06/11/2015 8:55 AM
post113944
I'm trying to play video files of different format (.mp4, .mpg, .avi) but getting errors (see log below). As far as I
understand, I need to get an appropriate video decoder. Can someone tell how to get it or what else I'm missing? I'm
running QNX 6.6.0 with Apps and Media SDK on imx6 Sabrelite system.
# pps
slog2_api: cannot connect to slogger2 server...errno=No such file or directory
pps: slog2_register() failed (No such file or directory)
pps: NOTICE: PPS initializing
pps: NOTICE: PPS attaching /pps
pps: NOTICE: PPS starting
# mkdir -p /pps/services/multimedia/renderer
# mm-renderer -c -v -e
55.483[5] Initializing "Playlist engine plugin" (mmr-playlist-engine.so)
57.510[3] newctrl: dll(/lib/dll/mmedia/audio_streamer.so) already on clist
57.513[3] newctrl: dll(/lib/dll/mmedia/fildes_streamer.so) already on clist
57.589[3] newctrl: dll(/lib/dll/mmedia/http_streamer.so) already on clist
57.595[3] newctrl: dll(/lib/dll/mmedia/mdev_streamer.so) already on clist
57.596[1] Unable to Initialize the AOI streamers
57.641[5] Initialized "Playlist engine plugin" (mmr-playlist-engine.so)
57.651[5] Initializing "Single-track engine plugin" (mmr-track-engine.so)
57.652[5] Initialized "Single-track engine plugin" (mmr-track-engine.so)
57.715[5] Initializing "QNX MMF routing plugin" (mmr-mmf-routing.so)
57.715[5] load config from: /etc/system/config/aoi.conf
57.716[2] could not open /etc/system/config/aoi.conf for read.
57.717[5] MmInit: -1 DLL ignored from conf /etc/system/config/aoi.conf
57.779[3] newctrl: dll(/lib/dll/mmedia/audio_streamer.so) already on clist
57.837[3] newctrl: dll(/lib/dll/mmedia/fildes_streamer.so) already on clist
57.941[3] newctrl: dll(/lib/dll/mmedia/http_streamer.so) already on clist
57.944[3] newctrl: dll(/lib/dll/mmedia/mdev_streamer.so) already on clist
58.333[5] Could not load the file2b_streamer
58.334[5] Could not load the ivahd_video_decoder
58.337[5] Could not load the flac_parser
58.340[5] Could not load the mpeg2ps_parser
58.340[5] Could not load the mkv_parser
58.343[5] Could not load the asf_parser
58.346[5] Could not load the cloudfs_streamer
58.347[5] Could not load the dupfd_streamer
58.347[5] Could not load the rtsp_streamer
58.348[5] Could not load the remote_frame_writer
58.349[6] MMF router (built on Feb 22 2014 at 19:06:57) initialized
58.349[5] Initialized "QNX MMF routing plugin" (mmr-mmf-routing.so)
58.350[5] Initialization complete
# mmrplay -a "" -v screen: /root/html.mp4
36.291[6] New client ID '@control.17180098587' (@control.17180098587.n0.p229403.u0.g0)
36.294[6] Created context 'testplayer' owned by pid 229403 (0:0), mode=0500
36.295[6] Created context 'testplayer' as #0 for client '@control.17180098587'
36.297[6] Looking for a router for track /root/html.mp4 (2 track params)
36.297[6] Picked router 'MMF router' for track /root/html.mp4
36.298[6] Creating engine 'Single-track engine' for track /root/html.mp4
36.301[5] Found a hint for URL.
36.301[6] in apply_prefetch_parameters
36.311[5] IsStreamPlaylist: playlist initial tag not found... consider it a non playlist stream
36.314[5] Skipping audio graph -- no audio device.
36.343[5] Created the mp4_parser filter based on the parser tag
36.344[5] Skipping Audio subgraph because there is no device specified.
36.344[6] Video writer getting PID 229403.
36.344[5] Finding decoder for stream 1.
36.345[5] Skipping queue after parser.
36.345[5] Couldn't create the ivahd_video_decoder filter (based on the video-decoder tag), mmerr=4046, looking for
another one
36.369[2] Couldn't find a suitable video-decoder filter, mmerr=4047
36.370[5] Couldn't find a decoder for the parser output.
36.371[2] The create() call in plugin MMF router failed
36.371[3] Error 5 (mmf#4047) in mmr_input_attach():
36.371[3] Couldn't create routing plugin
36.371[2] Engine 'Single-track engine' failed to create
36.372[5] inputAttach failed (5, mmf#4047:Can't build graph)
/root/html.mp4:...
