Unable to play .wav file using wave command in TI J6 VAYU EVM
12/23/2016 6:07 AM
post117295
While i am playing a .wav file using wave command in TI J6 EVM board, we are unable to get the audio.
The following output shows in the terminal
#wave sample.wav
SampleRate = 44100, Channels = 2, SampleBits = 16
Format Signed 16-bit Little Endian
Frag Size 3760
Total Frags 64
Rate 44100
Voices 2
Mixer Pcm Group [Wave playback channel]
Playback Volume level shows 100:100 but we are unable to play the audio.
We are configure the board with latest BSP package(BSP SDK 6.6) and I have copied three files to micro SD card:
1)ifs-dra74x-vayu-evm.bin(Build the BSP SDK 6.6 then generated .bin file)
2)MLO
3)u-boot.img
I prepared the bootable micro SD card and build the BSP by using BSP user guide(Texas Instruments DRA74x and DRA75x
(Jacinto 6)Vayu EVM ). i referred the below mentioned link for BSP package and user guide.
http://community.qnx.com/sf/frs/do/listReleases/projects.bsp/frs.qnx_sdp_6_6_bsp_for_the_ti_dra74
Please let me know if any additional packages or patches are needed to add in BSP and additional playback information
about the same issue.
