Forum Topic - mm-renderer authentication: (6 Items)
Is there a way to present mmrplay or mmrcli (i.e the mm-renderer utilities) with options and parameters from the
authentication result so that the encrypted audio is played?  Something like that would help to figure out how to use
and debug the mm-renderer API in our code.
RE: mm-renderer authentication
What kind of authentication?  What kind of encrypted audio?  Is it something you know mm-renderer already supports and
you just want to figure out how to use it, or is there a chance it might require new work inside mm-renderer?
> From: Dennis Kellly [mailto:community-noreply@qnx.com]
> Sent: Monday, February 22, 2016 8:47
> To: general-multimedia
> Subject: mm-renderer authentication
> with options and parameters from the authentication result so that the
> to use and debug the mm-renderer API in our code.
> http://community.qnx.com/sf/go/post115825
> To cancel your subscription to this discussion, please e-mail general-
> multimedia-unsubscribe@community.qnx.com
Curl, ssl.
"Is there a way to set the OPT_COOKIEFILE parameter normally configured via calling mmr_context_parameters()?"
From: Wojtek Lerch [mailto:community-noreply@qnx.com]
Sent: Monday, February 22, 2016 9:06 AM
To: general-multimedia@community.qnx.com
Subject: RE: mm-renderer authentication
> utilities) with options and parameters from the authentication result
> to figure out how to use and debug the mm-renderer API in our code.
General
http://community.qnx.com/sf/go/post115826
To cancel your subscription to this discussion, please e-mail general-multimedia-unsubscribe@community.qnx.com
mmrplay has a -C option to set context parameters:
# mmrplay -C OPT_COOKIEFILE=/foo/bar -C othereparam=othervalue http://foo.bar/foo.bar
mmcli has a ContextParameters command:
# mmcli -i mmrenderer_cli.so
000.000 Starting...
> ContextParameters OPT_COOKIEFILE=/foo/bar,othereparam=othervalue
> From: Dennis Kelly [mailto:community-noreply@qnx.com]
> Sent: Monday, February 22, 2016 9:08
> Curl, ssl.
> you know mm-renderer already supports and you just want to figure out
> renderer?
> > General
> http://community.qnx.com/sf/go/post115827
Re: RE: mm-renderer authentication
Thanks.  The examples are helpful.
Moving further along, we get the following error reported by mm-renderer:
Feb 24 12:21:31    2    20     2 mmr: AudioCard8: Start() DRM OPL failed err: 4052
What is this error trying to say and how can it be fixed?
