:55 6 20 1 io-media-generic/trackplayer: Loaded the mp4_parser filter based on the parser tag
Jan 01 00:00:55 6 20 1 io-media-generic/mmf: Setting long resource 'AVSyncDelay' (value='0')
Jan 01 00:00:55 5 20 1 io-media-generic/trackplayer: Skipping audio subgraph because there is no device
specified.
Jan 01 00:00:55 7 ...
04/28/2009 9:41 AM
post28229
On Tue, 28 Apr 2009, Venkatarao Patnaik Balivada wrote:
>Hi,
the problem?
> return MM_EINVAL;
Can you check and see if io-media-generic is still running after that
sequence of events.
If it is not, running dumper will allow you to collect information about
the state of executables when they exited abnormally. (see the docs on
dumper)
Peter
>Jan 01 00:00:55 6 20 1 io-media-generic/aoi: mp4_parser->SetChannelParameters() num_vid_tracks = 1,
num_aud_tracks = 0
>Jan 01 00:00:55 6 20 1 io-media-generic/aoi:...
04/29/2009 6:25 AM
post28305
I got the core dump file. But I couldn't find gdb to run on the target.
Should I run ntoarm-gdb on the host?
Instead of trying this, I want to understand the root cause of this.It might have crashed due to some bug in my decoder,
I can debug that.
My basic question is, why is MME iterating through each output format, if one of them (I need I420) is supported it
should stop and connect, right? Is it that none of the formats are supported by gf_writer?
It is difficult for me to debug video writer etc.
I need to write I420 output, can I write to a file instead of gf-writer, through the mmecli utility? OR I need to write
seperate app?
04/29/2009 7:30 AM
post28309
Can I use rawfile_writer to write my decoded output to a file?
04/29/2009 7:37 AM
post28310
I just found one sampleapp "audio_out", should I write similar app to write the video output to a file? OR mmecli can
write to a file?
04/29/2009 8:45 AM
post28315
On Wed, 29 Apr 2009, Venkatarao Patnaik Balivada wrote:
>Hi,
>Should I run ntoarm-gdb on the host? Instead of trying this, I want to
>my decoder, I can debug that.
Debugging has to run on the host system and not on the target.
Using the debugger you should be able to see what calling function the
fault occured in which would help you indentify what should be looked at
first.
ntoarm-gdb <full path to binary file> <full path to corefile>
>one of them (I need I420) is supported it should stop and connect, right?
>through the mmecli utility? OR I need to write seperate app?
I'm not aware of the ability to do that, but maybe someone else might be
able to point at some suggestions.
>General
>http://community.qnx.com/sf/go/post28305
04/29/2009 9:09 AM
post28320
I think in this case the debugger is not required. Because it returned one error from gf_writer function, which caused
the fault somewhere else. I want to debug only the first error. Only thing I don't understand is why is it iterating
through different video formats if I420 is supoorted by gf_writer(), which is the first format.
