12/05/2011 1:40 PM
post90426
I was trying to use MME for mp4 playback. but its failing with there errors. The logs are attached as follows:
I am using mmecli as the client for playback. can anybody please tell me whats going wrong ? The mp4_parser.so is the
default parser and the video+audio files is a good playable file.
Jan 01 00:00:06 2 20 1 io-media-generic/trackplayer: Error 10004:
Jan 01 00:00:06 2 20 1 io-media-generic/trackplayer: Couldn't find a parser for '/media/drive/salt-video.mp4'
Jan 01 00:00:06 2 27 200 MDP:metadata_get(801): Failed iom_get_track_info, errno = 5
Jan 01 00:00:06 3 27 200 MDP:mdp_mgr_metadata_get_int(1161): Error getting metadata for group 00000002 from "/
media/drive/salt-video.mp4": An external resource call used by the MDP failed. (10).
Jan 01 00:00:49 5 20 1 io-media-generic/mmf: writer hint snd:* found
Jan 01 00:00:49 5 20 1 io-media-generic/mmf: writer hint gf:* found
Jan 01 00:00:49 1 27 0 MME:_setiomoutputattr(5959): Output device type 2 not supported
Jan 01 00:00:49 5 20 1 io-media-generic/mmf: Configuring the queue for -1 bytes, lw = 0, hw = 0, thr = -1.
Jan 01 00:00:49 4 20 1 io-media-generic/trackplayer: Couldn't load the mp4_parser filter (based on the parser
tag), mmerr=4047
Jan 01 00:00:49 4 20 1 io-media-generic/trackplayer: Couldn't find a suitable parser filter, mmerr=4047
Jan 01 00:00:49 2 20 1 io-media-generic/trackplayer: Error 10004, 2, 4047:
Jan 01 00:00:49 2 20 1 io-media-generic/trackplayer: Couldn't create a linking filter for raw stream
Jan 01 00:00:49 2 27 0 MME:_attachinput(3782): Could not attach input (/media/drive///salt-video.mp4) to
controlcontext default (fid=2). errno=5
Jan 01 00:00:49 2 27 0 MME:_play(3224): Could not attach file '/media/drive///salt-video.mp4'
Jan 01 00:00:49 2 27 0 MME:_setgenericvalue(888): Send Error for request=2, value=0. errno 11
Arun
12/05/2011 1:52 PM
post90428
> the mp4_parser filter (based on the parser tag), mmerr=4047
Error 4047 (MM_ENFSF) means that the filter was loaded but didn't like your file. (Apologies for an inaccurate error
message...)
12/06/2011 2:19 PM
post90447
I was trying to use MME on an mp4(m4v) file playable on PC to be decoded and displayed through aviage. I am working on
arm target.
I am facing problems while decoding: logs are attached.
Can anyone point me where am I going wrong. I am using my own software video/audio decoder filter and the mp4_parser
provided with aviage
2 20 1 io-media-generic/aoi: fildes streamer seek: failing (22)
2 20 1 io-media-generic/aoi: fildes streamer seeking failing on StreamerStickyErrror resource set
5 20 1 io-media-generic/mmf: Configuring the queue for 1429093 bytes, lw = 285818, hw = 1143274, thr = -1.
4 20 1 io-media-generic/trackplayer: Couldn't load the video_decoder filter (based on the decoder tag), mmerr=
4047
5 20 1 io-media-generic/aoi: audio_decoder: RateFormat returning a rating of 60 for fourcc CA4M
5 20 1 io-media-generic/aoi: audio_decoder: EventListenerList returning type = MM_EV_VOICE_UPDATE
5 20 1 io-media-generic/aoi: in audio_decoder: SetInputFormat seeing aac format profile: 2 adts: 0
5 20 1 io-media-generic/aoi: audio_decoder: SetInputFormat AAC decoder fourcc:'CA4M' profile:29 adts:0 streamFmt
:'AAC_SF_RAW' nchannels:2 frate:44100hz
5 20 1 io-media-generic/aoi: audio_decoder: SetInputFormat audio card fourcc:'AWAR' nchannels:2 frate:44100hz
depth:16bits
5 20 1 io-media-generic/mmf: Configuring the queue for 176400 bytes, lw = 17640, hw = 158760, thr = -1.
5 20 1 io-media-generic/aoi: audio_decoder: IterateOutputFormats 'AWAR', 44100x16 channels 2 (2 x49152bytes)
5 20 1 io-media-generic/aoi: audio_writer using output device: '/dev/snd/pcmPreferredp'
5 20 1 io-media-generic/aoi: audio_writer asking for Signed 16-bit Little Endian, 1..2x17640B frags, 44100Hz, bps
=4, 2ch
5 20 1 io-media-generic/aoi: audio_writer settings: Signed 16-bit Little Endian, 3x4096B frags, 44100Hz, bps=4,
2ch, Q time 6960458359635968ms
5 20 1 io-media-generic/aoi: audio_writer PGA_StreamerCreate() adjusting chunk_size from 4096bytes to 20480bytes
5 20 1 io-media-generic/aoi: audio_writer using mixer device '/dev/snd/mixerC0D0'
5 20 1 io-media-generic/aoi: AudioWriterTask() adjusting chunk_size from 20480bytes to 20480bytes
5 20 1 io-media-generic/aoi: audio_decoder: RateFormat returning a rating of 0 for fourcc 1CVA
3 20 1 io-media-generic/trackplayer: Couldn't subscribe to the MM_EV_USER event.
2 20 1 io-media-generic/mmf: A resource element is missing a 'value' attribute
2 20 1 io-media-generic/aoi: fildes streamer reading failing on StreamerStickyErrror resource set
3 20 1 io-media-generic/trackplayer: Error event (read error)
2 20 1 io-media-generic/aoi: stream_reader->NextBuffer() MM_READ_LIST ERROR detected -1
5 20 1 io-media-generic/aoi: MediaClock Resume()
3 20 1 io-media-generic/aoi: GfwriterTask NextBuffer MM_STATUS_others=16.
2 20 1 io-media-generic/trackplayer: couldn't seek after an error (4002), giving up
2 27 0 MME:_next(2934): Could not find fid to play
Arun
12/06/2011 2:24 PM
post90448
> attribute
This indicates that there's something wrong with your io-media configuration file. Can I have a copy?
12/06/2011 2:29 PM
post90450
Hi Wojtek,
I am attaching my cfg file.
Arun
12/06/2011 2:40 PM
post90454
The file is indeed incorrect -- it's missing a "value=0" line in the resource{} element that was supposed to unset the
StreamerStickyError resource (around line 237 in your file). Try adding it back and see what happens.
12/06/2011 3:05 PM
post90455
here is what I got with that change.
Jan 01 00:08:17 5 20 1 io-media-generic/mmf: writer hint snd:* found
Jan 01 00:08:17 5 20 1 io-media-generic/mmf: writer hint gf:* found
Jan 01 00:08:17 1 27 0 MME:_setiomoutputattr(5959): Output device type 2 not supported
Jan 01 00:08:17 5 20 1 io-media-generic/mmf: Configuring the queue for -1 bytes, lw = 0, hw = 0, thr = -1.
Jan 01 00:08:17 2 20 1 io-media-generic/aoi: fildes streamer seek: failing (22)
Jan 01 00:08:17 2 20 1 io-media-generic/aoi: fildes streamer seeking failing on StreamerStickyErrror resource
set
Jan 01 00:08:17 5 20 1 io-media-generic/mmf: Configuring the queue for 1429093 bytes, lw = 285818, hw =
1143274, thr = -1.
Jan 01 00:08:17 4 20 1 io-media-generic/trackplayer: Couldn't load the my_video_decoder filter (based on the
decoder tag), mmerr=4047
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: my_audio_decoder: RateFormat returning a rating of 60 for fourcc
CA4M
CA4M
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: my_audio_decoder: EventListenerList returning type =
MM_EV_VOICE_UPDATE
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: in my_audio_decoder: SetInputFormat seeing aac format profile: 2
adts: 0
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: my_audio_decoder: SetInputFormat AAC decoder fourcc:'CA4M'
profile:29 adts:0 streamFmt:'AAC_SF_RAW' nchannels:2 frate:44100hz
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: my_audio_decoder: SetInputFormat audio card fourcc:'AWAR'
nchannels:2 frate:44100hz depth:16bits
Jan 01 00:08:17 5 20 1 io-media-generic/mmf: Configuring the queue for 176400 bytes, lw = 17640, hw = 158760,
thr = -1.
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: my_audio_decoder: IterateOutputFormats 'AWAR', 44100x16 channels
2 (2 x49152bytes)
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: audio_writer using output device: '/dev/snd/pcmPreferredp'
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: audio_writer asking for Signed 16-bit Little Endian, 1..2x17640B
frags, 44100Hz, bps=4, 2ch
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: audio_writer settings: Signed 16-bit Little Endian, 3x4096B
frags, 44100Hz, bps=4, 2ch, Q time 6333290055204864ms
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: audio_writer PGA_StreamerCreate() adjusting chunk_size from
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: audio_writer using mixer device '/dev/snd/mixerC0D0'
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: AudioWriterTask() adjusting chunk_size from 20480bytes to
20480bytes
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: my_audio_decoder: RateFormat returning a rating of 0 for fourcc
1CVA
1CVA
Jan 01 00:08:17 3 20 1 io-media-generic/trackplayer: Couldn't subscribe to the MM_EV_USER event.
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: my_audio_decoder: NextBuffer skipping 1 MRAE_TYPE_DECODER_CONFIG
payloads.
Jan 01 00:08:17 2 20 1 io-media-generic/aoi: my_audio_decoder: myDecoderInit DecoderInitAlloc_AAC() failed err
= -9999
Jan 01 00:08:17 2 20 1 io-media-generic/aoi: my_audio_decoder: NextBuffer myDecoderInit() failed err =
0xffffd8f1
Jan 01 00:08:17 5 20 1 io-media-generic/aoi: MediaClock Resume()
= -9999
0xffffd8f1
Jan 01 00:08:17 2 20 1 io-media-generic/trackplayer: graph reports some...
12/06/2011 3:08 PM
post90456
Wouldn't these be errors in your filter:
NextBuffer skipping 1 MRAE_TYPE_DECODER_CONFIG payloads.
myDecoderInit DecoderInitAlloc_AAC() failed err = -9999
NextBuffer myDecoderInit() failed err = 0xffffd8f1
On 11-12-06 3:05 PM, "Arun Johnson" <community-noreply@qnx.com> wrote:
>Hi,
>found
>found
>seek: failing (22)
>load the my_video_decoder filter (based on the decoder tag), mmerr=4047
>my_audio_decoder: SetInputFormat seeing aac format profile: 2 adts: 0
>depth:16bits
>bps=4, 2ch
>adjusting chunk_size from...
12/06/2011 2:25 PM
post90449
It looks like io-media couldn't read your file in readlist mode. If it
could sniff it and set the graph up, it has permissions. What filesystem
is the file on?
On 11-12-06 2:19 PM, "Arun Johnson" <community-noreply@qnx.com> wrote:
>Hi,
>and displayed through aviage. I am working on arm target.
>video/audio decoder filter and the mp4_parser provided with aviage
>supported
>decoder fourcc:'CA4M' profile:29 adts:0 streamFmt:'AAC_SF_RAW'
>card fourcc:'AWAR' nchannels:2 frate:44100hz depth:16bits
>Little Endian, 1..2x17640B frags, 44100Hz, bps=4, 2ch
>Little Endian, 3x4096B frags, 44100Hz, bps=4, 2ch, Q time
>6960458359635968ms
>MM_EV_USER event.
>'value' attribute
>3 20 1...
12/06/2011 2:30 PM
post90451
I am working on arm target. with qnx6 filesystem nio my eMMC mounted by:
mount -t qnx6 /dev/hd0t179 /media
Arun
12/06/2011 2:32 PM
post90452
Actually this one is even more interesting... Errno 22 is EINVAL -- what filesystem was your file living in?
12/06/2011 2:33 PM
post90453
Arun
12/07/2011 1:45 PM
post90474
Hi ,
can anyone tell me what's the error related to output saying:
Jan 01 00:04:25 5 20 1 io-media-generic/mmf: writer hint snd:* found
Jan 01 00:04:25 5 20 1 io-media-generic/mmf: writer hint gf:* found
Jan 01 00:04:25 1 27 0 MME:_setiomoutputattr(5959): Output device type 2 not supported
Jan 01 00:04:25 5 20 1 io-media-generic/mmf: Configuring the queue for -1 bytes, lw = 0, hw = 0, thr = -1.
Jan 01 00:04:25 2 20 1 io-media-generic/aoi: fildes streamer seek: failing (22)
Jan 01 00:04:25 2 20 1 io-media-generic/aoi: fildes streamer seeking failing on StreamerStickyErrror resource
set
Jan 01 00:04:25 5 20 1 io-media-generic/mmf: Configuring the queue for 881335 bytes, lw = 176267, hw = 705068,
thr = -1.
Jan 01 00:04:25 5 20 1 io-media-generic/trackplayer: Skipping subgraph 0 because there is no device specified.
Arun
12/07/2011 2:01 PM
post90475
> failing (22)
This one means that lseek returned EINVAL. The only reason I can think of is that either a bug in the parser or a
problem in your MP4 file caused the parser to attempt a seek to a negative position in the file.
The StreamerStickyErrror resource that you have in your configuration file asks the streamer to remember the first error
that happens, and keep returning it from any subsequent calls. It's a way to prevent other parsers from wasting time
trying to read a file after an I/O error, such as when the file is on a scratched disc or the media has been ejected.
Try removing both resource{} elements that set the StreamerStickyErrror resource from your configuration file. If that
makes the file play, it could be that the invalid seek was caused by a bug in the parser. What version are you running?
Can I have a copy of your MP4 file?
12/07/2011 2:25 PM
post90476
I tried removing that ..Its still giving me the following:
Jan 01 00:00:08 5 20 1 io-media-generic/mmf: writer hint snd:* found
Jan 01 00:00:08 5 20 1 io-media-generic/mmf: writer hint gf:* found
Jan 01 00:00:08 1 27 0 MME:_setiomoutputattr(5959): Output device type 2 not supported
Jan 01 00:00:08 5 20 1 io-media-generic/mmf: Configuring the queue for -1 bytes, lw = 0, hw = 0, thr = -1.
Jan 01 00:00:08 2 20 1 io-media-generic/aoi: fildes streamer seek: failing (22)
Jan 01 00:00:08 5 20 1 io-media-generic/aoi: MP4Parser: max sample size = 10875.
Jan 01 00:00:08 5 20 1 io-media-generic/mmf: Configuring the queue for 881335 bytes, lw = 176267, hw = 705068,
thr = -1.
Jan 01 00:00:08 5 20 1 io-media-generic/trackplayer: Skipping subgraph 0 because there is no device specified.
I am using the attached m4v file for this run.
Arun
12/07/2011 2:55 PM
post90477
i am using mp4_parser with aviage core 1.2
Arun
