Forum Topic - mm-renderer initial play position for HLS real-time broadcast type streams: (1 Item)
For an HLS real-time broadcast type stream, what is the play position at which mm-renderer starts playing the stream?
For example, is it 4 chunks back from the end of the first (sliding window) playlist file?
Configuration of interest is: iHE-AAC audio only stream with chunks of 10 seconds each.
